Author Topic: Siglent 1052DL+  (Read 848 times)
Offline AdrianFuTopic starter
Siglent 1052DL+
« on: August 03, 2020, 03:22:01 am »
Recently I did a firmware update on my 1052 which then upgraded the model to a 1202(?). Not in front of the DSO right now. Not happy with it has it causes the DSO to run slow eg changing voltage level from say 1v/DIV to 10v/DIV can take up to a minute for anything to happen. Is it possible to back pedal back to the original firmware?
Adrian
Re: Siglent 1052DL+
« Reply #1 on: August 03, 2020, 03:29:25 am »
1202(?) ??  :-//
Never been such a model.
Where did you source the firmware from ?
SDS1000DL+ firmware page:
https://int.siglent.com/download/firmwares/?ProId=42
Re: Siglent 1052DL+
« Reply #2 on: August 03, 2020, 07:03:02 am »
I downloaded the firmware from that site. This is what happened after updating the firmware.
Adrian
Re: Siglent 1052DL+
« Reply #3 on: August 03, 2020, 07:04:29 am »
A better picture
Adrian
Re: Siglent 1052DL+
« Reply #4 on: August 03, 2020, 07:08:03 am »
A better picture
Adrian
WOW, a 200 MHz DL+ !  :o
I'll drop tech support a line for you.
Re: Siglent 1052DL+
« Reply #5 on: August 03, 2020, 08:03:16 am »
Thanks. Appreciated
Adrian
Online tv84
  • Country: pt
Re: Siglent 1052DL+
« Reply #6 on: August 03, 2020, 08:17:19 am »
If you want to downgrade the BW, send me a pm.
Re: Siglent 1052DL+
« Reply #7 on: August 04, 2020, 07:28:39 am »
All good thanks TV84. Now (hopefully) back to normal.
Should have asked the question about the firmware upgrade before I did it
Adrian
