Author Topic: New Rigol DS1054Z oscilloscope  (Read 2711873 times)
0 Members and 149 Guests are viewing this topic.
Offline alsetalokin4017
Re: New Rigol DS1054Z oscilloscope
« Reply #2975 on: September 29, 2016, 12:52:17 pm »
How on earth can somebody even talk about unlocking the features unless you mention the correct code DSER? (which is undocumented, unmentioned in the Riglol updater keygen itself ..... but works anyway to unlock everything except the 500 uV/div option, of course.) Who would do that?   :-//
Offline Fungus
« Reply #2976 on: September 29, 2016, 12:55:07 pm »
What makes that the "correct" code?  :-//
The other codes work just fine. I'm just wondering why somebody would go around saying that bandwidth unlocking doesn't work.
« Reply #2977 on: September 29, 2016, 01:00:38 pm »
It's the correct code to unlock all the _working_ options. I'm wondering why somebody would want to only unlock a few of the working options by entering separate codes one at a time,  rather than all of them by using a single code entered once. And who said the bandwidth option doesn't work? Link please.
Offline canibalimao
  • Country: pt
Offline Fungus
« Reply #2979 on: September 29, 2016, 08:32:34 pm »
Because "DSER" isn't listed on the Riglol site?
(anybody know who's in charge of that site?)
« Reply #2980 on: September 29, 2016, 08:48:04 pm »
« Reply #2981 on: September 29, 2016, 08:51:05 pm »
But it is talked about and listed on _this_ site, many times, since long ago, along with the fact that it isn't documented in the Riglol site or the instructions that come with Riglol. I knew about it even before I got my scope in April 2015.
Offline Fungus
« Reply #2982 on: September 29, 2016, 09:07:18 pm »
Sure... but apparently the new guy who just came in here has never heard of it.
Offline ProBang2
« Reply #2983 on: September 29, 2016, 10:39:13 pm »
Perhaps that´s the reason for alsetalokin´s post (regarding the "DSER" code)??   :-//
Offline rolycatTopic starter
« Reply #2984 on: September 30, 2016, 07:43:29 am »
It has been documented in the FAQ section of the first post of this thread since April 2015.
I believe it was first mentioned here, in April 2014.
« Last Edit: September 30, 2016, 07:53:39 am by rolycat »
Offline Quiggers
« Reply #2985 on: September 30, 2016, 12:31:55 pm »
I followed the codes on the site, not the thread, it's a bit of a big thread.
So in a round about way , you're trying to help me get more bandwidth and avoid the 500uV no supporting hardware thingy.
So thank you.
Offline ProBang2
« Reply #2986 on: October 01, 2016, 01:57:05 am »
Also, are you guys doing the self-cal on the scope as requested, after firmware upgrade? I only ask because I now see a new button on the Self-Cal menu that I haven't seen anyone mention.
It now reads:
  • Start
  • End
  • LFCal
  • Output
Was this there before? I certainly don't remember it.
I tried LFCal, it does something and then says it failed. It looks like it might need a probe attached or something.
I do not want to ride a dead horse, but I am still curious:
Is there any new information about the two new functions in the the expanded Self-Cal menu?
("LFCal" and "Output").
BTW: Are there more undocumented "hidden" functions/infos available aside from:
- The added functions in the Self-Cal menu (see above)?
- The expanded/more detailled list in the System-Info screen?
- The factory reset?
« Reply #2987 on: October 11, 2016, 02:22:16 am »
A quick Heads-Up:
Fry's Monday Promo Code 6068321 is good for $50 off on the 1054Z. Good thru 10/11, and supposedly "they pay the sales tax on most oscilloscopes".
http://www.frys.com/product/8708441
I don't know if these codes are global, but you're welcome to try this one.
I was lucky and TEquipment price-matched a similar sale from Arrow a couple months back, that is also a possible avenue to pursue. Big Shout-out to Remy Ortiz at TEquipment, BTW - he sent me a direct link to the sale item AND created an account for me to use in less than 48 hours. World-class service. (Remy, sorry it took me so long to get around to this... life's been a raging bear ;) )
Thanks for all the advice guys... (you know who you are). :D
I am not my pants. I am not your pants either.
« Last Edit: October 11, 2016, 02:24:34 am by mnementh »
Offline bitseeker
« Reply #2988 on: October 11, 2016, 02:26:11 am »
Nice! I didn't even know Fry's carried Rigol scopes.
Offline Excoriator
« Reply #2989 on: October 11, 2016, 03:26:55 pm »
I've just got my DS1054Z. Very pleased with it, except that I can't get the upgrade hacks to work. I have tried it several times, working from the beginning each time, and double-checking everything, but no dice. It is now shutting down any code recognition for 12 hours so I can't try it very often!.
Have Rigol at last closed the loophole? Quite likely knowing my luck! The SW version is 00.04.04.SP1, Board 0.0.1. Anyone got any useful suggestion?
Offline Karel
« Reply #2990 on: October 11, 2016, 04:15:09 pm »
Connect the scope to your LAN.
Open a console and enter the following command:
telnet 192.168.1.6 5555   (change the IP-address with the one that is assigned to your scope)
enter the command:
*IDN?
It will respond with "RIGOL TECHNOLOGIES,DS1054Z,DS1ZA17xxxxxxx,00.04.04.SP1"
Copy the serial number of the scope.
Go to this site: http://gotroot.ca/rigol/riglol/
Paste the serial number in the first field.
In the options field enter: DSER  (nothing else!)
Don't change the private key field.
Click on "Generate".
Copy the generated key.
In the telnet connection enter the command:
:SYST:OPT:INST PDUY9N9QTS9PQSWPLAETRD3UJHYA
(replace the key with your generated key and pay attention to remove the dashes)
That's all.
Offline Excoriator
« Reply #2991 on: October 11, 2016, 06:27:22 pm »
Thanks, Karel.
I will certainly try it that way when the scope will accept another attempt, but I am not optimistic as it is essentially exactly what I did by hand. It has the advantage of getting around the possibility of copying mistakes, but as I said, I was extremely careful and double checked this on three separate occasions.
I am away from home for the next few days so will probably not be able to try it until next week, but I will let you know if it works.
Offline JohnPen
« Reply #2992 on: October 11, 2016, 06:47:00 pm »
I had the same problem last year in that the first 2, separately entered, attempts to use the generated code from the http://gotroot.ca/rigol/riglol/ process failed.  It was only on the third attempt typing in my serial number yet again that it seemed to generate a valid code for my DS1054Z.   I seem to remember that others had problems in that the generated code is not always correct and you need to repeat the whole process a couple of times until eventually you obtain a valid key.
Best of luck
« Reply #2993 on: October 12, 2016, 01:56:49 am »
Even better: Download the Source Code Archive (link at the bottom of the Riglol page) and run the program locally. You will find versions for Windows .exe, Linux (source to be compiled on your system), generic HTML which will open in your choice of browser, and OSX. (I have not tested the OSX version but the other three work properly.)
A very common mistake when entering the SN and the unlock keys manually using the little virtual keyboard is to mix up the characters "5" and "S", or "B" and "8". It is far easier and more reliable to use the telnet connection over LAN and copy-paste to enter the code as Karel describes above. I have encountered errors when using the abbreviated SCPI commands, so I recommend using the full commands, caps and lower case as shown: :SYSTem:OPTion:INSTall    followed by your 28 character key.
To remove the options and go back to "virgin" DS1054z 50 MHz bw, use the SCPI command :SYSTem:OPTion:UNINSTall
As far as I am aware, all DS1054z "DSER" option unlock codes start with the same two initial groups of 7 characters:  RDJ9JBB N3SWWUS xxxxxxx xxxxxxx. Enter your own unique code without hyphens or spaces.
Check to make sure the instrument's "System Info" screen is reporting the same SN as found on the sticker on the back of the scope. If they differ, you should of course use the SN that the scope's info screen is reporting.
Offline Karel
« Reply #2994 on: October 12, 2016, 06:34:15 am »
I can confirm that.
Offline Excoriator
« Reply #2995 on: October 12, 2016, 09:01:07 am »
The first problem is that 'telnet' is not accepted (windows 10)!
So I entered the code manually, double checked, and got "Code avoid for 12 hours" or similar in response. I am as sure as I can be that it is is not 'finger trouble'  I am not sure if this is real time or running time of the scope. It certainly hasn't had 12 hours running time since the last attempt. The first two code groups are indeed "RDJ9JBB-N3SWWUS" as found by others. I have to leave soon, so will try again next week. Thanks for suggestions and help everyone.
Z80
  • Guest
« Reply #2996 on: October 12, 2016, 10:03:41 am »
Do you have the S or Plus model?  I could be wrong but I believe the simple code hack doesn't work with those versions of the DS1054Z.
Offline Karel
« Reply #2997 on: October 12, 2016, 10:21:28 am »
Reboot your computer and select Linux. If the selection isn't there, install it. It's free.
In the unfortunate case you are forced to use windows, install Putty: http://beyondmeasure.rigoltech.com/acton/attachment/1579/f-0605/1/-/-/-/-/LAN%20troubleshooting%20with%20PuTTY.pdf
Offline Excoriator
« Reply #2998 on: October 12, 2016, 10:44:23 am »
To the best of my knowledge its a standard DS1054Z.
Offline gmb42
« Reply #2999 on: October 12, 2016, 11:22:40 am »
The telnet client hasn't been installed by default since Windows 7.  For Windows 10, run PowerShell as an administrator and enter:
Enable-WindowsOptionalFeature -Online -FeatureName TelnetClient
The following users thanked this post: ebastler, bitseeker
