Author Topic: New Rigol RSA5000 Real Time Spectrum Analyser  (Read 76782 times)
Online 2N3055
  • Country: hr
Re: New Rigol RSA5000 Real Time Spectrum Analyser
« Reply #125 on: May 26, 2020, 06:36:36 am »
I see nice improvement from 3GHz up (preamp on 10kHz BW), but I also see new spur at around 120MHz.
On a pics without preamp, you can see that spur at 120 MHz on stock (3kHz BW) is there  , but on "post" 120MHz spur is 10 dBm higher.
Also new spurs at 1550 MHz and 2775MHz, 5-6 dBm..
Similar as "with preamp", from 3GHz up, noise floor is better..
It can be that now PSU buses became resonant on some (other than before) frequencies (lower ESR, higher Q), or probably RSA has some spur rejection in software that would need recalibration.......Or both...
The following users thanked this post: Sighound36
Online tv84
  • Country: pt
« Reply #126 on: May 26, 2020, 08:34:17 am »
Or perhaps you are comparing the RSA5065 data to "tv84" RSA3000 upgrade version?
This one.
He didn't do any before photos so, now, he can only compare with another RSA. What you ask is the best way but now it'll be impossible.
At least, he's comparing a 3030 "upped" with a 5065 "stock". Without the PSU improvement it still is a very nice upgrade given the fact that, precisely in the additional range (3-6.5GHz), is where it is better than a supposedly calibrated one.
The following users thanked this post: Sparky
Online tv84
  • Country: pt
« Reply #127 on: May 26, 2020, 08:38:41 am »
I agree but i find it hard to believe that Rigol would do any software filtering of something caused by a PSU (made with crap components which may create any random effects of that type).
Offline Sighound36
« Reply #128 on: May 26, 2020, 08:49:56 am »
2N3055
I would agree the 120Mhz I know is the obvious one, I suspect this has something to do with a glitch that another forum user had identified with his RSA and we have spoken about, I will be delving deeper into this in the coming weeks.
Your observations are very fair with regard to resonances and as I mentioned before  in a previous post plans are afoot to look at the line filtration insertion losses plus as well as  revisions in the switching frequency damping and secondary stage work.
However it a nice start. I would like mention my unit has the option OXCO clock fitted, for the comparison I removed the clock but in the interests of fairness I placed in the stock unit and performed the same sweeps the results were identical on the the stock 5065 screen, but that is as far as it went.
What i could do is set up up the Agilent VSG and measure the output on both units at some point as well.
While I was inside the unit I did notice the circuit layout around the main clock at the bottom center right of the circuit board, I will take some measurements in a few strategic places as well.
All good fun though
Online 2N3055
  • Country: hr
« Reply #129 on: May 26, 2020, 02:05:13 pm »
It wouldn't be PSU specific, but many instruments will try to "sanitize" spurs (any spurs) and they do it by taking baseline and than "do something" about it... My Signal Hound has "Suppress spurs" mode.
The following users thanked this post: tv84
Online 2N3055
  • Country: hr
« Reply #130 on: May 26, 2020, 02:15:44 pm »
2N3055
All good fun though
I mentioned resonances because I have some experience with switchers designed to have resonant filters...  |O
And also power planes resonating with decoupling capacitors... Lots of  fun...Not.
I wasn't complaining, just commenting.  I have no doubt that you will be able to do some serious work here and looking forward to it!!
Best regards,
Offline Sighound36
« Reply #131 on: May 26, 2020, 06:34:48 pm »
I did find time today to drill down a bit more into the noise floor differences, have been working on a new psu so LISN time  :-/O
So I have broken down the results into what I feel are more meaningful segments.
First I set up the sweep from 0-150Mhz on each unit, both had been running for a few hours both on the same power conditioner outlets.
Then one from 0-3.2Ghz, then 3.2-6.5Ghz then 5.5-6.5Ghz at various RBW's
Cables are T-flex 405 18Ghz with quality crimped stainless matching bandwidth connectors.
Also an image of the set up so you can see both RSA working in the same environment.
Next post all of the screen images
Offline Sighound36
« Reply #132 on: May 26, 2020, 06:54:57 pm »
Below are the images I took earlier.
The psu improvements are also evident at the  lower end of the spectrum as well  8)
« Last Edit: May 26, 2020, 07:24:21 pm by Sighound36 »
The following users thanked this post: egonotto, 2N3055, mysol
Online tv84
  • Country: pt
« Reply #133 on: July 01, 2020, 08:59:11 pm »
It seems there is a new FW version for RSA3000E:
Link
Offline mysol
  • Country: ru
« Reply #134 on: July 16, 2020, 08:26:52 am »
Hm, the files inside tell it is old firmware....
Online tv84
  • Country: pt
« Reply #135 on: July 16, 2020, 08:30:43 am »
Which version?
Offline mysol
  • Country: ru
« Reply #136 on: July 18, 2020, 01:40:40 pm »
Which version?
The version of the file in the archive that you sent? Honestly, I didn't check after seeing the modify date.
1025918-0
Online tv84
  • Country: pt
« Reply #137 on: July 18, 2020, 02:11:54 pm »
What I wanted to know is the version showed in system info.
Offline mysol
  • Country: ru
Online tv84
  • Country: pt
« Reply #139 on: August 18, 2020, 02:08:39 pm »
New firmware v00.03.00.00.29:
[Model Supported] RSA5065,RSA5065-TG,RSA5065N
                                RSA5032,RSA5032-TG,RSA5032N
                                RSA3015N,RSA3030,RSA3030-TG,RSA3030N
                                RSA3045,RSA3045-TG,RSA3045N
[Latest Revision Date] 2020-07-16
[Updated Contents]
00.03.00
    - Add Vector Network Analyzer Application(VNA),
                   Only for N Mode.
Link.
The following users thanked this post: ralphrmartin
Offline mysol
  • Country: ru
« Reply #140 on: August 19, 2020, 07:33:54 pm »
I've tried to look some more information about this update. They've made only new app for VNA but for all versions of RSA3/5. What?)
Online tv84
  • Country: pt
« Reply #141 on: August 29, 2020, 07:36:26 pm »
RSA5000 Declassification & Performance Verification Guides.
RSA3000(-E) Performance Verification Guides.
« Last Edit: August 29, 2020, 08:17:39 pm by tv84 »
Offline rogersstuart
« Reply #142 on: January 17, 2021, 09:45:06 pm »
Is the RSA3015N in the same hardware series as the RSA3030 and "unlockable" to 6 GHz? I was reading and I see that tv84 did his magic on an RSA3015E and enabled 3 GHz. Looking at the list I can see that none of the E models have VNA capabilities or reach higher than 3 GHz but the N models do.
The following users thanked this post: tonykara
Online tv84
  • Country: pt
« Reply #143 on: January 17, 2021, 10:17:39 pm »
Until now I only saw a 3030 able to go to 5065. For all others, the 3 GHz is usually the limit (to which they are pre-calibrated). After that the noise floor is just not there (calibration and/or PCB components   :-//).
In this regard it seems the new realtime Siglent is more expandable.   ;)
Offline mysol
  • Country: ru
« Reply #144 on: January 23, 2021, 12:17:47 pm »
Can we get 3 GHz for 3015/3015E series and how?
Or at least unlock options...
« Last Edit: January 24, 2021, 08:21:00 am by mysol »
Offline Pitrsek
  • Country: cz
« Reply #145 on: February 04, 2021, 08:47:22 pm »
Anyone having experience with  RSA3015N?
Offline Dennis Frie
« Reply #146 on: February 09, 2021, 01:01:55 pm »
I just received a RSA3015N. I've not had much time to play with it yet, but so far I'm happy with it. I've normally been using a mix of SDR, a Rigol DSA analyzer and a R&S VNA- hopefully the RSA will be able to replace most of them for everyday use. It would have been nice with some kind of VSA option as the 3000E and RSA5000 series offers.
If you can live with the 1.5 GHz frequency-range and missing VSA option, it seems like a pretty good bang for the buck. I will keep my 6 GHz SDR for anything high-frequency and anything VSA-related though.
As a sidenote, calibration data shows that the unit is only calibrated to 1.5 Ghz.
Online tv84
  • Country: pt
« Reply #147 on: February 14, 2021, 11:47:16 am »
Another interesting random mistake:
RSA3015N running as RSA5032N
The following users thanked this post: Sparky, egonotto, KA3YAN, tonykara, AlexDavidson, Dennis Frie
Offline Sparky
« Reply #148 on: February 15, 2021, 06:00:01 am »
This is a very appealing mistake, because I think VSA option is not an option on RSA3000.  If one does not need to go beyond 3.2GHz, this is very pleasing!
 :-+ tv84!
The following users thanked this post: KA3YAN
Offline Dennis Frie
« Reply #149 on: February 15, 2021, 08:29:27 am »
 :-+ tv84!
Very neat mistake indeed...
It's interesting, that Rigol offers a VSA option (although only FSK/ASK, but much cheaper) for the E-series, but not for the RSA3000 series. Unfortunately, the E-series doesn't offer the 40 MHz bandwidth or VNA-option..
The RSA3015N mistake seems like the perfect combi.:)
