When a 500W power supply is found looking at that thing
Heheh, power supply I'm not worried about since it can only draw the maximum the PCI bus supports. And whatever it draws will pale in comparison to the graphics card really. I'm more worried about the length of the thing, was going to quickly try it in my desktop at work here, but turns out the card is longer than my computer
Sad to see the damage on that old beast though! They often forget things like removing the rackmount brackets as well, rotary encoders should be taped down so they don't get damaged, stiff cardboard padding in front of any display, double boxing, etc. Like I was massively scared when I saw the packaging on my R&S SMH, it was just with some foam padding and relatively loose. Luckily Rohde builds them like not-so-miniaturized tanks.
