Author Topic: Rigol 832 - Network upgrade.  (Read 977 times)
Offline paulcaTopic starter
« on: September 09, 2026, 01:23:10 pm »
I looked into this this morning and having read a bit of the manual for said feature I am glad I did not purchase it.
£102.  £102.... I wouldn't pay £10.
It's barely a COM wrapper.  Basically command line.
What are they sniffing?  Siglent... for free give you a rather clunky, but useful "Full virtual scope" in a web-browser.  Rigol?  AT commands basically.
Offline _Wim_
Re: Rigol 832 - Network upgrade.
« Reply #1 on: September 20, 2026, 08:09:52 pm »
You also have Rigol Ultrapower. Certainly not great, but can be handy when you are not in the same room to remotely control a DP832...
Edit: downloadlink for ultrasigma & ultrapower: https://www.rigolna.com/support/software/?srsltid=AU7gw4Vr3V5bPYlLrfZqKZC-cv_VyfvRwZOcclbJ8CU0m1VTqG5Kkbw6
« Last Edit: September 20, 2026, 08:13:11 pm by _Wim_ »
Offline _Wim_
« Reply #2 on: September 20, 2026, 08:11:27 pm »
Also, you can just unlock all features of the DP832 for free making it a DP832A with color dislay and all.
« Reply #3 on: September 21, 2026, 07:38:47 am »
Yea.  That got changed.  Now you have to dump the firmware by hacking in via the USB port and run that key block through a haXzor tool you install on your PC.
I did try the old key file, none worked.
Offline J-R
« Reply #4 on: September 22, 2026, 04:29:14 am »
Has anyone else reported having the same issue unlocking it, or just you?
