V2.96 is up
A couple of new devices and some updated, I have also added a options to automatic sync scales
Added: Automatic sync of scale option
Fixed: List in "Load devices" is not case depend when sorting anymore.
Updated: Maynuo M97xx electronic load (Thanks Tjuurko)
Added: Eletechsup PT21A01, Eletechsup PT22B01 PT100 Thermometer (Thanks flash2b)
Added: East Tester ET3501, ET3502, ET3503, ET3505, ET3510 (Thanks Tjuurko)
Added: Eletechsup NT48A08, Eletechsup NT48B20, Eletechsup NT48C32 NTC Thermometer (Thanks flash2b)
Fixed: Add automatic adjustement to the min/max limits in the number control by a very small about, fixed some limit issues.
Added: Eletechsup NT38D01 (10k, 20k,50k and 100k), Eletechsup NT18B07, Eletechsup NT28B16 (10k, 20k,50k and 100k) NTC Thermometer (Thanks flash2b)
Updated: Owon LCR2020, LCR2100, LCR2200, LCR2300, Anbai AT3810A, AT3817A, AT3816A, AT3818, Applent AT3810A, AT3817A, AT3816A, AT3818 (Thanks Flash2b)
Update: Yokogawa DMM's definition has been updated (Thanks flash2b)
Updated: Agilent 34461A, Keysight 34461A, Keysight 34465A, Keysight 34470A (Thanks KungFuJosh)
Added: Keysight 34460A, , Agilent 34460A (Thanks KungFuJosh)
Updated: Keithley DMM6500, Keithley DAQ6510 and Keithley DMM7510 DMM (Thanks KungFuJosh)
The sync option is places at the bottom of the sync setup:
It has a little trick: It will only sync scales with same unit. This means scales must keep track of unit and previous they did not. To fix this either delete all the old scales or accept that auto sync may not work first time a scale is selected, but will work next time (Select scale, deselect it and select it again is enough).
