Author Topic: Siglent Technical Support join in EEVblog  (Read 737220 times)
Offline KungFuJosh
  • TEAS is real.
Re: Siglent Technical Support join in EEVblog
« Reply #1675 on: August 12, 2025, 08:07:46 pm »
Their layout isn't great. Shrinking the size of the waveform graphic and making room for bigger text makes much sense that making it hard to read.
Best Continuity Tester Ever
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #1676 on: August 13, 2025, 09:12:39 am »
exactly my point, we the customers have the power,
if we all write to our support departments and complain about this new fw release,
if we stop purchase items with tiny fonts,
if we only purchase items with good readable fonts,
we will very fast get it exactly like we want and need it to be.
Radioamateur call sign OZ2CPU, Thomas Scherrer, Senior EE at Prevas, EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline Sorama
« Reply #1677 on: August 13, 2025, 10:07:40 am »
Not buying a specific device from a specific manufacturer  because of the used font… I don’t see it happen (as in: there is probably no alternative technically or financially).
Wish you luck in forcing a manufacturer to change just that.
Btw: I have Siglent gear too.
The following users thanked this post: oz2cpu
Offline oz2cpu
« Reply #1678 on: August 13, 2025, 10:40:22 am »
Sorama, that is my point, no one care about only me,
but if we all.. did the same thing, we would get it exactly like we want,
but you are right, that is not going to happen
Offline tautech
« Reply #1679 on: August 13, 2025, 10:40:53 am »
WOW thanks, i love to see the frequency change smoother too,
but i got old vintage analog stuff for when that is important, I upgrade ASAP and repport back,
and a huge thanks once again
The latest FW update was announced back in March so if you have this model I advise you contribute to the SDG6000X thread to get notification of new posts:
https://www.eevblog.com/forum/testgear/siglent-sdg6000-series-awg_s/msg5852057/#msg5852057
Offline Sorama
« Reply #1680 on: August 13, 2025, 11:25:44 am »
Power to the people  :box:
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #1681 on: August 13, 2025, 03:31:06 pm »
As someone who has worked for two of the biggest T&M instrument manufacturers - the user interface / user experience definitely matters.  Customers absolutely make purchase decisions based on usability.
Most often any "improvements" to the user interface come in the next revision of a product, not changing the GUI of a current product.  For ever customer who wants a change in the GUI, there is at least one other who wants the GUI to stay just the way it is.
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: Performa01
Offline KungFuJosh
  • TEAS is real.
« Reply #1682 on: August 13, 2025, 03:41:10 pm »
That's why things like font size should be an option the user can control. ;)
The following users thanked this post: Performa01, pdenisowski
Offline Sorama
« Reply #1683 on: August 13, 2025, 03:42:16 pm »
That's is exactly my point.
UI is very important/personal (one of the reasons I will never buy Rigol), but sometimes the budget will not allow you to shop somewhere else, so you're stuck to that particular UI of that particular device or brand you don't really like.
And the UI does not often get modified wrt customer wishes.
The following users thanked this post: pdenisowski
Offline KungFuJosh
  • TEAS is real.
« Reply #1684 on: August 13, 2025, 04:23:25 pm »
Siglent is usually pretty good about that, though they clearly went the wrong direction this time.
When I was messing with the SDS5000X, I flashed like 7 years worth of firmware in order. You can clearly see how unpolished the old firmware was, and how well they gradually adapted it after that.
Offline Sorama
« Reply #1685 on: August 13, 2025, 04:27:54 pm »
I would say: of course they do. Why wouldn’t they.
But not at a single demand of some customer.
But I have seen too many devices with bad UI that never got changed.
Offline oz2cpu
« Reply #1686 on: August 13, 2025, 04:55:55 pm »
exactly.. so please folks, start writing a polite and friendly phrased email to your favorite siglent support / sales departmens
do it all of you,.., this week ...
lets change the world to be better place, together  ..
I promise to release a new YT video ASAP this is fixed where i explain how happy i am
Online Mahagam
« Reply #1687 on: August 13, 2025, 09:15:50 pm »
Is it possible not to overload engineers with the not-so-important work of changing fonts and rounding the corners of icons? Maybe it's worth fixing existing bugs first?
For example, in the SDM3055 it is impossible to use a bargraph - the screen simply slows down mercilessly. In fast mode, sampling takes place at completely random time intervals.
SDG2042X - is it possible to make it so that when the frequency changes, there would be no phase discontinuity? (This happens even if the channels are independent)
SDS2104X+ - Axis mode "fixed" cannot be used when zoom is turned on
It's better to fix these annoying bugs first, and then get back to playing with fonts.
Offline oz2cpu
« Reply #1688 on: August 14, 2025, 07:20:59 am »
exactly Mahagam but They started, to waste time on making the fonts tiny and hard to read,
no one asked them to waste time on this.. Much better they should have spend time to fix bugs before anything else.
That is why it hurts even more to see this..
by the way
all signal generators from siglent have a signal level, frequency or phase spike, cut or drop,
when you dial the knob, it is not a smooth change like old vintage analog equipment,
it is a rather ignoring thing, if you see your self in the middle of an audio amplifier repair job.
Offline 2N3055
  • Country: hr
« Reply #1689 on: August 14, 2025, 08:22:15 am »
by the way
Nobody wasted time on making fonts smaller for no reason.
Like I said before, you are showing only basic channel screen. There are other screens where stuff didn't fit anymore, and having to switch through dozens of secondary screens to set single function is no fun either.
It was a decision from necessity.
I have bad eyesight and would preferer to use an AWG with 10" screen personally... Except no such thing....
Engineering is an art of compromise.
Dr. Richard W. Hamming
Offline tautech
« Reply #1690 on: August 14, 2025, 08:39:31 am »
by the way
Maybe the SDG3000X 7" display will be the answer to your dreams....
Offline oz2cpu
« Reply #1691 on: August 14, 2025, 08:50:38 am »
only if it comes in light gray, almost white
as all the other equipment we have and love so much
please dont tell us you go over to all items in black only like the others ?
it is terrible
Offline KungFuJosh
  • TEAS is real.
« Reply #1692 on: August 14, 2025, 03:51:15 pm »
Siglent has a new accessory to help with the font size; only $7000!  :-DD
Offline oz2cpu
« Reply #1693 on: August 14, 2025, 04:54:33 pm »
i need one.. amazon ?
Offline KungFuJosh
  • TEAS is real.
« Reply #1694 on: August 14, 2025, 09:11:36 pm »
Yup. About $56 right now with their magic coupon: https://www.amazon.com/dp/B0DNS9R2Q1
So I guess it would probably only be $5600 from a scope dealer. ;)
Offline pdenisowski
« Reply #1695 on: August 15, 2025, 10:48:17 am »
Regarding the "small fonts" issue:  when I was visiting customers in China a number of years ago, I was struck by the age distribution of the engineers in their labs.  In my experience, the age distribution of engineers in most US / European labs mostly follows the general population, but in China almost every lab I went to had a distribution that was very skewed towards young (20s) engineers.
I didn't think about it at the time, but perhaps this is - to some extent - responsible for the "small fonts" issue:  many younger people (my younger self included) often don't understand the issues that older people have with smaller text.
In fairness though: there are a lot of companies / products with fonts that are almost unreadable once one is past a certain age.
The following users thanked this post: Performa01, TUMEMBER, KungFuJosh, oz2cpu, awakephd
Offline oz2cpu
« Reply #1696 on: August 15, 2025, 10:54:07 am »
EXACTLY
and that is why my suggestion :
lets make fonts as big as possible on each screen, to make most people, most happy,
stuff is just more user friendly the bigger the fonts can be
Offline 2N3055
  • Country: hr
« Reply #1697 on: August 15, 2025, 11:13:53 am »
EXACTLY
We can also make only single parameter with 72 font size per screen and 12342 different screens to setup a device. That is also not a solution...
Siglent was made aware of your opinion. They respect your honesty and will look into it.
If there is some optimization possible they will see what can be done.
If not, they won't. They are engineers, not magicians.
There is only so much stuff you can fit on 95mmx55mm screen.
That is less than half the size of my smallish smartphone that is 155x72mm.
Offline KungFuJosh
  • TEAS is real.
« Reply #1698 on: August 15, 2025, 03:07:24 pm »
No magic needed if they make better use of space.
Modified:
Original:
Thanks,
Josh
« Last Edit: August 15, 2025, 03:09:09 pm by KungFuJosh »
Offline oz2cpu
« Reply #1699 on: August 15, 2025, 03:14:32 pm »
you could have done it even better
see here..
