Same results with mine. At 144.32 MHz, I get the spur about 10 kHz lower. At 144.33 MHz, the spur is about 15 kHz lower. And so forth, 144.34-->20 kHz, 144.35-->25 kHz.
OK, how about lower than 144.32. The spur is about 5 kHz lower at 144.31. But then something mysterious happens precisely at 144.3 MHz: the entire noise floor on the spectrum analyzer jumps up about 20-30 dB. At 144.29 MHz, it is back to normal. I was using an HP 8642B signal generator, which is pretty good, and I verified the same thing using a different signal generator, so it is definitely the DSA815-TG.
So whatever is causing the spur seems to be related to 144.3 MHz. Perhaps some internal clock?
