Author Topic: Program that can log/control many multimeters and other devices.  (Read 1662499 times)
Gertjan, flash2b, Benleentje and 146 Guests are viewing this topic.
Online flash2b
  • Everything I like about myself is better with you.
Re: Program that can log/control many multimeters and other devices.
« Reply #6050 on: March 19, 2026, 08:02:48 am »
Dear HKJ,
I have made a definition for the Eletechsup 10IOA01, 10IOA02, 10IOA04 and 10IOA08 relay modules supporting both Digital Input and Digital Output.
These are very nice relay modules built around the MindMotion MM32F0010A1T ARM Cortex M0 48MHz micro controller. The module uses high quality relays and other components. It is the second relay definition that is supported by TestController and it has been extensively tested both in TC as well as with the Battery Test popup.
(Attachment Link)
It supports both Digital Traces for the input and the output and has a setup menu. It supports setting the relation between input and output as well.
For all that want to use it, you need a USB RS485 adapter to connect this module. There are many available in different price brackets, like the ones I use (purple)  https://nl.aliexpress.com/item/1005010389167788.html and https://nl.aliexpress.com/item/1005008276085365.html The chipset does not matter as long as it works in the OS you are running TC on. These adapters work for all my Eletechsup definitions.
These one also look good: https://nl.aliexpress.com/item/1005007318074871.html , https://nl.aliexpress.com/item/1005008321643522.html and https://nl.aliexpress.com/item/1005008083676644.html
« Last Edit: March 19, 2026, 11:12:09 am by flash2b »
They say attention is a shovel. It's time to dig 'em out.
Online HKJTopic starter
    • Tests
« Reply #6051 on: March 19, 2026, 12:12:40 pm »
I have tried to be a bit more detailed about #interface definitions:
http://lygte-info.dk/project/TestControllerInterfaceDefinitions%20UK.html
I plan on linking to this from the current #interface explanation.
Comments welcome.
Online Benleentje
« Reply #6052 on: March 19, 2026, 12:25:45 pm »
I do not know for sure but you can just use #port <port number>. In the connected tab of TC you should use the address.
That it is Mobus_RTU over TCP/IP should not matter writing the definition commands.
For the TCP/Ip connection there can be a overhead with additional data. This is to indentify the unit in the network and says witch packet data it is. The overhead is 11 byte's and it sends the actual RTU command. Modbus rtu over TCP/ip will only send the RTU command.
Online flash2b
« Reply #6053 on: March 19, 2026, 12:55:59 pm »
Comments welcome.
This is a welcome addition to the documentation  :-+
I am working on a #interfaceType Power for an AC/DC Power meter which can output multiple values extra to the PS and ACPS. E.g. harmonics, powerfactor, frequency, efficiency etc.
Will that follow like PS and ACPS ?
Furthermore for #interfaceType LCR I written it wrongly for my Owon LCR2000 definition.
I propose something like this
#interfaceType LCR
#interface getMode
#interface getFrequency
#interface setMode
#interface setFrequency
#interface readValue 0 1 2
#interface readFrequency 3
May be adding an example will help like for a relay an actual definition is:
#interfaceType Relay Relay:2 Relay:3 Relay:4
#interface setRelays setOutput (value)
#interface getRelays setOutput?
#interface setRelay relayOutput(value?"on":"off") (channel)
#interface getRelay relayOutput? (channel)
You could also point to a definition that uses the #interfaceType instead of showing an example.
« Last Edit: March 19, 2026, 01:08:45 pm by flash2b »
    • Tests
« Reply #6054 on: March 19, 2026, 01:19:00 pm »
A power meter is for reading value, i.e. it is nothing like a power supply.
One issue with a power meter is that what output values is available is often a configuration command, this makes it very difficult to implement #interface for.
Some I would expect:
#interface readPower
#interface readVoltage
#interface readCurrent
But most other will depend on configuration, the above may also, but please lock that part of the setup so it always works.
In my power meter I have defined options for a few predefined setting and not made it possible to fully customize what it is reading (The definition is not published, because the protocol has changed and I have not updated my firmware).
#interfaceType LCR
#interface getMode
#interface setMode
Most LCR meters has two output values, not 3. The readFrequency is not really necessary.
I have some plans about changing the setMode/getMode working, basically require standard names to be used and then the definition must translate them to names used for the actual device. That would make setMode/getMode useful for device independent programming.
For that I need to make a programming command that can do the translation fairly simple, probable something like: translate(value,"VDC,V-DC","VAC,V_AC",...) i.e. pairs of TC and device names, and providing a reverse translate function would make it easy to do both ways.
I know example was for a DMM, but it also applies to LCR meters.
This is a good idea, but your definition is not the best example. It may be a well defined and working definition, but it is a bit on the complicated side to read with lot of sections.
Online flash2b
« Reply #6055 on: March 19, 2026, 01:35:27 pm »
You are right about the LCR meter output.
My Owon LC2020 has 2 value output + 2 optional value output, total 4 values if all are "On", but minimal always 2.
Yes sections make everything hard to read, but I am a meta master because of you ! (the Eletechsup NT48xxx is a beast !).
Should an ACPS and an (AC)Power not always have a get/set Frequency ?
« Last Edit: March 19, 2026, 01:46:11 pm by flash2b »
Online flash2b
« Reply #6056 on: March 19, 2026, 01:42:17 pm »
On the commercial relay support, are you happy with the Eletechsup 10IOAxx ??
I got some complaints that it is uses a RS485 and not RS232. There are also RS232 relays available, two channel but all use proprietary protocols.
I can take a look but I do not want to really invest money (and time) in another module. I bought the 4 channel one to have some more flexibility than the minimum 2 channel needed for the Battery Test popup.
    • Tests
« Reply #6057 on: March 19, 2026, 01:42:30 pm »
The idea is that interface makes it possible to make scripts and TC functions device independent and most LCR meters only have two values.
For a supply yes, for a measuring device no, a measuring device need a readFrequency, not a set/get.
In interface set/get is for configuration, read is for the actual value.
Online flash2b
« Reply #6058 on: March 19, 2026, 01:47:24 pm »
The readFrequency is, imho necessary since a setting a frequency, the LCR will round it to the closest it can deliver. Most LCR meter use steps and are not continuous.
    • Tests
« Reply #6059 on: March 19, 2026, 01:50:00 pm »
I am happy with your definition and the usb<->RS485 adapter is not very expensive.
I would not mind having RS232 based relays, but I will not ask you to do it, you already did a good relay definition.
One issue with RS232 today is that you have a couple of versions: 3.3V, 5V and real RS232 signal levels and they are not compatible. A relay for industrial applications would use real RS232, but cheaper version may use 3.3V or 5V interface or even implement USB serial directly on the board.
    • Tests
« Reply #6060 on: March 19, 2026, 01:52:09 pm »
I would expect reading the setting from the meter, would return the actual selected frequency, i.e. getFrequency
Online KungFuJosh
  • TEAS is real.
« Reply #6061 on: March 19, 2026, 01:58:26 pm »
I have a driver slowly in the works (available time depending) for Hioki IM35XX series LCR meters, and they also have 4 parameters in addition to the other measurement details like frequency (which I assume should be easy to get anyway).
My LCR is the IM3570 Impedence Analyzer, so frequency sweeps are no problem for me on the device. However, having more options in TC to do frequency sweeps including multiple parameters would be cooler than the 2 parameter limit in the analyzer mode on the device.
Thanks,
Josh
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Online flash2b
« Reply #6062 on: March 19, 2026, 02:01:04 pm »
#interface getFrequency should return the value the LCR meter is using indeed.
It is that I always add the setFrequency to the #askValues since I need it while logging for the graphs.
So yes you are right. But setFrequency != getFrequency for stepped LCR meters.
For the USB relay you mean these? https://nl.aliexpress.com/item/1005004782739576.html
Online flash2b
« Reply #6063 on: March 19, 2026, 02:07:06 pm »
Thanks,
Josh
You could use the Param sweeper with more that one parameter right?
For my Owon LCR2020 I only added frequency to support sweeping but I was planning to add bias voltage as well. TC could do both with the param sweeper.
« Last Edit: March 19, 2026, 02:08:52 pm by flash2b »
    • Tests
« Reply #6064 on: March 19, 2026, 02:08:35 pm »
You probably mean getFrequency, but it is not necessary, you can put a checkmark in the log box for each device in param sweeper.
Yes and the user of the script or popup may better be aware of that.
I did not mean any specific relays, but be careful, they may use HID.
    • Tests
« Reply #6065 on: March 19, 2026, 02:10:37 pm »
TC can sweep up to 3 parameters on param sweeper, but this can take a very long time!
Online flash2b
« Reply #6066 on: March 19, 2026, 02:21:45 pm »
You are right it is HID and controlled by https://github.com/darrylb123/usbrelay
Online Gertjan
« Reply #6067 on: March 19, 2026, 05:54:46 pm »
Ideal would be modules that do not need an additional interface. Usually the bench is cluttered enough :)
USB would be good. Ethernet would even be better, because we can do without additional virtual COM ports with their quirks.
Problem with RS485 is that people have to buy an additional interface, and have to learn about RS485. Which raises the barrier to start using these modules. So unfortunately less users....
While everybody using test equipment will have RS232 solutions at hand. And is (hopefully) experienced in setting up RS232.
regards, Gertjan.
    • Tests
« Reply #6068 on: March 19, 2026, 06:20:17 pm »
V3.00 is up
The main attraction is a automatic battery test, but there are a couple of new devices and some older devices that have been updated. Flash2b has done a lot, but he is not the only one.
   Updated JSerialComm to v2.11.4
   Modified: I have moved all automatic tests into a submenu in the popup menu.
   Added: Eletechsup 10IOA01, 10IOA02, 10IOA04 and 10IOA08 relay modules (Thanks flash2b)
   Added: Matrix APS-4000A, Matrix APS-4000B, Matrix APS-4000C, Matrix APS-7100, Matrix APS-7105, Matrix APS-7110, Matrix APS-7200, Matrix APS-7300, Matrix APS-7500 AC Supply in both ascii and hex versions (Thanks Benleentje)
   Added: Riden RD6024, RD6030 and RD6012P power supplies (Thanks Tjuurko)
   Update: Mastech, Tase, Tenma, UNI-T thermometers definitions now support #interface (Thanks flash2b)
   Update: Yokogawa, Hameg, Analogic DMM's definitions now support #interface fully (Thanks flash2b)
   Update: BSide I8 power supply (Thanks flash2b)
   Update: eTommens definitions now support #interface fully (Thanks flash2b)
   Update: Eletechsup definitions now support #interface fully (Thanks flash2b)
   Modified: Test interface to better handle devices with more than 8 channels
   Fixed: Right click to get a var name missed the . it is fixed now.
   Added: Eletechsup N4IOA01 current source, Eletechsup N4DAC02 voltage source, Eletechsup N4DBA06 volt/current source (Thanks flash2b)
   Fixed: Updated script language to support "Auto sync to left scale" in "Chart layout"
   Fixed: Updated script language to support "Log sync" in "Param sweeper"
Battery test means TC can automatic test a LiIon battery and generate curves and CSV files:
The following users thanked this post: croma641, Gertjan, Tjuurko
Online flash2b
« Reply #6069 on: March 19, 2026, 07:00:53 pm »
Congratulations with this milestone of V3.00 of TestController.
Thank you for all your support, HKJ !!
    • Tests
« Reply #6070 on: March 19, 2026, 07:08:33 pm »
It has been through a lot of versions over time, I have not skipped since I started the version numbers, many of them has only been test releases.
The reason for the release today was because I wanted the 3.00 version number and with your relay definition battery test can be used by everybody.
Online Benleentje
« Reply #6071 on: March 19, 2026, 07:43:32 pm »
Yesterday it took met 3 hour to connect a modbus tcp device to get in online. That was only talking to lantronix chip inside. Talking to the device itself is for tomorrow and needs more software.
So RS485 is not that difficult and ik think even easer dan RS232 with al his problems in settings and handshakes.
    • Tests
« Reply #6072 on: March 20, 2026, 05:20:22 pm »
I have been playing with the  Eletechsup NT18B07, but it is very slow!
Why not read all values in one go with:
holding? 0 7 /10
Online flash2b
« Reply #6073 on: March 20, 2026, 05:39:03 pm »
The NT48A08 is much, much, much better.
Currently it is
#scpiCmd readTempCH1? holding? 0x00
:readmath: binConv(int(value),0,2,1)
Please explain what you mean with holding? 0 7 /10
Do you mean 1 scpiCmd reading all values at the same time and then #askValues readAll ?
    • Tests
« Reply #6074 on: March 20, 2026, 05:42:15 pm »
Currently it is
Yes, the holding? commands can have a count as the second parameter, that means it can read a lot of registers at once.
Some devices support it, others do not and there might be a limit on how many can be read at once.
Only requirement is that they are in sequence,
That is basically the same as the holding command can have multiple values after it and they will be packed into one message.
