I have update by Owon LCR2000 series (and Anbai/Applent variants) with 3 new tabs
Release notes:Added: Comparator tab: state, mode (Δ, Δ%, SEQ), nominal value, number of bins, secondary limits, AUX bin, beep and open check
Added: Bins tab: editor for the 9 comparator bins, with Send, Retrieve, Save and Load; the bins are retrieved automatically at connect
Added: #interface readFrequency, set/getFrequency, set/getVoltage, set/getCurrent and set/getBiasVoltage
Modified: Monitor 1 and 2 modes split over two lines, setup window is narrower
Modified: Trigger and Correction now use toggleButton controls, List tab got a separator below List Parameter
Modified: metadef token MaxFreq renamed to MAXFREQVAL, matching the TICKVAL naming
Modified: Configuration line uses MAXFREQVAL, shows DCR and Bias for all models except the AT810A
Fixed: typo in Automatic Level Control
Added: List tab: editor for the 10-point list sweep, with Send, Retrieve, Save and Load; the list is retrieved automatically at connect adapted from the Yokogawa 755x 756x v1.13 Program feature
Added: Device info control - model, ID string, interface type and address, read with the new deviceInfo? command
Modified: File Load, Save and Delete combined into one File Action row
Fixed: File load, save and delete always used file 0; the selected file number is now sent with each command
Fixed: Removed unneeded page names from :update: lines
I also defined a #interface for #interfaceType LCR since that is missing on the documentation.
Well this major update can now be added to the next release of TC.
Owon LCR2000.zip (11.97 kB - downloaded 15 times.)
