Author Topic: Siglent SSA3000X-R 5/7.5GHz Real-Time Spectrum Analyzer  (Read 15601 times)
Offline oeweanTopic starter
  • Country: no
    • Adroit.no
« on: December 18, 2019, 11:47:39 pm »
Exciting news
Siglent has released product information on their chinese website for a real-time spectrum analyzer with 5 and 7.5GHz range, 40MHz bandwidth.
https://www.siglent.com/products-overview/ssa3000xr/
It also looks like the SSA3000X Plus and SVA1000X series are getting 7.5GHz versions
I think 2020 is going to be a exciting year for Siglent :-)
« Last Edit: December 20, 2019, 09:22:14 pm by oewean »
Norwegian distributor of test and measurement equipment....
Adroit.no
The following users thanked this post: thm_w, BillB
Offline DaJMasta
    • medpants.com
Re: Siglent SSA3000X-R 5/7.5GHz Real-Time Spectrum Analyzer
« Reply #1 on: December 19, 2019, 12:20:03 am »
Really nice news to see, now the inexpensive SA players have broken into the higher bandwidths.  I hope they have a VNA version on the way too, even if only a single port like their current lower bandwidth offerings.
Looks like it's got 40MHz realtime bandwidth too!
Offline tautech
« Reply #2 on: December 19, 2019, 03:10:46 am »
Yes this new SSA3000X-R range is not to be confused with the recently updated SSA3000X Plus range which will have only a 7.5 GHz version coming early-mid 2020 to add to the existing 2.1 and 3.2 GHz versions.
Avid Rabid Hobbyist
Offline srce
« Reply #3 on: December 19, 2019, 09:27:51 am »
Looks pretty interesting. Slightly worse phase noise than the Rigol and no IF output though. More expensive too, possibly? (although I guess it depends on what options are included and how they are priced).
These two making a mockery of the Keysight and R&S pricing though.
Offline tv84
  • Country: pt
Offline srce
« Reply #5 on: December 19, 2019, 02:14:13 pm »
No analog AM/FM demodulation on the Rigol? That's a surprise.
Offline tautech
« Reply #6 on: December 20, 2019, 03:11:44 am »
Chinese website confirmation a 7.5 GHz SVA1075X is coming too:
https://www.siglent.com/products-overview/sva1000x/
Avid Rabid Hobbyist
Offline jadew
« Reply #7 on: December 20, 2019, 03:17:46 am »
That's pretty neat, but a bit pricey I think. Lower end model retails at $3k?
Offline tautech
« Reply #8 on: December 20, 2019, 03:20:30 am »
1.5 GHz SVA1015X $ 1995
Avid Rabid Hobbyist
Offline 0culus
« Reply #9 on: December 20, 2019, 03:22:07 am »
Comparison to Rigol RSA5065
Where? All I see is a table comparing it to offerings from Keysight, Tektronix, and R&S, which must be a joke. All three are orders of magnitude more expensive and in a totally different class.
Offline srce
« Reply #10 on: December 20, 2019, 07:22:46 am »
They've changed it. It was there yesterday. However, that's Keysight's lowest benchtop model that supports Real Time analysis, so seems like a reasonable comparison.  Without all the options enabled, its not that different. E.G. frequency range can be just 10MHz to to 3GHz. DANL is worse (-164) without NFE option. But even with just the basic options, you need to spend 5 times as much to get RTSA. I don't know why they require you to have the 80MHz b/w option before supporting RTSA.
« Last Edit: December 20, 2019, 06:13:13 pm by srce »
Offline tv84
  • Country: pt
« Reply #11 on: December 20, 2019, 11:35:33 am »
They replaced the Rigol in the comparison table.   :-//
...but Google is our friend.
Offline simone.pignatti
« Reply #12 on: December 20, 2019, 04:35:17 pm »
To summarize this should be the SIGLENT 2020 spectrum analyzers line up:
SIGLENT SSA3050X-R, spectrum analyzer 9kHz - 5GHz with up to 40MHz real time analysis bandwidth
SIGLENT SSA3075X-R, spectrum analyzer 9kHz - 7.5GHz with up to 40MHz real time analysis bandwidth
SIGLENT SVA1015X, spectrum analyzer 9kHz - 1.5GHz with S11 and S21 single port vector network analyzer
SIGLENT SVA1032X, spectrum analyzer 9kHz - 3.2GHz with S11 and S21 single port vector network analyzer
SIGLENT SVA1075X, spectrum analyzer 9kHz - 7.5GHz with S11 and S21 single port vector network analyzer
SIGLENT SSA3021X PLUS, spectrum analyzer 9kHz - 2.1GHz
SIGLENT SSA3032X PLUS, spectrum analyzer 9kHz - 3.2GHz
SIGLENT SSA3075X PLUS, spectrum analyzer 9kHz - 7.5GHz
SIGLENT SSA3021X, spectrum analyzer 9kHz - 2.1GHz
SIGLENT SSA3032X, spectrum analyzer 9kHz - 3.2GHz
Technical Support
Online tggzzz
« Reply #13 on: December 20, 2019, 05:22:38 pm »
Siglent has released product information on their chinese website for a real-time spectrum analyzer with 5 and 7.5GHz bandwith
That would have been stunning, if it had been the case.
They have a bandwidth of 40MHz, and a frequency range up to 7.5GHz.
  • Country: no
    • Adroit.no
« Reply #14 on: December 20, 2019, 09:21:20 pm »
Sorry for the miscommunication, a bandwidth of 7.5 GHz would be more than stunning  :)
Will edit the text.
Adroit.no
Offline rf-loop
« Reply #15 on: December 21, 2019, 10:21:37 am »
I do not remember any case that Rigol have published this kind of comparison table where they compare any their own product with Siglent product. So, why Siglent need compare they products with Rigol. Is Rigol some kind of "reference" level for Siglent. No.
Much better ones need be "reference" just as is also with audiophiles, reference quality speakers or amplifiers and then compare all others to these. So...
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline tv84
  • Country: pt
« Reply #16 on: December 21, 2019, 10:58:52 am »
For a certain period (while Siglent didnt have the equipment ready) it was and the proof is their own table.
I would say that they even used Rigol's parameters as an objective to equal or add a little more. The series params are striking similar.
« Reply #17 on: December 21, 2019, 01:22:51 pm »
Technical Support
Offline tv84
  • Country: pt
« Reply #18 on: December 21, 2019, 01:37:42 pm »
I made the line up table, will add more details over the time
https://docs.google.com/spreadsheets/d/1BCe9j2sFGA9krmXgSYCdvsX91E3v2_LXLjGxaZi36aI/edit?usp=sharing
Nice. Why not VNA in X-R series? Just a marketing strategy, right?
Offline srce
« Reply #19 on: February 26, 2020, 11:22:08 am »
Any idea when these (SSA3050X-R) are going to be available in Europe?
Offline colorado.rob
« Reply #20 on: February 26, 2020, 04:56:05 pm »
Do any vector signal analyzers have the capability to do symbol mapping and output the symbol/bitstream in real time?
Offline tautech
« Reply #21 on: February 26, 2020, 08:39:52 pm »
As in IQ demodulation ?
Yes the SSA X-R, SSA Plus and SVA models can do this.
SVA:
The Signal Path video stopped at the start of IQ demodulation:
https://youtu.be/ToVJTKCyIU8?t=2660
I'll ask the factory for a projected release date.
Avid Rabid Hobbyist
Offline tautech
« Reply #22 on: February 27, 2020, 01:25:49 am »
Apparently in just a couple of weeks however I cannot say which distributors will get to stock them first.
Avid Rabid Hobbyist
The following users thanked this post: srce
« Reply #23 on: February 27, 2020, 03:38:21 am »
SVA:
Hi Rob,  I am looking for a VSA that can output the bitstream so that it can be consumed by other instruments.  I see the data on screen in the video.  A number of VSAs have that ability.  But I would like to output that demodulated bitstream from the instrument in real time, either via a dedicated TTL port, or via LXI.  I looked at the programming manual and it was not apparent how to get at the demodulated data.
Offline tautech
« Reply #24 on: February 27, 2020, 03:56:10 am »
SVA:
Yes we only have limited I/O's to get data out so it must be from USB or LAN and maybe there will be a new SCPI command set when these new models are released. IDK.
But I know 2 beta testers that maybe can take this up with the product managers to see how this might be accomplished however maybe not in real time.  :(
Avid Rabid Hobbyist
