Got another somewhat uncommon piece in, same as the last, made by Polar Instruments in the UK.
A Toneohm 950 Multilayer Shorts Locator.
I was looking for an 850A, which does basically all the same, functionally, sans the multilayer function, but I hardly ever need that, only one device I work on regularly even has a multilayer board and IIRC I only had two of them with a short between layers.
However, the seller of the only reasonably priced 850A (bare unit, no probes, but those can be DIY'd) I'd found was very slow to respond, I been waiting on that shipping quote for months, by now.
And in the meantime, this 950 popped up for under 100€ shipped...didn't have to think twice about that.
All probes included, save for the multilayer ones, but there's nothing fancy about them, easy to DIY,
already have everything required on order. Shoutout to
@fcb and
@Fraser https://www.eevblog.com/forum/testgear/toneohm-850a-short-finder-by-polar-instruments-a-look-under-the-hood/msg3489726/#msg3489726Funnily enough, the original (optional, it does have an internal speaker) lightweight (as per the advertising) headphones came with the unit. I'd wager they are unused.
Regular probes on the left, current probe on the right.
My unit passed QC in 1998, to my surprise, no SMD components in sight.
And yeah, that shielding is simply a sheet of copper covered in tape, save for the area it's soldered.
Surprisingly much going on in there, compared to an 850A (
https://www.eevblog.com/forum/testgear/toneohm-850a-short-finder-by-polar-instruments-a-look-under-the-hood/msg747013/#msg747013)
One odd thing I spotted, the solder mask had lifted in one spot, looked like what I'd usually see as a side effect of sorts of water ingress,
but that can't be it? Sorta odd. With too much heat from soldering I'd expect delamination, not the solder mask lifting.
Either way, cleaned it up, re-soldered and applied conformal coating (the UV solder mask I have at hand is rather viscous, so I opted for the coating to get it all under there).
Other than that, nothing wrong with the electronics, the case had one standoff broken off and two more with cracks in them, but that's what you get with old plastics.
Welded all that. Not pretty, but it should hold, for a while anyway.
Main PCB
All buttoned up again, working just fine.
Have yet to test the vectorized plane short finding, of course, for a lack of probes.
Should be getting that done some time next week.
Now it's awaiting its' first proper use. Not gonna see a ton of use, but I'll see if it saves me any time locating shorts.
Operator Manual, Service Manual and EPROM dump are up on elektrotanya, should anyone need any of that, btw.
