Author Topic: Siglent SDS2000X Plus Hack  (Read 351364 times)
Offline Elasia
Re: Siglent SDS2000X Plus Hack
« Reply #25 on: June 02, 2020, 01:15:45 pm »
I'll open my 100Mhz base model and take pics of the front end you can use
Offline Elasia
« Reply #26 on: June 02, 2020, 08:13:57 pm »
The base model is the  same front end with the main board also with matching version codes / population
I did try to get to the other side as well but that proved to be a real pain in the ass so i changed my mind lol
Offline Martin72
« Reply #27 on: June 02, 2020, 08:17:42 pm »
Wasn´t a surprise for me as I got the 500Mhz hack on my sds2104X+...
Offline jemangedeslolos
« Reply #28 on: June 02, 2020, 08:35:04 pm »
They know they will sell a lot more 2104X Plus than 2204XPlus and nobody will buy a 2304X,its almost the same price than the SDS5034X.
Its simpler to have only one hardware.
Offline Frex
« Reply #29 on: June 03, 2020, 04:21:24 pm »
Mine (a 2104x-plus) stay as SDS2354X-plus (350MHz) when using 500M option key.
I tried again, but same... :-\
Frex
Offline Elasia
« Reply #30 on: June 03, 2020, 04:38:33 pm »
Frex
You might want to open it up and see if the board is the same rev / same population of parts.. been some debate about these odd cases
Offline stafil
« Reply #31 on: June 03, 2020, 06:19:13 pm »
Frex
Same here
Offline Martin72
« Reply #32 on: June 03, 2020, 07:39:55 pm »
Frex
Only what the annotation in the system info box concerns.
Offline tv84
  • Country: pt
« Reply #33 on: June 03, 2020, 08:59:32 pm »
I will solve that question next so that you can all get some sleep!   :)
The following users thanked this post: KeBeNe, Mr. Scram, Martin72
Offline Martin72
« Reply #34 on: June 03, 2020, 09:02:03 pm »
 ;D :-+
Offline Martin72
« Reply #35 on: June 06, 2020, 08:44:59 pm »
I was curious about the keygen in the first post and try it out just for fun ( my scope was unlocked "long" before), Input the scop id and press "Run".
And...
The keys are indentical to mine, nice thing.
May be nothing special to notice for others, but for me who didn´t have any knowledge in the programming/hacking things, it´s pure magic... ;D 8)
Offline tv84
  • Country: pt
« Reply #36 on: June 06, 2020, 08:49:47 pm »
It's basically Clarke's 3rd law in motion.   :-DD
"Any sufficiently advanced technology is indistinguishable from magic."
The following users thanked this post: KeBeNe, 2N3055, Martin72
Offline THD
« Reply #37 on: June 07, 2020, 12:06:40 pm »
Hi
Long time reader, first time poster.
I've just received an SDS2104X Plus and done the dance to "upgrade" it to 500MHz (Thanks to those responsible for the method!). I've also entered keys for all remaining functions. This has worked fine except for the option ending _FG. In the key gen there is no reference to FG but there is reference to AWG. It seems no matter which key I try I can't get the _FG function unlocked.
I'm sure it's obvious, but what am I missing ?
Thanks
Offline THD
« Reply #38 on: June 07, 2020, 12:54:16 pm »
I didn't make it clear, although I did mention it, I have tried the AWG key but it is rejected every time.
Offline THD
« Reply #39 on: June 07, 2020, 03:39:43 pm »
I've solved my AWG key entering issue. The key was valid, but was being rejected. So for anyone who may be having a similar issue :-
When you first enter the options page the option type is pre-populated with the _FG option.
Entering the key without touching anything else fails.
What I did in the end was open the drop down and re-select the _FG option, then enter the key.
That worked.
So it seems that even though the _FG option was pre-populated it wan't necessarily selected.
The following users thanked this post: Johnny B Good, Simon_RL
Offline Elasia
« Reply #40 on: June 07, 2020, 08:17:18 pm »
That worked.
Yeah this is a bug, i've seen it before now that you mention it so can confirm it
Offline Martin72
« Reply #41 on: June 07, 2020, 08:20:28 pm »
Hmmm…
Can´t remember that I got a problem with it.
Offline Martin72
« Reply #42 on: June 07, 2020, 08:31:01 pm »
Hmmm…
Maybe because of this.
Offline THD
« Reply #43 on: June 07, 2020, 08:48:54 pm »
I had definitely touched FG a couple of times and Key entry was still failing for me.
Offline stafil
« Reply #44 on: June 10, 2020, 04:02:28 am »
Does this work for SDS5000X ?
Offline Elasia
« Reply #45 on: June 10, 2020, 06:20:50 am »
If modded, but how much beyond model name? tv84 would most likely know
Offline Scott Holmes
« Reply #46 on: June 11, 2020, 10:02:15 pm »
Wasn't able to use the 500M option, but oddly all of the other codes worked without issue.  suggestions?
Offline Elasia
« Reply #47 on: June 11, 2020, 10:10:52 pm »
Fat finger?
You can try the SCPI command MCBD
« Reply #48 on: June 12, 2020, 12:57:56 am »
For whatever reason, I had to go 100M-> 200M ->350M ->500M.  Enter the bandwidth keys in that order.
Online EEVblog
« Reply #49 on: June 13, 2020, 02:41:14 am »
I believe I saw on one of the hack scripts it mentioned that it does.
