Hi David, I am not sure i understand all your lines, or want to :-)
I know most tube testers are fragile, when it comes to wrong use, wrong settings, shorted tubes, and such,
high voltage, and micro amp sensitive meters, sounds like a possible way to trash open a meter,
and there is no relacement to get.
this unit works perfectly, was only used by a top pro the last 40 years, it was used every day and maintained,
I am super happy about it, i plan to keep it and use it, and to keep beeing carefull about it.
I did find one bad thing so far : for rectifier diode tubes, it is really not that smart or accurate or easy to use
