Author Topic: Siglent SDS2000X Plus  (Read 749907 times)
Online tautechTopic starter
Re: Siglent SDS2000X Plus
« Reply #4000 on: March 19, 2023, 01:47:20 am »
I saw a joke earlier in this thread about screen protectors and bubbles. Just received my scope from Saelig and I removed the screen film installed at the factory that had a red tab and said remove before use. However, my screen seems to have another film installed on it and in this one I have bubbles.
Is there a second protective film that needs to be removed or do I have an issue with my screen?
See photos. Scope is brand new just opened.
Maybe 2 were installed by error.  :-//
There is matt glass underneath so at the edge of the display use a spudger tool or similar to get under the remaining film to remove it.
Avid Rabid Hobbyist.   Come visit us at EMEX Stand #1001 https://www.emex.co.nz/
Offline MarkusAJ
« Reply #4001 on: March 19, 2023, 02:26:16 am »
I received my in middle of 12/2022 and it had the same issue. At first I thought it’s defective display, but shortly I realized it’s 2nd layer.
I used toothpick to remove it.
« Last Edit: March 19, 2023, 02:50:17 am by MarkusAJ »
Offline TakeItApart
« Reply #4002 on: March 19, 2023, 06:05:07 am »
Thank you Martin72, tautech, and MarkusAJ for the replies. I’ll try to remove it.
Offline BillyO
« Reply #4003 on: March 19, 2023, 04:52:43 pm »
Hmm, mine had only one.  I suppose it's possible that 2 got put on there.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline plaisthos
« Reply #4004 on: March 29, 2023, 11:31:32 am »
I have one of these devices as well (SDS2104X Plus). But now it just stopped refusing to boot and just hangs after doing a bunch of self tests at the SIGLENT logo. (If you are curious, youtube video here: )
Is there any reset everything or safe boot, these devices support or should I just send it back for warranty?
Online 2N3055
  • Country: hr
« Reply #4005 on: March 29, 2023, 01:45:01 pm »
Shutdown the scope and on next boot keep pressing Math button quickly and persistently...
Offline plaisthos
« Reply #4006 on: March 29, 2023, 02:13:46 pm »
Thanks that helped! :)
« Reply #4007 on: March 29, 2023, 07:34:28 pm »
I've only heard of this with older firmware.
Please ensure firmware is up to date from here:
https://int.siglent.com/download/firmwares/?ProId=53
Offline rfspezi
« Reply #4008 on: April 03, 2023, 10:01:04 am »
When comparing the 10MHz output of my reference GPSDO to my SDS2042X Plus SDS2104X Plus, there is a significant frequency deviation.
Is there a way to "tune" the internal reference oscillator of the SDS2000X Plus (similar to the DAC-value for the VCO in a SDG2122X)?
« Last Edit: April 03, 2023, 08:06:13 pm by rfspezi »
Offline Martin72
  • Testfield Technician
« Reply #4009 on: April 03, 2023, 01:09:53 pm »
Pics please...
Can´t be said enogh.
Offline BillyO
« Reply #4010 on: April 03, 2023, 01:16:11 pm »
When comparing the 10MHz output of my reference GPSDO to my SDS2042X Plus, there is a significant frequency deviation.
Significant?  Mine is off by about 3Hz once warmed up.  What is significant?
Offline idolclub
« Reply #4011 on: April 03, 2023, 01:55:34 pm »
SDS2000X Plus Series Firmware Update:
Version: V1.5.2R3
2023-03-28
Release notes:
1. Fixed an issue on the production line
Version: V1.5.2R2
2022-12-22
Release notes:
1. Fixed a calibration bug only existing on Rev.G hardware (06-xx).
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X%20Plus_V1.5.2R3_EN.zip
Offline rfspezi
« Reply #4012 on: April 03, 2023, 03:46:41 pm »
It's off by about 1 Hz which for my applications is significant.
However... no matter how much off it is, the question is if there is a way to calibrate it or not.
Offline bdunham7
« Reply #4013 on: April 03, 2023, 05:19:50 pm »
SDS2042X Plus?  Are you mixing model numbers?  Assuming you are referring to an SDS2104X Plus or one of its siblings, is the discrepancy between your GPSDO and the output of the built-in AWG, the hardware frequency counter or the screen display frequency counter?  Or something else?  I'm not aware of any way to adjust any of those in any case and the scope does not have an external clock input.  I doubt any model without an external clock in will give you precision better than 0.1ppm.
Offline rfspezi
« Reply #4014 on: April 03, 2023, 08:27:26 pm »
Sorry, you are right... I mean the SDS2104X Plus - not the SDS2042X Plus.
I assume they use the same clock source for the scope and the AWG since both show the same deviation.
Offline BillyO
« Reply #4015 on: April 03, 2023, 08:29:22 pm »
So, if you feed the AWG into the scope 10MHz shows as 10MHZ right on?
Offline rfspezi
« Reply #4016 on: April 03, 2023, 08:39:10 pm »
Correct.
Offline BillyO
« Reply #4017 on: April 03, 2023, 08:52:36 pm »
Dave did a teardown here:
I don't see anything that is tweakable with a screwdriver.
Online 2N3055
  • Country: hr
« Reply #4018 on: April 03, 2023, 08:56:55 pm »
Correct.
If I may ask, what application is that?  That needs   better than 100ppb timebase accuracy on a scope?
The following users thanked this post: colorado.rob, Martin72
Offline bdunham7
« Reply #4019 on: April 04, 2023, 02:27:06 am »
Not likely to have a trimpot, but it may have a DAC/VCTCXO combo like the SDG2000 series that is used during initial setup and perhaps there is even a calibration routine for it that we just don't know about or have the commands for.  I doubt you could count on its mid-term stability to be better than 0.1ppm though, so I'm not sure how much closer you could get.
The following users thanked this post: BillyO
Offline rfspezi
« Reply #4020 on: April 04, 2023, 09:18:07 am »
Can somebody confirm that the lowest start/stop frequencies for Bode plots on the SDS2000X Plus series are:
Start = 10 Hz
Stop = 510 Hz
« Reply #4021 on: April 04, 2023, 09:37:46 am »
Start = 10 Hz
Stop = 510 Hz
Stop frequency = highest your AWG can provide up to 120 MHz max.
Offline rfspezi
« Reply #4022 on: April 04, 2023, 09:40:20 am »
The lowest possible frequencies, not the highest are in question.
« Reply #4023 on: April 04, 2023, 09:44:01 am »
Start = lowest.
Stop = highest.
This is used for Bode plot and analysers universally. Stop = highest.
What do you need to know ?
Start to Stop = a frequency sweep.
Edit to add:
From the datasheet:
Bode Plot
Frequency Mode: Linear, Logarithmic
Range: 10 Hz ~ 120 MHz
« Last Edit: April 04, 2023, 09:48:58 am by tautech »
Online 2N3055
  • Country: hr
« Reply #4024 on: April 04, 2023, 11:17:32 am »
Start = 10 Hz
Stop = 510 Hz
You can create scan from 10Hz to 510 Hz.
Actually, min span of scan is 500Hz.
So 10-510Hz or 2000-2500Hz etc..
You cannot create scan from 10Hz to 20Hz if that is what you need.
