Author Topic: Siglent SDS2000X Plus  (Read 747209 times)
arijav and 3 Guests are viewing this topic.
Offline miyagi
  • Country: jp
Re: Siglent SDS2000X Plus
« Reply #825 on: April 09, 2020, 02:45:10 am »
@twizla, tv84 is right, the hardware is the same. I measured rise time with Picosecond 4015D, it is exactly 650ps.  I also attached the frequency response plot, -3 dB point is roughly around 590MHz. If I have better attenuator and settings here, the result should be better, maybe can go up to 600-650 MHz.
Offline miyagi
  • Country: jp
« Reply #826 on: April 09, 2020, 03:07:05 am »
@ TK, yes keep a copy is better. So for whom would want to try this. Here is a simple guide to upgrade SDS2104X Plus to 500 MHz.
1) Create a .txt file and input 'telnetd'
2) Save this file as 'siglent_device_startup.sh' .  *** It must be this file name. And file format is .sh***
3) Copy file 'siglent_device_startup.sh' to the root directory of a USB drive.
4) Insert the USB drive to scope, and now turn on the power of scope. *** Must have the USB drive inserted before turn on the scope. And everytime you want to telnet to scope, you need to have the USB inserted before turn on it.***
5) After turn on scope with USB inserted, set scope LAN configuration as DHCP
6) Open a command window on PC, write 'telnet +IP address of your scope'
7) Now it requires user name and password.
   User name:   'root'
   Password: 'siglent_sds1000x_e'
8) After log in, write commands:
mount -o remount,rw,sync /usr/bin/siglent/firmdata0
rm /usr/bin/siglent/firmdata0/bandwidth.txt  *** or as TK suggested, you can use another command to have a copy of this file just in case**
The following users thanked this post: TK, zerto, stafil, chris009, jundar
Offline twizla
« Reply #827 on: April 09, 2020, 06:44:14 am »
Many thanks miyagi. I have measured exactly same values of 650ps and 600MHz. This is than the frontend bandwidth, with all low-pass elements disabled.
I dont know how implemented, likely a set of RC lowpass, they limit the BW steps 100/200/350MHz.
Offline miyagi
  • Country: jp
« Reply #828 on: April 09, 2020, 09:33:19 am »
You are welcome, twizla. I guess it's implemented in chips.
Offline pga23
« Reply #829 on: April 09, 2020, 11:18:28 am »
Maybe only probes are different?
I've bought SDS2104X Plus and I've four 200MHz probes, so I suppose it can be the only difference between 100MHz and 350/500MHz version.
Offline douggoldberg
« Reply #830 on: April 09, 2020, 12:46:42 pm »
Thank you so much my friend. Your instructions are perfect. As soon as mine shows up I will make this improvement. Do you know the correct .txt file to reference to turn on the other options?
« Last Edit: April 09, 2020, 03:58:59 pm by douggoldberg »
« Reply #831 on: April 10, 2020, 10:52:36 pm »
I received my scope today. Three days after ordering from Germany. Excellent service. Sadly Miyagi's update method did not work. I get a refused connection when I try to TELNET in with Putty. The scope can see the startup.sh file that has the telnetd but I dont think its reading it on startup. Any thoughts?
Offline TK
« Reply #832 on: April 10, 2020, 11:03:52 pm »
Are you using the full name siglent_device_startup.sh or just startup.sh?
« Reply #833 on: April 10, 2020, 11:13:00 pm »
I used the full name as specified by Miyagi. I can hit the scope via a web browser so i know its on my network and I have the correct IP.
Online Martin72
  • Testfield Technician
« Reply #834 on: April 10, 2020, 11:17:40 pm »
I would be glad to hear about your experiences with the scope itself, at the first time.  ;)
« Reply #835 on: April 10, 2020, 11:24:52 pm »
I played with it for a few hours. Its a very impressive instrument. Coming from a non-touch screen (1202X+) its a revelation. I love the touch control and its very responsive. Its going to take me a bit to get used to the menu structure though. I do need the I2S decoding as I do a lot of digital audio work. The FFT is actually better than I thought. I have a dedicated audio interface for analog signal capture (RTX 6001) that runs FFT's on the PC. Overall Im very happy I just want to get it all the goodies working ...
Online Martin72
« Reply #836 on: April 10, 2020, 11:33:00 pm »
"Problem" is, except the bandwith, you already have all the goodies in trial versions on board.  8)
« Reply #837 on: April 10, 2020, 11:38:32 pm »
Martin, Of course you are correct. The bandwidth is the big "prize".
Offline TK
« Reply #838 on: April 10, 2020, 11:41:47 pm »
It might not be opening standard port 23 for telnet.  @Miyagi, do you know the port number for telnet connection?
« Reply #839 on: April 10, 2020, 11:42:20 pm »
Anybody able to make Miyagi's technique work?
Offline TK
« Reply #840 on: April 10, 2020, 11:48:49 pm »
Try telnet to port 5024
« Reply #841 on: April 11, 2020, 12:18:09 am »
That got me right in no password. Hmm. Should I try the scripts now?
« Reply #842 on: April 11, 2020, 12:23:08 am »
tried his scripts, did not effect any change. Bummer.
« Reply #843 on: April 11, 2020, 12:30:49 am »
Looks like this port is SCPI interface. Well at least I know I can telnet it to that.
« Reply #844 on: April 11, 2020, 12:56:47 am »
Where's TV84 when you need him....
Offline TK
« Reply #845 on: April 11, 2020, 01:57:59 am »
I think TV84 is in Europe and probably sleeping at this moment
Offline TK
« Reply #846 on: April 11, 2020, 02:22:05 am »
You can try running nmap on your PC/laptop to check which ports are opened on the scope
Offline stafil
« Reply #847 on: April 11, 2020, 02:52:34 am »
What's your version? Maybe they closed the hole?
Are you using windows to create the file? Make sure that Windows doesn't add an extra file extension.
Offline miyagi
  • Country: jp
« Reply #848 on: April 11, 2020, 02:56:41 am »
The port number for telnet is 23. Be sure the siglent_device_startup.sh file content is telnetd.    The file must be in USB root directory, and USB should be inserted to scope, before turn on the scope.
Offline Back2Volts
« Reply #849 on: April 11, 2020, 03:25:47 am »
... I do need the I2S decoding as I do a lot of digital audio work.  ...
Can the four channels be used with the logic analyzer, without the special probe?
