I got this BM4070 some years ago. I believe it is still available on several web shops.
This tester comes from an era when a linear potentiometer was needed to adjust for Zero (only for on Capacitor ranges).
It needs now calibration on the higher capacitance ranges, as the readings are far off to be trusted.
It uses trimmers for calibration. Just need to remove the back cover by undoing four screws.
The daughterboard PCB has nine trimmers labeled as follows:
VR1 200pF
VR3 20-200uF
VR4 2000uF
VR5 200uH
VR8 200uH-1
VR6 2mH
VR9 2mH-1
VR2 20mH-200mH
VR7 2-20H
I am waiting to get my new ZT-DQ02 LCR tester to have another tester to compare readings.
Meanwhile I opened it for inspection and took the opportunity to take pictures.
There are two PCB's. The main board with reference BM4070 REV:2.0 220106 (2022-JAN-06), and the daughterboard is BM4070x REV:2.1 211210 (2021-DEC-10).
Main board - Main components:
IC1 BLOB MCU - 44-PIN IC
IC2 14053BG 16-PIN MC14053B Triple SPDT Analog Multiplexers/Demultiplexers
IC3 TL062G 8-pin TL062G Dual Low Power JFET OpAmp
Q1 S8050 TO-92 S8050 NPN BJT 2W 1.5A 40V
Q3 J6 SOT-23 SMD S9014 NPN BJT 0.2W 0.1A 50V
Q4 2A SOT-23 SMD MMBT3906 PNP BJT 0.2W 0.2A 40V
D3-D7 M7 1N4007 1A 1000V Si DIODE
D8-D12 M7 1N4007 1A 1000V Si DIODE
R27 PTC 1500R
VR10 Zero Adj 1MR Linear Pot
Daughterboard - Main components:
IC4 072C 8-PIN TL072 Dual Low Noise FET OpAmp
IC5 072C 8-PIN TL072 Dual Low Noise FET OpAmp
IC6 4093BF 14-PIN CD4093BF Quad 2-Input NAND Schmitt Trigger
IC7 14066BG 14-PIN MC14066B Quad Analog Switch/Quad Multiplexer
IC8 OPA1612 8-PIN OPA1612 Dual High Performance Bipolar Audio OpAmp
The BM4070 runs on a 9V dry battery and consumes around 10mA independently of the selected scale.
A value too high for such a small battery imho.
