So you don't consider that the SDS2000X 2 or 4 ch models having more than 3x the memory depth and more wfm/s than the GDS-2204E as worth anything ?
I think about it this way. The heart of the scope is ADC. ADC has certain sample rate. The more the sample rate, the more expensive ADC is, and the price grows exponentially. Faster sampling also requires faster and/or bigger FPGAs to accept all these samples. Siglent designed SDS2000X scope around an ADC with 1Gs/s sample rate. As we know, ADC requires low pass filter. For 1Gs/s sample rate, the required frequency of the fron end filter is somewhere around 300 MHz. What Siglent does for SDS2104X? They install bigger capacitors, so the filter is now 100 MHz instead of 300 MHz. What the customer can do:
1) Live with incorrect capacitors and have 100 MHz scope instead of 300 MHz.
2) Open it up and replace the capacitors with the correct values.
3) Pay $1,000 to Siglent so that they would install correct capacitors.
Siglent, of course, would think you should take option 2 (you void warranty) or 3 (you pay more), but here's the catch. Here's option 4:
4) Buy Instek GDS-2204E instead.
With Instek, you get only 500MS/s sample rate, but Siglent's 1GS/s isn't worth much with incorrect 100MHz front end filter. Why pay for the bigger ADC? Instek, on the other hand is a 200 MHz scope! Other than that, it comes down to slightly clumsier software and idiotic VXI-11 protocol vs more memory. 120k wfms/s is not that much different from 140k wfms /s. If either company sells the same amount of the scopes, Instek gets much more profit because their hardware is cheaper.
But. If not for the bad capacitors, Siglent would be a clear winner.
Screwing the front end filter the other way doesn't help neither. Here's a cheap 1GHz scope:
http://www.analogarts.com/products/usb-oscilloscope/sa985-1-ghz-bandwidth-oscilloscopeBut the sample rate is 125Ms/s
All this may have some historical meaning, but I predict that in the (near) future bandwidth is going to be determined by the sample rates, not by marketing schemes. And it means more bandwidth for the same money for the customers.
Of course it may not be true for bigger scopes. If a scope costs as much as a car (or a house), everything is different.
