Author Topic: Tektronix 11801 / CSA803 Capture Software  (Read 189 times)
Offline KosmicTopic starter
« on: June 15, 2026, 03:07:15 am »
I built a new capture software for the Tektronix 11801 and CSA803. Initially I wanted mainly to extract the high rez data from the command "DISP? DATA" but eventually got carried away and added all the capture mode I could find  ::)
Please note this was only tested on a CSA803 so if someone could test it out on a 11801 that would be great.
Some info here: https://github.com/etiennechenard/Tek11801Capture/blob/main/README.md
Download here: https://github.com/etiennechenard/Tek11801Capture/releases
« Last Edit: June 15, 2026, 03:08:57 am by Kosmic »
Offline cncjerry
Re: Tektronix 11801 / CSA803 Capture Software
« Reply #1 on: June 17, 2026, 04:07:27 pm »
I have an 11801 and I think I used John Miles' software to grab plots.  Which Visa did you use and what adapter?
Look good!
Jerry
« Reply #2 on: June 17, 2026, 10:52:19 pm »
Look good!
Jerry
I use a Keysight 82357B adapter with Keysight IO Libraries Suite 2026 (come with the VISA driver). But in theory should also work with any visa32.dll/visa64.dll (ex NI-VISA).
« Last Edit: June 17, 2026, 10:56:12 pm by Kosmic »
