Author Topic: Tek CSA7404/TDS7000 repair project (Upgraded memory/CPU)  (Read 505943 times)
Offline huyong002
  • Country: cn
Re: Tek CSA7404/TDS7000 repair project (Upgraded memory/CPU)
« Reply #1000 on: February 07, 2026, 09:53:00 am »
No, that error 3 should be correct. The last page of the log shows an error. Could you please take a look?
Offline huyong002
  • Country: cn
« Reply #1001 on: February 07, 2026, 09:57:39 am »
Thank you very much. I carefully compared the serial port logs and found that it reported an error "ERROR..." at the end of the operation. The step size of 0.00 DLs is too small.
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #1002 on: February 07, 2026, 09:59:16 am »
Could you please attach all the logs as .txt files?
The following users thanked this post: huyong002
Offline huyong002
  • Country: cn
« Reply #1003 on: February 07, 2026, 10:19:18 am »
Thank you for your reply. The attachment contains the specific log. It seems that the error occurred at the end.
Offline huyong002
  • Country: cn
« Reply #1004 on: February 07, 2026, 10:23:31 am »
Could you please take a look? I don't know what to do next.
Offline cronoPatrick
    • cronologic
« Reply #1005 on: February 19, 2026, 08:11:45 am »
Dear forum members,
I would like to briefly introduce myself: My name is Patrick and I work at Cronologic. We develop ADC and TDC PCIe devices. Since the founding of our company about 18 years ago, we have been the proud owners of a Tektronix TDS 7404. It was the first “real” lab instrument we were able to afford after starting the company.
Unfortunately, about two weeks ago, the unit stopped working.
The following actions have already been taken:
Replaced the VRAM battery
Replaced the 2.5 V regulator (previously only 0.8 V was measured)
The scope now responds again via RS232. However, the boot process stops after the message:
“romPost: POWER-UP DIAGNOSTIC COMPLETE.”
The 7-segment display remains stuck showing an “L”.
Using another oscilloscope, we verified that the RS232 signals are present at connector J790.
Has anyone experienced something similar or has an idea how to proceed from here?
Many thanks in advance and best regards,
Patrick
Online coromonadalix
« Reply #1006 on: February 19, 2026, 09:49:32 am »
have you put back  the nvram configs   for vxwork booting process ?
on some tds 7k    the nvram dies, configs are lost ..
« Last Edit: February 19, 2026, 09:51:37 am by coromonadalix »
    • cronologic
« Reply #1007 on: February 19, 2026, 09:59:14 am »
How far i understand, we have todo this via the RS232 Interface. But the problem is, it stops after:
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
romPost: MPC106  Walking-one passed.
romPost: MPC106 configuration passed.
romPost: First PCI access  passed.
romPost: PC87560 Walking-one passed.
romPost: PC87560 configuration passed.
romPost: DEC21554 configuration passed.
romPost: PERFORMING ROM CHECKSUM TEST...
romPost: ROM checksum passed.
romPost: PERFORMING DRAM CELL TEST...
romPost: Enabling data cache...
romPost: Data cache enabled.
romPost: Enabling instruction cache...
romPost: Instruction cache enabled.
romPost: DRAM Cell test passed.
romPost: Disabling data Cache...
romPost: Data cache disabled.
romPost: Disabling instruction cache...
romPost: Instruction cache disabled.
romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF...
romPost: Writing address to each *address...
romPost: Reading address from each *address...
romPost: DRAM march test passed...
romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON...
romPost: PERFORMING DRAM WALKING-ONE  TEST...
romPost: DRAM Walking-one test passed.
romPost: PERFORMING NV-MEMORY WALKING-ONE  TEST...
romPost: NV-MEMORY Walking-one test passed.
And we can not break it.
Regards
Patrick
Online squadchannel
  • Country: jp
« Reply #1008 on: February 19, 2026, 01:01:24 pm »
Is the DIP switch causing this?
or maybe the boot flash is corrupted?
    • cronologic
« Reply #1009 on: February 19, 2026, 01:32:20 pm »
Do u mean the DIAG SEL switches? They are all in ON position. Attached the picture.
Offline bielec
« Reply #1010 on: April 04, 2026, 06:41:24 pm »
I am the owner of a DPO7254  which I purchased new about 15 years ago.  Well today the scope failed to switch on and I traced the fault to an overheated resistor R33 of 33k in the psu.   On reassembly, the scope powered up, all voltages present with green leds DS200,201,202,203,204,330 all showing normal.    The scope did not  complete booting however, and I had no LCD display.    Attaching a monitor to the motherboard vga showed a Tektronix splash screen with the error message "Cannot continue because the kernel driver is missing"    Is this the problem with NVRAM which is discussed at length in this forum?   Or do i have another issue?
I have looked in vain for the 7 segment display and J790 but can't find them.   Is my model different from the CSA and TDS700?   Or am I just getting old and blind?  Any assistance in my search would be appreciated.
Offline calibrationfixture
« Reply #1011 on: April 05, 2026, 05:25:58 am »
Hi bielec,
Your Instrument is another Family. See its Service Manual: Maintenance Section - Troubleshooting. And you can use Google for fixing your Kernel Driver issue.
Calibrationfixture
« Last Edit: April 05, 2026, 10:08:33 am by calibrationfixture »
Offline bielec
« Reply #1012 on: April 05, 2026, 11:57:30 am »
Thank you for your response, and yes Google suggested that the hard disk was probably not available due to bios cmos battery failure.  Well, this morning the scope booted up and worked as normal so maybe that was it.  I shall replace the motherboard cmos battery.
On this scope model, am I to suppose that there is no NVRAM and  no PPC settings to worry about?
Should I start a new thread specific to the DPO7254?
The PSU  was an Artesyn model CVR460-96P01B01  which is available at £1500 so I was lucky to find the fault of dry solder joint due to overheating resistors.  Maybe this supply is common to 7000 series scopes in this thread?
« Reply #1013 on: April 05, 2026, 01:11:16 pm »
Hi bielec,
You don't have to worry about the NVRAM in this Instrument, but both Big Fans on the left side can have a problem. See another Post from me:
https://www.eevblog.com/forum/testgear/tektronix-dpo7254-intelligent-fan-control-or/msg6078549/#msg6078549
And I should make a Clone of its HDD, upgrade the Firmware and enable some (or all) of its Options. Creating a new Topic/Thread will help Google.
Calibrationfixture
« Last Edit: April 17, 2026, 05:32:51 am by calibrationfixture »
The following users thanked this post: bielec
