Hi guys,
I just successfully dumped and unlocked my brand new MSO1104Z-S! Thank you all for your outstanding work!!
I did some things differently, namely I did not use openOCD (simply because I couldn't be bothered to actually make it
work with Win7 and my JLink...). So I opted for Jlink Commander (which is nice because it auto-detects the target -
and I had it installed anyway...) using the following commands:
h /* for HALT (the Target)*/
speed 4800 /* pimp the JTAG frequency to 4.8MHz, you can probably go even higher, but my cable was a bit long...*/
savebin <yourfilename.bin> 0x40000000 0x3FFFFFF /*actually dump 64MB of Firmware; it took less than ~ 5 Minutes*/
g /*GO?? -> resumes target*/
Next thing was a problem with rigup: I kept getting segfaults. After some rigorous searching, I found that it had to do with some statically linked (??) libraries. The there mentioned fix worked (Ubuntu 15.10): Remove all LDFLAGS except -O2: LDFLAGS := -O2
It then compiled nicely and successfully generated the magic letters...
Thanks again, keep up the awesome work!!
Tobi
