Author Topic: New Rigol DS1054Z oscilloscope  (Read 2059331 times)
Offline Chumanista
Re: New Rigol DS1054Z oscilloscope
« Reply #2900 on: September 16, 2016, 01:12:13 pm »
I just made a video guide to updating the firmware and unlocking:
The following users thanked this post: hammy, jsi, Lanaki
Online rstofer
« Reply #2901 on: September 16, 2016, 02:41:59 pm »
Very nice!  I am sure it will be a great help to new users.
The following users thanked this post: Lanaki
Offline Karel
« Reply #2902 on: September 16, 2016, 03:14:49 pm »
To enter a key via the scope's interface is a pain in the ass.
It's much easier, faster and less prone to error, to connect your scope to your pc via LAN, and use telnet.
Check the IP-address of your scope in the scopes menu.
On your pc, open a console and enter:
telnet 192.168.1.17 5555     (modify the IP-address)
Check connectivity using the command:
*IDN?
The scope will respond with brand, model and serial number.
Now enter:
:SYST:OPT:INST PDUY9N9QTS9PQSWPLAETRD3UJHYA   (replace the key with yours)
That's all.
Offline Fungus
« Reply #2903 on: September 16, 2016, 03:43:15 pm »
I didn't know you could do it with telnet, I thought you had to install that horrible driver software from the CD.
Edit: I just tried it and it works  :)
*IDN?
RIGOL TECHNOLOGIES,DS1104Z,DS1ZA123456XX,00.04.04.SP1
« Last Edit: September 16, 2016, 03:49:05 pm by Fungus »
Offline Karel
« Reply #2904 on: September 16, 2016, 05:34:45 pm »
In case you have to send it back for service/repair and you want to remove the installed options:
:SYST:OPT:UNINST
will uninstall the installed options.
Offline alsetalokin4017
« Reply #2905 on: September 16, 2016, 06:31:21 pm »
*IDN?
Not reading my posts?    :clap:
I've posted on the use of telnet to talk to the scope several times (at least nine times in fact). See my posts from July of 2015 for example:
https://www.eevblog.com/forum/testgear/is-ds1054z-with-firmware-00-04-02-04-07-hackable/msg715684/#msg715684
https://www.eevblog.com/forum/testgear/is-ds1054z-with-firmware-00-04-02-04-07-hackable/msg715695/#msg715695
Rigol-bashing, are we?   :-DD
Online rstofer
« Reply #2906 on: September 16, 2016, 07:21:27 pm »
Before my time here...  Nevertheless, it works perfectly although I had hoped for some kind of prompt.  Talking to a blank screen is a little disconcerting.
Given that Telnet works, which means a simple TCP connection will probably also work, there's no reason to get locked in to the provided software.  It might take a little packet sniffing to see how things work.
« Reply #2907 on: September 17, 2016, 04:21:23 am »
Online rstofer
« Reply #2908 on: September 17, 2016, 04:54:26 am »
http://www.teuniz.net/DSRemote/
I'll have to give that a try next time I have my Linux system running.
Not that I need the feature, really, just a curiosity.
Offline Karel
« Reply #2909 on: September 17, 2016, 07:10:13 am »
No need to. Everything is documented (in theory and besides bugs):
http://int.rigol.com/File/TechDoc/20151218/MSO1000Z&DS1000Z_ProgrammingGuide_EN.pdf
cp.literature.agilent.com/litweb/pdf/5989-6717EN.pdf
Offline Fungus
« Reply #2910 on: September 17, 2016, 09:18:41 am »
Related to the vertical positioning response speed that's become the new DS1054Z-hater's whipping-post:
I wonder how smoothly the signal traces can be moved up/down the screen using the SCPI interface.
« Last Edit: September 17, 2016, 03:35:17 pm by Fungus »
Offline urill
« Reply #2911 on: September 17, 2016, 03:17:38 pm »
Follow up on the panel LED not turning off problem...
I have been using the scope with faulty panel lights because I can't afford to be without my scope for two weeks.
I plug the usb drive with new firmware in the scope right after I switch on the scope.
This time, the scope turn on and the lights are normal. It fixed the problem without upgrading the firmware.
I suspect the scope did some sneaky things (write flash?) without user confirmation.
Offline urill
« Reply #2912 on: September 17, 2016, 03:47:30 pm »
After I recalibrate the scope, the problem came back. It is probably a hardware failure at this point.
Online rstofer
« Reply #2913 on: September 17, 2016, 05:05:46 pm »
Definitely worth downloading and reading.  I doubt that I will ever do anything with it but it's nice to have the information.
Offline Sredni
  • Country: aq
« Reply #2914 on: September 19, 2016, 10:12:36 pm »
So yes, a BIG improvement.  Massive. Looks like the DS1000Z firmware team have returned. :-+
For general information, I come from a really old firmware (04.02.sp4) and upgrading to 04.04.01.01 has slowed down the vertical movement noticeably when in STOP mode. I tried just before the update with the test signal and in STOP mode it was so very fluid - almost CRO-like, I'd say - a now it's not noticeably different from the RUN mode.
It appears, though, that in RUN mode things got a little better. The waveform appear to shim a little bit, but... oh, well.
Ok, now I'll go see what is new... :-)
Oh, BTW: does it matters to have only one or all four channel when doing an autocalibration?
« Last Edit: September 19, 2016, 10:21:20 pm by Sredni »
Online rstofer
« Reply #2915 on: September 19, 2016, 11:21:14 pm »
The directions say to remove the 4 probes, that's all that is required.  The test program will deal with the channels in its own way.  You will see the traces moving up and down.
The following users thanked this post: Sredni
Offline ankerwolf
  • Country: at
« Reply #2916 on: September 20, 2016, 06:14:30 pm »
Hello,
I cannot check the detailed systeminfo. I cannot tip faster.
Anyone the same problem?
LG Wolfgang
Offline bitseeker
« Reply #2917 on: September 20, 2016, 06:58:23 pm »
Works fine for me. Menu, Menu, Force, Menu. That's the only part of the sequence that you press in quick succession. Then, access the System Info screen normally. Maybe you're going too fast and the scope is missing one or more key presses.
Offline ankerwolf
  • Country: at
« Reply #2918 on: September 20, 2016, 07:03:04 pm »
ok, thank you! It's working!  :D
Offline bitseeker
« Reply #2919 on: September 20, 2016, 07:07:07 pm »
Great! :phew:
Offline ted572
  • Radio Communications Equipment/System Design Engr.
« Reply #2920 on: September 23, 2016, 11:40:29 am »
There is NEW Firmware available now for the MSO/DS1000Z Oscilloscopes
FW Version: 00.04.04.01.01
Released: 2016/09/14
 o  Added support for the multi-inteface of LXI
 o  Fixed bugs with Auto-Measurement functions
http://int.rigol.com/File/ProductSoftWare/20160914/DS1000Z(ARM)update.rar
Edit:  I see now (thanks to 'alsetalokin4017') that 'IAmBack' reported this firmware release in 'Reply #2878' on September 14, 2016.  https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg1026216/#msg1026216   I don't know how I missed seeing this. :palm:   If you go back and read the reply's after his post you will see responses to the fixes.
« Last Edit: September 23, 2016, 02:19:44 pm by ted572 »
Offline Fungus
« Reply #2921 on: September 23, 2016, 12:24:37 pm »
Coming thick and fast now!
They've changed the way the vertical movement works so it's now continuous movement while you turn the knob.
With one channel on it's very responsive. Not quite analog, but not bad.
Two channels a little bit worse.
Three channels... a bit worse.
Four channels... a bit laggy and some overshoot. It's OK with a delicate touch, hamfisted youtube bloggers will hate on it.
Overall? It's an improvement. With one or two channels enabled it's definitely better.  :-+
« Last Edit: September 23, 2016, 12:57:13 pm by Fungus »
Offline Fungus
« Reply #2922 on: September 23, 2016, 12:29:32 pm »
Looks like they're reading this forum...  :popcorn:
Offline f1rmb
« Reply #2923 on: September 23, 2016, 12:35:07 pm »
With one channel on it's very fast. Not quite analog, but not bad.
Four channels... a bit laggy and some overshoot. OK with a delicate touch, hamfisted youtube bloggers need not apply.
On the whole, I'll say it's an improvement - with one and two channels enabled it's definitely better.
Even faster than you think  ;D
Offline StuUK
« Reply #2924 on: September 23, 2016, 12:39:35 pm »
Just checked the extended system info (menu,menu,force,menu) on my recently purchased 1054Z and I get the following versions:-
Software 00.04.04.00.07
Firmware 0.2.3.11
So a little confused as to what the latest actually is?
« Last Edit: September 23, 2016, 12:41:09 pm by StuUK »
