Lets start to discuss about DS1000z conversion to DS1000z -S. Can anyone tried to add signal generator daughter board?
Is it possible to flash DS1000z -S firmware to DS1000z osciloscope?
The firmware is the same - but where are you going to get the daughterboard from?
It's a little secret
I will reveal it someday, soon.
P.S. If the firmware is same on both DSO then why on DS1000z there is no Signal generator icons? Maybe it will appear after inserting daughterboard?
It's a little secret I will reveal it someday, soon.
Hey, you are the one who claims to have a source for the daughterboard -- you better figure it out...
Seriously though: You claim to have one part of the required solution, but are not telling us.
But at the same time, you expect the forum to help you with the other part of the solution?!
Ah, so you've made a daughterboard for it? Excellent! Don't leave us in suspense too long.
Finding a nice way to add the front source button might be the most challenging part...
Dremel...?
no need dremel or even the cheap dremel clone. just a paper cutter knife. the hole is already there nice and square.
The hole is easy, you still a button though that hopefully doesn't look too ugly.
still, a paper knife with some dried silicon is the key. the rest is time and perseverance.
Interesting!
i'm just wondering which to buy, Rigol DS1000Z or Siglent SDS1000X...
