UPDATE! UPDATE! i received a message stating that this model doesn't have a HELP button! but the model i recovered does in fact has this button located on the place where the QUICK button exists! My customer bought it directly from china it was one of the first units to be released, could this be a counterfeit unit? demo?
In this case I don't know if it will apply to other scopes without this key. Anyway I leave this post and my experience on this
I was able to revive a non working Rigol DHO814 from a
customer. This customer tried to hack this device and he told me when he was trying hack through adb there's a power failure when he was sending data. After that the scope stop working.
I tried other SD cards with different firmwares and no luck.
Symptoms: lights turn on, relays don't click, Rigol logo not displayed, fan working, nothing more work, no adb access.
I leave the original sd card on scope before I try the following:
Somehow I was able to enter booloader mode of the scope, but logo isn't displayed, I read on other post that logo is controlled by bootloader, but honestly i can't explain why it worked.
I tried entering bootloader mode 5 times, keep reading.
This is how I did it, if you have a broken scope you don't have nothing to loose, maybe it also work for you. The only negative point is that the Rigol logo stop being displayed!
1. I used a 16GB usb flash drive formatted in FAT16
2. Download the latest firmware file for the DHO814 from the official RIGOL website. Extract the GEL file from the zip and place it in the root directory of the USB drive.
3. Insert the USB drive into the USB HOST port on the front panel of the DHO814.
4. DHO814, From power off state, press and hold the HELP button and power it back on, and release the power button BUT don't release the HELP button until you see the led on the flash drive blinking, it must be continuous blinking, if it just blinks briefly and stops, it won't work!
I HAD TO REPEAT THIS 5 TIMES, i was almost quitting and suddenly it worked.
5. there's no information displayed on screen, when the flash drive led stops blinking, I waited another minute and then power off the scope.
6. I remove the usb-c power cable and the flash drive and wait a minute
7. i turn the scope on, nothing happened, but i decided to leave it on because i remember i recovered some smartphones waiting longer at the beginning and after around 1 minute the scope become alive and boot almost perfectly it took a total of around 3 minutes.
8. I rebooted the scope several times BUT The RIGOL LOGO is NOT displayed!
Calibration took around 45 minutes
My customer accepted the scope the way it is and took it back. At the moment of writing this text he didn't complain.
I hope this helps those who have similar problem and could recover you units, you have nothing to loose, just a little of your time.
