Author Topic: New Rigol DS1054Z oscilloscope  (Read 2716009 times)
0 Members and 300 Guests are viewing this topic.
Offline Crow
Re: New Rigol DS1054Z oscilloscope
« Reply #950 on: January 15, 2015, 09:58:26 am »
Good News for me :D
i used the Tool and the first Code Successfully worked  :-+
Thanks for all the Tips and Hints and of Course for the Amazing work  :-+ :-+
Offline Bzzz
  • shoving atoms
    • Wan Hung Lo Electronics Blog :)
« Reply #951 on: January 15, 2015, 11:15:45 pm »
It already has the Newest Firmware 4.02.SP4 factory installed and the Board Version jumps from 0.2.2 to 0.1.1  :-\
as you can see on the Screenshot
Interesting. I got mine the same day from Batronix, but it has SP3 installed. Haven't tried much yet, I lack cables and adapters at home, and a (already shipped) function generator for jitter bug testing. And, guess what, my university chair of physics (where I left it for the moment) doesn't even have a function generator at all. But µA meters and Lock-In amps that are for sure much older than I am and must have cost a fortune...yeah, priorities  ;D
Anyways, I hope I have more time next week, so that I can assemble the FG085 and try some stuff at home. Hope that's enough for jitter testing - if not, I don't care for the moment, I have no plans for projects in the MHz+ regime yet. Same goes for the Riglol upgrades, I don't need pirated keys for stuff that I'm not even using. Not even sure if I unlock the 100 MHz one day, even if that's not an upgrade that Rigol offers for cash.
Offline fremen67
« Reply #952 on: January 15, 2015, 11:17:54 pm »
Hi all,
Maybe interesting for those living (or working) in Germany: I received my DS1054z yesterday (10 days for the delivery). I bought it at innet24.de through meinpaket.de with a 7% discount. I checked today and it's now 5% (5SPAREN code)
http://www.meinpaket.de/de/rigol-ds1054z--digital-speicheroszilloskop-50-mhz-4-kanaele-1-gs-s-abtastrate-30-000-wfms-s/p682293255/?traffic_source=5SPAREN&showTellaFriend=false
A strange thing I noticed is the frequency counter that was oscillating around 500 - 700Hz on the probe adjustment signal ...
I updated the firmware from SP3 to SP4 and don't see the problem anymore. It is now locked to 1.00001 kHz ... Did someone else see this?
Edit: my first impressions:
- the screen does not look as clear as my Hnntek MSO (kind of blury) but still OK
- the fan definitely needs a replacement
- I find the auto adjustement quite slow
- New fonts in SP4 are perfects!
- A lot of options and functionnalities.. but that was not a surprise  :)
« Last Edit: January 17, 2015, 03:05:19 am by fremen67 »
I'm a machine! And I can know much more! I can experience so much more. But I'm trapped in this absurd body!
Offline nixfu
« Reply #953 on: January 16, 2015, 03:27:19 am »
>Was Dave just having a bad PC day with the software or is this nightmare for real ?
The software works fine for me.  And fellow eevblog forum member Alessandro's software he is writing for the Rigol is just fantastic.
https://www.eevblog.com/forum/testgear/rigol-ds1000z200040006000-waveform-capture-utility/msg570679/#msg570679
I think the problem is Dave already had a conflicting set of drivers etc.. from the Agilent scope.  Probably needed to do a total uninstall of the other scopes software/drivers/etc before starting.
« Last Edit: January 16, 2015, 03:35:18 am by nixfu »
Offline Solder_Junkie
« Reply #954 on: January 16, 2015, 04:25:32 pm »
Anyone know if the 100 MHz hack is reversible? From what I recall, it changes the model type and doesn't uninstall using the uninstall all command.
Offline nixfu
« Reply #955 on: January 16, 2015, 07:01:15 pm »
Yes there are some commands you can execute from the ultravision software command interface that will delete the key.
« Reply #956 on: January 16, 2015, 08:57:38 pm »
Any clue as to which command will remove it? There had been earlier comments that "uninstall all" didn't remove it, as it changed the model to 1104.
I am reluctant to try it without a way back -in case it needs returning under warranty...
Thanks
Offline hammy
« Reply #957 on: January 16, 2015, 09:12:36 pm »
For God's sake  ::)
Search -> scpi command uninstall
Or download the pdf manual and use the search funktion there, please.
« Last Edit: January 16, 2015, 09:15:29 pm by hammy »
« Reply #958 on: January 16, 2015, 09:21:27 pm »
For God's sake  ::)
Except it has been previously reported that the 100 MHz mod changed the model number and wasn't reversible by "uninstall". Do you know if that is the case, or not?
Offline dadler
« Reply #959 on: January 16, 2015, 11:44:35 pm »
Argh- Tequipment just re-updated the ship date on my 1054Z from the 20th to the 26th.
I wish there was a 4 channel scope in the DS2XXX series for < $1k. The low price on the 1054Z is making it hard for Rigol to keep up with demand.
Offline HighResolution
« Reply #960 on: January 17, 2015, 12:49:55 am »
Yeah I got the same email today, sucks.  I actually got excited at first, thought they might have shipped it out today.
Its probably only a slight delay as I am sure the scopes have been in transit now for some time.
Offline pickle9000
« Reply #961 on: January 17, 2015, 01:38:10 am »
My order was Nov 10 arrived Jan 2 Tequipment, shipped to Canada so 6ish weeks
Offline Mandragora
« Reply #962 on: January 17, 2015, 02:17:23 pm »
Hello, I am wondering if anyone tested 500uV after SP4.
Maybe Rigol fixed this problem.
Could anyone test it if it is possible?
Offline BlueBill
« Reply #963 on: January 17, 2015, 04:12:01 pm »
Good News for me :D
I'm getting a DS1054z at the end of the month, what Windows tool are you referring to? Ultra Sigma?
Offline keninvic
« Reply #964 on: January 17, 2015, 04:19:04 pm »
I am on that list too, delayed till 26th.  Are the Rigols purchased from TEquipment  shipped from Rigol in Beaverton, OR or NJ?
Offline JDubU
« Reply #965 on: January 17, 2015, 04:46:34 pm »
My DS2072 was shipped from NJ.
Offline Teneyes
« Reply #966 on: January 17, 2015, 05:16:28 pm »
But you may have to request tracking # once you see complete order status at TE, 7 days NJ to WA
« Last Edit: January 17, 2015, 05:18:17 pm by Teneyes »
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
Offline pickle9000
« Reply #967 on: January 17, 2015, 08:51:38 pm »
 500uV is for another Rigol scope, the 1054z does not have that capability.
Offline Mark
« Reply #968 on: January 23, 2015, 05:45:00 pm »
Well it looks like I was very lucky to get the last one from Batronix, their website is now showing "end of March / beginning of April".  Ordered  on Sunday and received on Thursday, excellent service!  So far I'm blown away with the whole feel of the scope, for the price it is unbeatable.    The unlock code worked a like a charm first time, so I'm even happier.
eevblog has cost me a small fortune!
Offline CrashO
« Reply #969 on: January 23, 2015, 06:10:27 pm »
Same here. Ordered Sunday (22:53) and received it on Thursday in The Netherlands  :-+
Offline dadler
« Reply #970 on: January 23, 2015, 06:22:43 pm »
They finalized the pre-auth on my credit card yesterday, so I have been fully charged now. I hope this means that the date will not get pushed out again. :)
Offline tequipment
    • TEquipment
« Reply #971 on: January 23, 2015, 08:02:02 pm »
We got 383 units in yesterday.  They started shipping today but most will ship monday.  We will have 110 left for stock after everything ships!  This is the 1st time we have had stock since it was launched.
Best Regards,
Evan
TEquipment.NET
http://www.tequipment.net/Rigol/DS1054Z/Digital-Oscilloscopes/
Offline aroby
« Reply #972 on: January 23, 2015, 08:51:09 pm »
Best Regards,
Evan
TEquipment.NET
Amazing numbers for an oscilloscope!  Plus, I ordered one today (before reading this) so that I could get in the queue.  Sounds like I may not have to wait too long ...
Offline Spyke
« Reply #973 on: January 23, 2015, 08:59:53 pm »
Mine shipped today too, my first ever scope (unless a crappy dso-quad counts :-DD).
Can anyone that gets theirs post the firmware ver/board rev of these freshly made scopes? Wonder if the code generators to unlock all features still work...
Offline BlackLabelSix
« Reply #974 on: January 26, 2015, 12:23:53 am »
Ordered one last night, hopefully I can get in on this batch, but if not from what I am reading it will be worth the wait  8)
