Author Topic: New Rigol DS1054Z oscilloscope  (Read 2787400 times)
0 Members and 36 Guests are viewing this topic.
Offline Njk
  • Country: ru
Re: New Rigol DS1054Z oscilloscope
« Reply #4800 on: July 31, 2024, 12:26:30 pm »
With one of the previous firmwares, they'd added "AC.Vrms" item in the Vertical menu, but also introduced a GUI defect there (marked with red circle on the image below). If the defect managed to survive the latest update?
Offline szpila
« Reply #4801 on: July 31, 2024, 12:30:40 pm »
Yes, it is still in latest fw :)
Online Adrian_Arg.
  • Country: ar
« Reply #4802 on: August 03, 2024, 10:56:45 pm »
So what did they fix? If they didn't fix that nonsense, they didn't fix anything. |O
Offline rob040
« Reply #4803 on: August 04, 2024, 11:50:37 am »
Hi Njk,
Maybe a bit silly, but what is the defect that you mention? I'm only aware that Rigol introduced this function, but not of any mistake.  :-//
And was it reported to Rigol when it was discovered?
Online Adrian_Arg.
  • Country: ar
« Reply #4804 on: August 04, 2024, 03:12:12 pm »
Below the "AC.Vrms#" button there is another button with the number 3, which does not serve any purpose, since it is repeated with another button. I don't think they have fixed the problem with the frequency and the 24 bit depth. It would be good if they made a list of corrections.
debajo del boton "AC.Vrms# hay otro botton con el numero 3, que no cumple ninguna funcion, ya que esta repetido con otro botton, no creo que hayan arreglado el problema de la frecuencia y los 24 bit de profundidad, seria bueno que hagan lista de correcciones
The following users thanked this post: rob040
Offline Njk
  • Country: ru
« Reply #4805 on: August 04, 2024, 03:12:36 pm »
A screenshot for the defect is in my previous post. Notice that they'd also updated the Help information. According to that information, the intended outcome supposed to look like on the image below. "AC.Vrms" is an additional item, which is the last one in the column (it corresponds to F6 key). But something went wrong and "AC.Vrms" is actually located at the place of "Variance" item (which is now missing). For me, it's definitely a defect. The interns made a mistake.
Online Adrian_Arg.
  • Country: ar
« Reply #4806 on: August 04, 2024, 03:19:44 pm »
So now they fixed it, they removed button 3 and put "Variance" or is that an old image?
Offline Njk
  • Country: ru
« Reply #4807 on: August 04, 2024, 04:14:23 pm »
They'd placed AC.Vrms instead of Variance, not below it
Online Adrian_Arg.
  • Country: ar
« Reply #4808 on: August 04, 2024, 09:07:45 pm »
I understand what you mean about the buttons, but this image is with the latest firmware, with the error of button 3 corrected???
Offline Njk
  • Country: ru
« Reply #4809 on: August 05, 2024, 10:12:52 am »
No, this image is created with a picture editor, to show how it should look. It's not a real screenshot
Offline rob040
« Reply #4810 on: August 05, 2024, 03:51:50 pm »
The question remains whether it was ever reported to Rigol or not. If not, you can't blame them not fixing it. :P
« Last Edit: August 05, 2024, 03:53:31 pm by rob040 »
Offline McBryce
« Reply #4811 on: August 05, 2024, 05:53:40 pm »
What?? Seriously?? You don't think Rigol should do functional testing themselves and just throw the latest compiled firmware on the market?? Of course they should find it themselves! Customers aren't responsible for finding flaws in their product, that is most definitely their responsibility. This isn't some short-lived tech-toy. This is a measurement device that people need to be able to trust and Rigol want you to believe you can trust it.
McBryce.
Offline rob040
« Reply #4812 on: August 05, 2024, 06:15:56 pm »
Of course they should do that, but we know after so many years they simply don't do it. :palm:
Online Adrian_Arg.
  • Country: ar
« Reply #4813 on: August 05, 2024, 09:32:37 pm »
I still haven't installed this latest firmware, because I don't know what it improved or fixed that is worth installing.
yo tadavia no puse este utimo firmware, porque no se que mejora o corrigieron, que valga la pena instalarlo
Online Adrian_Arg.
  • Country: ar
« Reply #4814 on: August 23, 2024, 02:00:44 pm »
I installed the firmware DS1000Z(ARM)Updatev00.04.05.02.07_tcm7-4148, on my rigol ds1054z and I see no changes, or is it that I am short of visa??
Online Adrian_Arg.
  • Country: ar
« Reply #4815 on: September 20, 2024, 04:46:31 pm »
Since I installed the latest firmware on the DS1054Z, it does not allow me to calibrate, I almost reached the end of the progress bar, and the function exits.
Offline MarkF
« Reply #4816 on: September 20, 2024, 05:44:14 pm »
The latest version of firmware for the DS1000Z is 00.04.05.02.08.
It can be downloaded here:  DS1000Z & Z-Plus  00.04.05.02.xx
For calibration to complete, you need to allow the scope to warm-up for at least 30 minutes and remove all the probes.
Offline Karel
« Reply #4817 on: September 20, 2024, 05:58:19 pm »
It happened also to me that, after the fw update, when I did the calibration (no probes attached,
more than 30 minutes warmup etc.), it got stuck.
After waiting for another hour, I switched it off, and switched it on again.
Then I did the calibration again and it succeeded without problems...  :-//
Chinese software I guess...  :-DD
The following users thanked this post: Jacon
Online Adrian_Arg.
  • Country: ar
« Reply #4818 on: September 20, 2024, 08:56:44 pm »
If that is the version I have installed, it does not let me calibrate and I could not find any information about what they improved.
Offline Fungus
« Reply #4819 on: September 20, 2024, 09:11:12 pm »
Did you just "upgrade"? Did it work before?
So why install it?
Offline MarkF
« Reply #4820 on: September 20, 2024, 11:32:29 pm »
Well, find out what version you do have!
Under the trigger knob quickly press the MENU > MENU > FORCE > MENU buttons.
Then go to the System Info page to see the extended system information.
The following users thanked this post: Andrew Morton
Online Adrian_Arg.
  • Country: ar
« Reply #4821 on: September 20, 2024, 11:49:42 pm »
software version: 00.04.05.02.08
Offline hcet14
« Reply #4822 on: October 02, 2024, 08:52:46 pm »
Hello, I guess it's my first post here in this thread.
I didn't use my ds1054z for a very long time (2 years?). I read something about turning on the scope after a while in the closet, it's not starting anymore?
It has the h*ck*d FW and worked ok the last time I used it.
What I read here, 00.04.05.02.08 is the latest FW version. Can I update with 00.04.05.02.08 and still have 100MHz bandwidth?
Online Adrian_Arg.
  • Country: ar
« Reply #4823 on: October 02, 2024, 09:31:19 pm »
if it does not modify the bandwidth at all
Offline hcet14
« Reply #4824 on: October 02, 2024, 09:45:04 pm »
The ds1054z starts  8)
FW version: (see attachment)
Installed options: (see attachment)
Hello @Adrian_Arg. "quote":
"if it does not modify the bandwidth at all"
What do you mean with the starting "if"? Do I have to be concerned or is it just a typo?
« Last Edit: October 02, 2024, 09:49:57 pm by hcet14 »
The following users thanked this post: Fungus
