Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 714068 times)
0 Members and 14 Guests are viewing this topic.
Offline squishsquash
Re: RuiDeng Riden RD6006 DC power supply
« Reply #1425 on: May 22, 2026, 02:58:28 pm »
I have been reading the manual for the aftermarket firmware but it does not really point out the differences between the shippped firmware. Can someone point out like a top 10 best improvments over standard firmware please? I know I would appreciate it a lot, which means other noobs like myself would probably appreciate it. Giving us a good push to get it working and update :)
Thanks,
I just got a RD6018 for 58 dollars shipped, a month ago which seems like quite a good deal. I even had already purchased the lesser RD6006 but it cost 80$ and returned it when i noticed this random price drop only on that single model from banggood which i never use if I can help it. I also bought a very cheap Cisco power supply that is -54 volts and from my understanding I would still plug that into the negitive, it would just be cycling electrons in reverse from a positive rail but still is power and works the same. I have to say as a noobie ground and potential is kinda hard to grasp at first but then you just realize its a perspective only, the flow of energy is the same. I digress, have a great friday with a holiday all! :rant:
« Last Edit: May 22, 2026, 03:04:24 pm by squishsquash »
Offline bateau020
« Reply #1426 on: May 22, 2026, 04:14:00 pm »
you ask for the top 10. Since I don't know what features you like, and I don't know how far Riden has updated their firmware to be more like Unisoft's, the main recommendation is:
Try it out. You can go back to the original firmware if you want.
The main improvement subjects are:
* battery charging functionality many more possibilities, with a full extra menu
* better personnalisation of the display
* many more other settings available
* better ergonomics
* a calibration menu
Offline sofakng
« Reply #1427 on: May 22, 2026, 06:28:50 pm »
Hey guys, quick question...
I incorrectly used the red terminal for battery testing and I read that is wrong and can damage the power supply.  I did see some odd behavior after I did but it seems fine now.
Did I damage my unit or how can I tell?
Offline Vuonghp
  • Country: vn
« Reply #1428 on: May 25, 2026, 01:33:12 pm »
Tôi có thể tải bản cho rd 6018 ở đâu
Offline Vuonghp
  • Country: vn
« Reply #1430 on: May 25, 2026, 02:03:19 pm »
Tôi không tìm thấy phần mềm của Unisoft.tôi cần chỗ tải chíng xác.cảm ơn
Offline bateau020
« Reply #1431 on: May 25, 2026, 02:07:30 pm »
It's in the message, at the top. https://mega.nz/file/s1lHUTxJ#TMCqTGWBQ753QhjcnvQdSK52LZMYrijdSeJUzuhboNY
It's a zip file with all the mentioned firmwares for the various models.
The following users thanked this post: Vuonghp
Offline okw
  • Country: no
« Reply #1432 on: May 26, 2026, 03:22:21 pm »
Does anyone have the schematics for the RD6006? I accidentally connected a LiPo to black and red, instead of black and green posts. Now the output it always on (no matter the state of the ON/OFF button) and at full (maxed out, based on what the power supply feeds it). Any idea what could be damaged? A MOSFET that's shorted?
« Last Edit: May 26, 2026, 08:34:51 pm by okw »
Offline Atlan
  • Country: sk
« Reply #1433 on: May 26, 2026, 08:15:25 pm »
Fuse?
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline okw
  • Country: no
« Reply #1434 on: May 26, 2026, 08:35:41 pm »
Fuse?
Sorry, wrote wrong. It's always on, and at full (V).
« Reply #1435 on: June 10, 2026, 09:12:18 pm »
If you find the offical Riden youtube page they acutally have some great repair videos that cover the most common failure points that are build into the converter. Its usually as mentioned the fuse or the little protection board. If the unit is still working I would imagine you have a minor issue.
« Reply #1436 on: June 10, 2026, 09:13:40 pm »
Thanks bateau020, that is enough info for me to heavily consider using it. Appreciate it! ;D
⚠️ Critical Flashing Rule
Binary Match: You must flash the exact version (RD60181 for the RD6018) or it will glitch.
I made a list of the main reasons to upgrade to the opensource over the default firmware, see below:
1. Protection & Safety
New Protections: Adds UVP (under-voltage), UCP (under-current), and OTP (external temperature probe).Inrush Control: Adds ORP (over-resistance) to safely manage initial power surges.Motor/Capacitor Mode: ISET > OCP+200 setting allows 600ms bursts without tripping safety cutoffs.
2. Hardware Bug Fixes
TL594 Voltage Spike: Stock firmware has no workaround for the startup spike.Resistor Swap: UniSoft provides the exact fix (swap R22 for 68K-100K) for clean power-on sequences.
3. Advanced Battery Charging
NiMH / NiCd Support: Adds -ΔV/Δt detection (with filtering on "p" versions).Precise Cutoffs: Stops charging via temperature, capacity (0.001Ah steps), or time.Automation: AutoSelectMEMn loads your battery preset instantly upon connection.
4. Screen & UI Upgrades
Custom Layouts: Switch between 5 distinct layouts (choose from 15+ parameters).Mini Oscilloscope: Dedicated graphing mode with play, pause, autoscale, and timestamps.Visual Tweaks: Custom colors, 7-segment digit styles, and a smart screensaver.
5. Serial Control & ESP32 Integration
More Ports: Adds TTL UART and RS485 to easily connect an ESP32.No Lockouts: Skip keys lock lets you use the front buttons while remote control is active.
6. Smart Power Bench Automation
Boot Control: Dictate exactly how the unit wakes up (Boot Output, Boot MemCell).One-Switch Setup: Pairs with a Dell PSU switch to boot your entire bench into a known state.
« Last Edit: July 08, 2026, 06:39:02 pm by squishsquash »
Offline dougg
« Reply #1437 on: July 08, 2026, 06:44:28 pm »
Both my RD6018 and RD6006P were showing date-times starting in 2020, resetting each time they were powered cycled. So I checked the voltage on the CR1220 button batteries and they were both around 0.3 Volts (should be > 3 Volts). The battery is somewhat awkwardly placed on the lower PCB. Couldn't find a CR1220 replacement but CR1225 was available and it fits and works. My guess is lots of RD60xx power supplies bought early in their production cycles would also have the same flat button battery issue. Other than that, both power supplies are still working fine.
While I'm here, I'd like to send out a high voltage pulse, say 50 Volts to test the effectiveness of the protection diodes on a PD Sink.. The RD60xx supplies have a timer setup (well hidden following SHIFT-UP_ARROW) but its finest resolution is 1 second. Could it be less, say 10 or 100 milliSeconds? Does the ON transition overhead (e.g. its dV/dT) make such finer resolutions pointless? Alternatively could an accurate pulse from a function generator be sent to an existing header on the RD6006P PCB to obtain a similar result (i.e. pulsing the power supply output)?
Offline gregcrago
« Reply #1438 on: August 21, 2026, 01:42:30 pm »
Can I flash RD6012 firmware to a RD6012H? I dont see any RD6012H discussion on this forum. Someone posted link to video, but I am willing to test out a "-force" if I don't brick mu unit and can reflash back to OEM v1.40
Offline bateau020
« Reply #1439 on: August 21, 2026, 03:33:53 pm »
extremely probable that it will either brick or not work. Different hardware.
Offline UniSoft
  • Country: kz
« Reply #1440 on: August 21, 2026, 08:23:16 pm »
It is depends from what "Product Model" it have...
if you'll see there 60121 then you can flash it,
if there will be something else, then no need even try, it will not work.
Offline bateau020
« Reply #1441 on: August 21, 2026, 09:35:17 pm »
Offline gregcrago
« Reply #1442 on: August 25, 2026, 01:27:42 pm »
so rd6012h 'same hardware' and I will not brick it? You got me nervous.
Offline bateau020
« Reply #1443 on: August 25, 2026, 01:30:07 pm »
No, it is NOT the same hardware as the RD6012. The RD6012 has model 60121. The RD6012H has model 60126.
Applying firmware for RD6012 on a RD6012H will either not work or will brick it.
Offline gregcrago
« Reply #1444 on: August 25, 2026, 10:12:16 pm »
Can someone ask Douglas Gilbert to add RD6012H to the Unisoft firmware Document?
Offline bateau020
« Reply #1445 on: August 26, 2026, 05:45:51 am »
Well, since it is me who is doing most maintenance on that document, I can do it. But it'll be a mention that the 6012H, like many others: 6030, 6024,.. is not supported by the custom firmware.
These are the models that exist right now, with the firmware options:
RD6006
  model: 60061
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60061/RD60061.json
  Not compatible with Unisoft's custom firmware (China only model)
RD6006
  model: 60062
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60062/RD60062.json
  Unisoft's custom FW: https://mega.nz/file/s1lHUTxJ#TMCqTGWBQ753QhjcnvQdSK52LZMYrijdSeJUzuhboNY
RD6006P
  model: 60065
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60065/RD60065.json
RD6012
  model: 60121
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60121/RD60121.json
RD6012P
  model: 60125
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60125/RD60125.json
RD6012H
  model: 60126
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60126/RD60126.json
RD6018
  model: 60181
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60181/RD60181.json
RD6018P
  model: 60185
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60185/RD60185.json
RD6024
  model: 60241
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60241/RD60241.json
RD6030
  model: 60301
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RD60301/RD60301.json
« Last Edit: August 26, 2026, 07:38:22 am by bateau020 »
The following users thanked this post: Cliff Matthews, Pappson, washley, nmaas87
Offline gregcrago
« Reply #1446 on: August 26, 2026, 02:23:46 pm »
Thank you. Much more clear explanation. I did not understand that the firmware link was to the OEM firmware, not Unisoft
The following users thanked this post: 4lfre1re
Offline dougg
« Reply #1447 on: September 11, 2026, 04:49:10 pm »
Thank you for the maintenance clarification and the support list.
Offline bateau020
« Reply #1448 on: September 12, 2026, 03:00:53 pm »
haven't yet updated the document, but proposed a change to wildekek's site (https://github.com/wildekek/rdtech-firmware-unisoft), new proposed version is here: https://github.com/hb020/rdtech-firmware-unisoft/tree/main
Offline nmaas87
« Reply #1449 on: September 25, 2026, 12:52:34 pm »
Also:
RK6006
  model: 60066
  Riden FW: http://www.ruidengkeji.com/rdupdate/firmware/RK60066/RK60066.json
