Author Topic: Siglent Technical Support join in EEVblog  (Read 825754 times)
0 Members and 161 Guests are viewing this topic.
Siglent America
  • Guest
Re: Siglent Technical Support join in EEVblog
« Reply #350 on: January 14, 2015, 06:54:24 pm »
There is a 1.5/1.8 GHz model and a 3 GHz model. The unit I saw had a tracking generator and the EMC tools. I don't know if they are standard or optional. It was a really nice looking unit. We showed the 3 GHz version at Electronica. Specs should be better than comparable products in this price range. I believe the display is larger.
That's all I can say at this point. I hope to learn more at DesignCon.
Offline Rene
« Reply #351 on: January 22, 2015, 06:59:22 am »
Dumb question.....
Is the 50 ohms output impedance on the SDG1025 function generator always present even if I setup the Load parameter to be equal to "High-Z"?
My guess is that the answer is yes but just wanted to triple check. I assume that there is some kind of a physical 50 ohms resistor welded right before the BNC output connector so it is always there no matter what parameter you set in the function generator.
Could someone verify this for me?
Thanks.
Offline tautech
« Reply #352 on: January 22, 2015, 08:50:47 am »
Dumb question.....
Thanks.
I did wonder if you where dumb, then I thought it is a good question.
But I don't know.  :palm:
Have a scour through the links on the https://www.eevblog.com/forum/testgear/the-sdg1000-and-sdg800-thread/msg579096/#msg579096 thread.
Check the teardowns and this link:http://sigrok.org/wiki/Siglent_SDG1010
Thought this might show it but no.
You might have to do a teardown yourself for the answer.  :P
Avid Rabid Hobbyist
Offline rf-loop
« Reply #353 on: January 22, 2015, 09:24:28 am »
Dumb question.....
Simple answer. Yes. Output internal impedance is 50ohm INDEPENDENT of what value you set for LOAD impedance what setting affect only for displayed V level so that you need not yourself calculate it. Adjustment is NOT for adjust internal impedance. Adjustment tell to SDG what is your LOAD impedance. If your LOAD impedance set is right, only  then SDG display can show right Voltage level.
Inside  is "zero impedance" source -- internal impedance 50 ohm ---BNC out --- your LOAD impedance --|
>---Ri--OUT--Rload---GND
Example:
If you set HI-Z as load setting... and your SDG V level show 10V. You connect 50ohm load to output. Your level over your load is 5V.  (source voltage 10V and series 50ohm Ri and 50ohm Rload)
If you set HI-Z  as load setting... and your SDG V level show 10V You connect 1Mohm load to output. Your level over your load is around ~10V (source voltage 10V and series 50ohm Ri and 1Mohm Rload)
If you set 50ohm as load setting... and your SDG V level show 10V. You connect 50ohm load to output. Your level for your load is 10V.  (source voltage 20V and series 50ohm Ri and 50ohm Rload)
If you set 50ohm as load setting... and your SDG V level show 10V. You connect 1Mohm load to output. Your level for your load is ~20V.  (source voltage 20V and series 50ohm Ri and 50ohm Rload)
(it is also in data sheet and it is in manual)
EV of course. Cars with smoke exhaust pipes - go to museum.
Offline Rene
« Reply #354 on: January 22, 2015, 08:56:02 pm »
Guys, thank you for helping me out with my question.
Before posting, I did run some experiments and I also concluded that the 50 ohms resistor was being used regardless of the Load setting chosen (50 ohms or High-Z). The problem with those tests is that they were not really conclusive (at least I think they were not conclusive).
For example, lets say that this particular function generator had two transmission lines leading up to the BNC output connector, one with a 50 ohms resistor in series and the other without the resistor. Because of this physical design, this would mean that it may be possible via some software setting (on the current or some future version of the software) to actually bypass the transmission line with the 50 ohms resistor.... Yes, i realize that my example is a dumb example but I am new to all this and right now I feel like a hormone raging teenager checking out their very first porn magazine, my mind is going all over the place!
So anyway, what I wanted to verify was that it was physically impossible to skip the 50 ohms resistor due to the hardware design. in other words, there is only one transmission line leading up to the output and such transmission line has a 50 ohms resistor welded in series on it so it is impossible to bypass the resistor via software. Based on the replies, this appears to be the case.
Thanks.
« Last Edit: January 22, 2015, 08:59:02 pm by Rene »
Offline IvoS
« Reply #355 on: January 22, 2015, 09:08:55 pm »
I have a warranty question. I want to buy a new SDG5082 generator. Will I still get 3year warranty coverage even though I buy from overseas or someone from eBay?
Thanks.
Offline tautech
« Reply #356 on: January 22, 2015, 09:15:18 pm »
Thanks.
Yes of course you will or should.
Whether you will get any required support from your supplier is another question.
Avid Rabid Hobbyist
Offline rf-loop
« Reply #357 on: January 23, 2015, 06:36:54 am »
Thanks.
Read siglent warranty  related your region. (read whole text carefully)
Example:
Partial quote siglentamerica:
http://siglentamerica.com/support
The following warranty applies to all SIGLENT products procured through the SIGLENT America office and/or its’ approved North American representatives and/or distributors. Product purchased from outside the SIGLENT network will be serviced by the selling agents and not SIGLENT Technologies.
Partial quote siglenteurope:
http://siglenteu.com/shfw.aspx
The following warranty applies to all SIGLENT products procured through the SIGLENT Europe office and/or its’ approved Europe representatives and/or distributors. Product purchased from outside the SIGLENT network will be serviced by the selling agents and not SIGLENT Technologies.
« Last Edit: January 23, 2015, 06:42:35 am by rf-loop »
Offline rf-loop
« Reply #358 on: February 14, 2015, 03:50:41 pm »
Just because Spring Festival time is starting soon.
But do not worry if factory in China is closed.
Assembled in...
« Reply #359 on: February 14, 2015, 04:12:56 pm »
Assembled in...
Riggght. Pull the other one, which plays Yankee Doodle.
As an aside, spot the misconnection on this Samsung TV set at my bank ( the Steve Bank) that purports to be "Made in South Africa" as well. Local TV set manufacture stopped in 1996 when the assembly plant in PE closed down, due to cheap imports. Even then they had been reduced from a full house manufacturer doing everything from design to panel and case manufacture to a kit assembler who got the local content mark from closing the back panel, placing the set in a box with a locally printed manual and placing a pair of batteries in a pack with the remote.
Offline commongrounder
« Reply #360 on: February 15, 2015, 03:39:57 pm »
Ha!  Stereo mini plug into RCA jack!  Bet that monitor has no audio!  ::)
« Reply #361 on: February 15, 2015, 03:54:57 pm »
The audio out goes to in cieling speakers, that are powered and make a very quiet hum. Luckily they plugged the mini jack into a video component Input jack. One to the left is video out....... Sad to say the video feed is via the RF link, not via the VGA input though there is a cable attached to it, leading to a computer somewhere. Kind of a waste having a HD monitor, and feeding it a standard video signal instead of using it to it's best resolution.
Must build myself a TV be gone sometime..........
Offline tautech
« Reply #362 on: February 15, 2015, 07:11:09 pm »
Assembled in...
It's the back panel of the SDS3000 designed and built in conjunction with LeCroy.....
http://www.siglent.com/prodcut-detailxx.aspx?id=80&tid=-1&T=2
Avid Rabid Hobbyist
Offline rf-loop
« Reply #363 on: February 15, 2015, 07:34:35 pm »
Assembled in...
Yes.
Also as Spring Festival present SDS2000 peak detect mode started suddenly and surprisingly working.
Offline tautech
« Reply #364 on: February 15, 2015, 07:58:19 pm »
Assembled in...
Yes.
Maybe we should advance the RTC to see what other features Siglent have decided to release that are linked to the date?  >:D
Avid Rabid Hobbyist
Offline nctnico
« Reply #365 on: February 15, 2015, 08:03:59 pm »
I already verified peak detect works since the most recent firmware update. Nothing new here. Peak detect still doesn't work properly in roll mode though.
Offline Owen
« Reply #366 on: March 11, 2015, 07:21:22 pm »
It seems that Siglent released a new SDG1000 Firmware (1.01.01.37R2): Are any Changelogs available?
http://siglentamerica.com/gjjrj-xq.aspx?id=1260&tid=15
Offline tautech
« Reply #367 on: March 11, 2015, 07:29:44 pm »
The last few I have opened the logs were included in another file.
Avid Rabid Hobbyist
Offline SHF
« Reply #368 on: March 12, 2015, 04:55:39 pm »
Hello!
new SDG1000 Firmware (1.01.01.37R2) has new menu !! - >> Bandwidth Update - >> Please input license to update bandwidth !
very interesting..... ;) ;)
Precision is no coincidence
Offline tautech
« Reply #369 on: March 12, 2015, 06:37:35 pm »
Hello!
Welcome to the forum.
It is.  :-+
This might indicate Siglent is starting to offer bandwidth upgrade options to some of their products.  :-+
Of course any product range incorporating the same HW theoretically should be capable of this.
Other manufacturers do it why shouldn't Siglent?
Avid Rabid Hobbyist
Offline rf-loop
« Reply #370 on: March 12, 2015, 08:01:49 pm »
Hello!
In the world there are many kinds of exciting things.
It may be that the Year of the Rabbit Siglent will present even more some nice things....
Offline SiglentTopic starter
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #371 on: March 13, 2015, 02:24:58 am »
It is true.
here is all the latest firmware link
SDG1000 series
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SDG1000-V100R001B01D01P37R2.zip
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDG1000-V100R001B01D01P37R2.zip
SDG5000 series
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SDG5000-V500R001B01D01P12.zip
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDG5000-V500R001B01D01P12.zip
SDS1000CFL
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SDS1000CFL_2CH_SSP_V100R005B08D02P38.zip
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SDS1000CFL_4CH_SSP_V100R005B03D02P38.zip
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDS1000CFL_2CH_SSP_V100R005B08D02P38.zip
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDS1000CFL_4CH_SSP_V100R005B03D02P38.zip
SDS1000CML/CNL(except SDS1202CNL+)
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SDS1000CML_SSP_V100R005B01D02P29.zip
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SDS1000CML_SSP_V100R005B01D02P29.zip
SHS1000/800
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SHS820_V100R003B01D02P02R2.zip
http://siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SHS1000_V100R003B01D02P02R2.zip
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SHS820_V100R003B01D02P02R2.zip
http://www.siglent.com/2014EnglishWebsite/Firmware&Software/Firmware/SHS1000_V100R003B01D02P02R2.zip
« Last Edit: March 16, 2015, 02:19:50 am by Siglent »
The Best Value in Electronic Test & Measurement
Offline pickle9000
« Reply #372 on: March 13, 2015, 02:28:29 am »
One thing Siglent really beats Rigol at, firmware updates.
Offline tautech
« Reply #373 on: March 13, 2015, 04:32:23 am »
You forgot low jitter.  ;)  :box:
Avid Rabid Hobbyist
Offline Rene
« Reply #374 on: March 14, 2015, 04:35:16 am »
Too bad they continues to behave in such an irresponsible manner as to continue the practice of distributing software that has not been digitally signed. Such lack of consideration towards their customers security concerns.... oh well.
