Author Topic: Solder diameter for SMD  (Read 39606 times)
Offline JackP
Re: Solder diameter for SMD
« Reply #25 on: June 03, 2015, 07:35:18 pm »
Spent a few days soldering THT last week with a 936 clone, conical tip and cheap .3mm solder. What I've learned, get some bigger stuff (and order in some new chisel tips!). The amount you had to feed in was ridiculous!
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #26 on: June 03, 2015, 08:30:42 pm »
Yes - I use 0.8mm for most stuff but there are times when it's just too much, like touching up QFPs after braiding off shorts, 0402s etc. and that's when the 0.3 comes out .
Day Job: Mostly LEDs
