Author Topic: Program that can log/control many multimeters and other devices.  (Read 1774739 times)
0 Members and 30 Guests are viewing this topic.
Offline HKJTopic starter
    • Tests
Re: Program that can log/control many multimeters and other devices.
« Reply #6325 on: May 02, 2026, 04:34:19 pm »
Dear flash2b ,,, for some reason, if I enter any value other than "0,"  value is not accepted. If I enter 1 or 10, etc., the value looks like the screenshot.
I have not studied the definition, but:
I suppose the report interval is for programming the device to be used outside TC
The field is red because you have entered a value outside the legal range. TC will color a field red, if it do not conform to the requirements.
The following users thanked this post: 2X
Offline flash2b
  • Everything I like about myself is better with you.
« Reply #6326 on: May 02, 2026, 04:40:57 pm »
The report interval is for auto reporting. The device will sent values according to that interval. Keep it on 0 and use the Log interval of TC or use Current Values to get the maximum speed. If you put a value other that 0 it will delay logging.
They say attention is a shovel. It's time to dig 'em out.
Offline Gertjan
« Reply #6327 on: May 03, 2026, 06:22:01 am »
So maybe it is better to remove the "Report Interval" setting from the menu. Or restrict the values that can de entered to sensible values.
While creating menus, one always must take into account the ignorant, lazy and just plain stupid users....
Regards! Gertjan.
Offline homico
  • Country: ru
« Reply #6328 on: May 03, 2026, 06:57:15 pm »
Of course, I didn't go beyond the limits... These strange numbers appear after pressing the button. What's interesting is that they're always different and always exceed the limit. Well, I left it at "0" and everything works. However, it flashes quickly, it's annoying.
I wanted the readings to change once per second, but...
And yet, I won't use Eletechup. As it turns out, they're inaccurate! In the 25-100°C range, there's a large dip of almost 10°C in the middle. (My black window thermometer is calibrated and tested)
I've done numerous tests in water, as well as contact with copper with thermal insulation. I've also replaced the NTC elements and checked the temperature with several thermometers.
There's no doubt about it – the modules (2 pcs) are inaccurate. Perhaps I got defective ones, but how many should I buy...?!
« Last Edit: May 03, 2026, 07:04:39 pm by homico »
    • Tests
« Reply #6329 on: May 03, 2026, 07:27:36 pm »
That makes sense.
What TC does is send the message to change, then it probably sends a message to read the changed value, but because the device has transmitted a unsolicited message, TC believe that message to be a answer to its question about the value.
That do not sound good, generally with NTC sensors you have a table or a expression in the processor to convert the reading to a temperature, not any circuit.
The best way to test it is to find a resistance table for the NTC and then use a decade resistor to check it out.
Note: All 10K NTC's do not use the same resistance table.
Offline flash2b
« Reply #6330 on: May 04, 2026, 06:58:49 am »
I use mostly the NT48A08 and not the NT38D01. I have not encoutered this problem.
@homico
Could you tell me what is is your main processor on your NT38D01 board ?
Offline homico
  • Country: ru
« Reply #6331 on: May 04, 2026, 02:07:40 pm »
Purchased on Aliexpress from a supposedly official store.
Of course, I did the testing without growing the standard NTC. It was still in place.
« Last Edit: May 04, 2026, 02:30:58 pm by homico »
Offline flash2b
« Reply #6332 on: May 04, 2026, 05:19:22 pm »
Did you try: https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/msg6252871/#msg6252871 ?
Let me know the result, so I can fix the definition.
The chip marking FMD T4E JGKH is probably the Fremont Micro Devices FT60E121-RB.
What happened to PIN4 of you SOP8 ?
Does cleaning the solder side around the area of the NTC connector help ?
« Last Edit: May 04, 2026, 05:21:25 pm by flash2b »
Offline homico
  • Country: ru
« Reply #6333 on: May 05, 2026, 06:20:59 pm »
The printed circuit board is fine. As usual, it's a dirty solder from China. I cleaned it with 98% alcohol, but nothing changed.
« Last Edit: May 05, 2026, 06:25:04 pm by homico »
Offline homico
  • Country: ru
« Reply #6334 on: May 05, 2026, 06:33:40 pm »
I'm continuing my experiments. It might be because of the rapid heating. And the 38D01 module is lagging behind my module, which has a sensor on a DC18B20 chip.
    • Tests
« Reply #6335 on: May 07, 2026, 08:31:58 am »
V3.03 is up
A lot of devices has been added/updated and I have officially release the battery test function.
In addition to the above a new modbus interface has been added that allows multiple devices on a RS485 bus.
   Updated: GWInstek GPP-4323 Power supply, add support for different firmware versions (Thanks PL)
   Updated: ET5410A+ Electronic load (Thanks PL)
   Added: Tiny Devices tinySA4 spectrum analyzer (Thanks PL)
   Added: UNI-T UT622 LCR meter (Thanks PL);
   Added: A long overdue help page for GPIB+Modbus popup
   Added: B&K Precision 9130 power supply (Thanks janteau)
   Added: Support for multiple modbus devices on one serial port (Requires a slight modification to the device definition).
   Added: XY MD02 (AHT20), XY MD02 (SHT20), XY SHTC3 and XY MD02 (SHT40) Humidity & Temperature transmitter modules (Thanks flash2b)
   Added: LC Tech LCUS-1, LC Tech LCUS-2, LC Tech LCUS-4 and LC Tech LCUS-8 1 to 8 channel relay modules  (Thanks flash2b)
   Added: Eletechsup DM56A04 and Eletechsup DM36B06 4 to 6 digit readouts (Thanks flash2b)
   Added: Eletechsup DM18A01, Eletechsup DM18B02, Eletechsup DM18C04 and Eletechsup DM18D06 1 to 6 digit readouts (Thanks flash2b)
   Added: Ebyte EID051-133, Ebyte EID051-134, Ebyte EID051-135, Ebyte EID051-138, Ebyte EID051-143, Ebyte EID051-144, Ebyte EID051-145 and Ebyte EID051-148 3& 4 digit readouts (Thanks flash2b)
   Added: Ebyte EID041-G01 and EID041-G01S Humidity & Temperature transmitter module (Thanks flash2b)
   Updated: Giant Force GTH thermal chambers (Thanks jmurray)
   Added: Sorensen DHP 40-166 DC Power Supply (Thanks jmurray)
   Added: Rigol DM858 and Rigol DM858E DMM (Thanks FireDeveloper)
   Added: #removeMatch and #removeLineMatch makes it possible to do RegEx matches to remove sections and lines in #metadef
   Updated/added: ET5410A+, ET5420A+ electronic load (Thanks KungFuJosh)
   Updated: Batronix Magnova Oscilloscope (Thanks KungFuJosh)
   Updated: Added readTemperature to ATorchPX100Devices.txt as requested by CaptainBucko
   Updated: A lot of Eletechsup devices got faster (Thanks flash2b)
   Added: Circutor-CVM144 CVM Power analyzersM5-29 Three-phase power analyze (Thanks Benleentje)
   Added: BatteryTest popup, it controls up to 5 devices for doing a battery test with multiple discharge currents automatic.
No devices are updated to support the new modbus interface, to do that open the definition file and add modbus to the #port definitions, i.e.
#port com
must be changed to:
#port com modbus
And modbus selected in the type column of "Load devices". Press F1 on the GPIB+Modbus page for more help.
A warning: I have modified the code around GPIB, but have not tested it, i.e. it may not work anymore or it might work with multiple devices.
It is possible to download V3.00 from here: https://lygte-info.dk/pic/Projects/TestController/TestController3.00.zip (This is the old version, the new version must be downloaded from my website).
« Last Edit: May 07, 2026, 09:08:40 am by HKJ »
Offline flash2b
« Reply #6336 on: May 07, 2026, 09:48:03 am »
I will update all my definitions theat use  modbus RS485 to support the shared modbus function shortly.
New defintions I will release this month also, currenltly testing them.
    • Tests
« Reply #6337 on: May 07, 2026, 10:03:23 am »
I expected that, that is the reason I did not do it.
What I said about not modifying any drivers, it not complete true, the NT18B07 is updated, I did also remove the serial number, to get stable numbering of the 3 I have.
Offline flash2b
« Reply #6338 on: May 07, 2026, 12:46:41 pm »
I generally also update and/or improve my defintions as well. So some will also have enhancements.
Offline flash2b
« Reply #6339 on: May 07, 2026, 03:06:01 pm »
https://lygte-info.dk/pic/Projects/TestController/TestController.zip is still pointing to v3.00
Now points to the latest version !!  :box:
« Last Edit: May 08, 2026, 05:46:59 pm by flash2b »
    • Tests
« Reply #6340 on: May 07, 2026, 03:09:38 pm »
Sorry about that, it is fixed now.
Offline flash2b
« Reply #6341 on: May 07, 2026, 03:43:39 pm »
This definition has an error:
GWInstek GPD-3303S-II.txt
dk.hkj.devices.SetupFormats$IndicatorNumericField - Ch1CC - Line do not contain 3 parameters: Ch1CC 0
dk.hkj.devices.SetupFormats$IndicatorNumericField - Ch2CC - Line do not contain 3 parameters: Ch2CC 0
Fixed by adding
Ch1CC 0 gray
2 times in the file !!
« Last Edit: May 07, 2026, 03:52:46 pm by flash2b »
    • Tests
« Reply #6342 on: May 07, 2026, 03:52:43 pm »
Looking in the definition it is obvious.
I have added a random 3 parameter to the line (It is a color), that will have to do until somebody with the power supply updates it.
The update will first be included from next release or if somebody post a updated definition I will use that.
Offline flash2b
« Reply #6343 on: May 07, 2026, 03:55:12 pm »
Here you go
    • Tests
« Reply #6344 on: May 07, 2026, 03:59:14 pm »
Here you go
Thanks  :) :)
gray is probably a better color than I used.
Offline flash2b
« Reply #6345 on: May 07, 2026, 06:00:05 pm »
Also added some spaces for naming convention GW Instek on this one.
    • Tests
« Reply #6346 on: May 07, 2026, 06:08:14 pm »
Thanks, I have updated.
Offline homico
  • Country: ru
« Reply #6347 on: May 08, 2026, 04:52:44 pm »
How to find your website?
    • Tests
« Reply #6348 on: May 08, 2026, 04:56:59 pm »
https://lygte-info.dk/project/TestControllerIntro%20UK.html
The globe at the left can also be used.
Offline flash2b
« Reply #6349 on: May 08, 2026, 06:17:49 pm »
I've found a small bug  :o
If you change the device/handle (right click) from A to B, and then right cllck on the command line, the command list of the previously selected handle/device are shown. I have seen this bug before, so it is not since 3.03.
