The other day I declared the 7A24 vertical plug-in as “unfixable” due to it's many contact issues with both channel 1 and 2 attenuator switch decks. Well stubborn me refused to give up. Either fix it or junk it, those were the alternatives. Or a 3rd alternative, perform a radical experiment and see if it works. Got nothing to lose. Well, the experiment worked. And after a minor detour with the +15V short here are some results. Rock steady with a 10MHz square wave.
I will be outlining in detail the method I used to restore the attenuator switch decks in a separate thread. And even though this is a 50 ohm deck it will also apply to the 1MEG decks. And it applies to all 7000 series plug-ins as well as scopes such as the 465/475/485 which use the same attenuator assembly. And I assume the 5000 series plug-ins use the same decks too.
