V3.00 is up
The main attraction is a automatic battery test, but there are a couple of new devices and some older devices that have been updated. Flash2b has done a lot, but he is not the only one.
Updated JSerialComm to v2.11.4
Modified: I have moved all automatic tests into a submenu in the popup menu.
Added: Eletechsup 10IOA01, 10IOA02, 10IOA04 and 10IOA08 relay modules (Thanks flash2b)
Added: Matrix APS-4000A, Matrix APS-4000B, Matrix APS-4000C, Matrix APS-7100, Matrix APS-7105, Matrix APS-7110, Matrix APS-7200, Matrix APS-7300, Matrix APS-7500 AC Supply in both ascii and hex versions (Thanks Benleentje)
Added: Riden RD6024, RD6030 and RD6012P power supplies (Thanks Tjuurko)
Update: Mastech, Tase, Tenma, UNI-T thermometers definitions now support #interface (Thanks flash2b)
Update: Yokogawa, Hameg, Analogic DMM's definitions now support #interface fully (Thanks flash2b)
Update: BSide I8 power supply (Thanks flash2b)
Update: eTommens definitions now support #interface fully (Thanks flash2b)
Update: Eletechsup definitions now support #interface fully (Thanks flash2b)
Modified: Test interface to better handle devices with more than 8 channels
Fixed: Right click to get a var name missed the . it is fixed now.
Added: Eletechsup N4IOA01 current source, Eletechsup N4DAC02 voltage source, Eletechsup N4DBA06 volt/current source (Thanks flash2b)
Fixed: Updated script language to support "Auto sync to left scale" in "Chart layout"
Fixed: Updated script language to support "Log sync" in "Param sweeper"
Battery test means TC can automatic test a LiIon battery and generate curves and CSV files:
