Author Topic: Recommendation Hand multimeter without rotary switch  (Read 6522 times)
Offline AlfonsTopic starter
« on: December 09, 2015, 03:04:47 pm »
Seeking a hand-multimeter, which is only to operate with tip-keys like a table multimeter, without the rotary switch, which is usually to be found. And there should be no ScopeMeter. Who can recommend something?
Offline Fungus
Re: Recommendation Hand multimeter without rotary switch
« Reply #1 on: December 09, 2015, 03:27:03 pm »
If you tell us the why we might know something even better...
« Reply #2 on: December 09, 2015, 03:39:49 pm »
Because it is better to use. For me the main reason to use a table multimeter, once is a better display, to others that they are better serving also. If I want to switch with my Fluke 187 VDC to ADC, I must not only change the strings, but cranks at this turning wheel. (The Fluke 187 is OK, no Problem). I just wanted to know if there is such a thing?
Offline Fungus
« Reply #3 on: December 09, 2015, 03:49:30 pm »
Offline Lightages
  • Canadian po
« Reply #4 on: December 09, 2015, 04:16:14 pm »
There are very few options:
http://www.chauvin-arnoux.com/en/produit/mtx-3283b.html
http://www.aliexpress.com/item/EONE-VC105-multimeter-completely-waterproof-push-button/1196741782.html
as a couple examples, from very high price to relatively low priced probably junk.
Any reason you don't want a bench meter?
« Reply #5 on: December 09, 2015, 05:29:01 pm »
Thanks!
Both, the old Fluke and the modern Metrix were familiar to me. The one is too old, the other too expensive. I had not much else found of good quality.
I had thought to replace my old HP Bench multimeter and to get me a second hand multimeter. I sometimes find it very convenient to set the unit as it fits best. With a bench meter on the shelf that's not always so simple and on the table they are too large. I do not have much space, thats the problem.
« Last Edit: December 09, 2015, 06:55:11 pm by Alfons »
Offline dom0
« Reply #6 on: December 09, 2015, 05:33:21 pm »
Keithley made some pretty small bench meters, 191 and 197 and maybe some others. There are some other smaller vintage bench meters by other manufacturers.
Offline robert_
« Reply #7 on: December 09, 2015, 06:08:10 pm »
Fluke 11/12?
« Reply #8 on: December 09, 2015, 06:53:21 pm »
It should have at least the class of Fluke 187.
I see, that it will be expensive to find something.  I am surprised, that hardly any manufacturer which produces like that. Is that so little demand? Is probably due to that the measured values change is not so easy to implement in a small package. In tough conditions, a rotary knob is already useful, but otherwise more of a hindrance. Then I'll stay at a bench-Multimeter, this is cheaper.
« Last Edit: December 09, 2015, 07:06:42 pm by Alfons »
Offline dom0
« Reply #9 on: December 09, 2015, 07:27:58 pm »
Can't really beat a piece of injection molded plastic and some gold plated spring contacts in terms of price, size and reliability in a hand held multimeter. On the other hand bench meters are expected to be fully programmable, so a solution like a rotary knob simply doesn't work for them.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #10 on: December 09, 2015, 11:49:38 pm »
A couple more options but I cant recommend either as I have not owned them nor do I know anybody that has.
