Author Topic: New Rigol DS1054Z oscilloscope  (Read 2733617 times)
0 Members and 14 Guests are viewing this topic.
Offline gstorto
Re: New Rigol DS1054Z oscilloscope
« Reply #4850 on: May 12, 2025, 07:30:33 am »
Another question, is this supposed to be a fixed voltage power rail?
It might be, but it sets the common mode output voltage which has to be within range of the next stage.
I would ignore the differential amplifier stage until the input buffer is working.
Sorry David, I forgot to mention.
I was investigating this because what I had seen on the "FET input amp stage", which I believe you mean is the input buffer?
The input is a 1 kHz 0 to -10V square wave through a x10 probe (so 0 to -1V in effect):
This is the differential buffer output to the ADC by the way:
« Last Edit: May 12, 2025, 07:55:09 am by gstorto »
Offline magore
« Reply #4851 on: July 13, 2025, 03:28:33 am »
I just reported the Vertical Menu errors to Rigol emailed to [email protected]
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #4852 on: August 15, 2025, 08:25:39 pm »
Hello everyone,
I'm returning to electronics after at least 5 years. I would like to update my DS1054Z. After reading the latest comments, I understand that the most stable firmware without weird errors is 00.04.05.02.02.
Does anyone have this firmware version? It is no longer available online.
Thanks in advance.
Update: I've found a link that I missed. Thanks everyone!
« Last Edit: August 15, 2025, 08:34:28 pm by HoracioDos »
Offline HoracioDos
  • Country: ar
« Reply #4853 on: August 15, 2025, 08:47:27 pm »
Hi!
Just curious, did you get an answer from them?
Since the latest version is still 00.04.05.02.08, I'm guessing you didn't.
Thanks!
Offline MarkF
« Reply #4854 on: August 15, 2025, 11:54:48 pm »
If you really want 00.04.05.02.02, here it is which I downloaded from the North America site.
The following users thanked this post: HoracioDos
