holdingL? 0x0301 /1000
No data, is this normal?
;; KP184: Tx <holdingL? 0x0301 /1000>
;; COM12: Tx: 01 03 03 01 00 04 15 8D
;; COM12: Rx: 01 03 04 00 00 00 01 3B F3
;; KP184: Rx Timeout
I missed you was using "holding?", i.e. without the L. If you try
holding? 0x0301 /1000
You will hopefully get the long answer, but with a Rx timeout because my special handling is in the holdingL? code.
I have uploaded a new version (1.74) where the 0x301 handling is in the holding? code.
I have also starting working on multiple divisors, but I have not tested any of it. If it works you can do:
holding? 0x0301 /1000 /1000 /3600000 /3600000
