Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37113238 times)
Gertjan and 3595 Guests are viewing this topic.
Offline Mr. Scram
  • Display aficionado
« Reply #4325 on: December 04, 2017, 05:59:47 pm »
No.
You are (on the way to) an expert.
An expert is a person who made every possible mistake (Hans-Peter Dürr).
I don't feel they're mutually exclusive  :-BROKE
« Reply #4326 on: December 04, 2017, 07:45:20 pm »
Indeed. It's Sunday and I'm bored so I blew up a capacitor for the sake of forum and my children's education :)
This is a tiddler. The big ones will take your hand off.
https://youtu.be/SE0SfHuzkaU
Impressive demonstration and as you rightly said, a big one is capable of taking your hand off should it be in the vicinity of it, even at a low voltage like 32V, you don't want to pick a fight with with it. :popcorn:
Yup.
I especially love the retort from those old Sprague aluminum cans with the rim rolled around a phenolic plate to which the leads are riveted; it's like they DELIBERATELY designed it to be a pipe bomb.  :palm:
Electrons may be very, very small, but when they gang up on you they ALWAYS win.
« Reply #4327 on: December 04, 2017, 08:00:43 pm »
Gentlemen, I'm afraid I have some bad news to tell you. I don't think there's an easy way of saying this, so I'll just get it out. Yesterday I found out I'm an idiot. It's hard to swallow, I know, but it's true.
Naw - fuses aren't for idiots they are for those of us that have the power of extreme concentration which crowds out all other matters.  ;)
Now that description I like  :-DD
I'll agree it is very fair description.  :-DD
I also suffer from Extreme Concentration Syndrome. Perhaps it plays a role in the myriad other afflictions in the TEA Glossary.
« Reply #4328 on: December 04, 2017, 08:03:38 pm »
That's why some of us make a fuss when people talk about welding up their own air compressor reservoirs from any old bits of scrap lying around, or proposes welding up a corroded through compressor reservoir with the cheap MIG welder they bought at the local big-box DIY store. Imagine what it's like when your little 5ml, 500um wall thickness aluminium pressure vessel gets scaled up to a 100l, 5mm wall thickness steel pressure vessel.
That's what keeps me from buying a compressor from Harbor Freight. Cheaptankexplosionphobia.
« Reply #4329 on: December 04, 2017, 08:05:42 pm »
A new addition to the LED love-fest, a 3466A, batteries dead of course but replaced with eneloops easily. All working - within specs. Quick outside clean up.
One of the most unusual voltage setting systems - select 2 or 3 of 5 resistors for the 4 voltage settings.
What kind of batteries did the Eneloops replace? Did you have to adjust the charging current?
« Reply #4330 on: December 04, 2017, 08:08:32 pm »
The battery was a small lead acid (sealed) one that was installed in a bracket attached to the top of the meter casing and was laying on its side.
Offline Mr. Scram
« Reply #4331 on: December 04, 2017, 08:09:18 pm »
If you're afraid of a cheap tank exploding, you should see the punch the more expensive sturdy ones pack when they go.
« Reply #4332 on: December 04, 2017, 08:13:48 pm »
I see. The charging current was OK for NiMH?
« Reply #4333 on: December 04, 2017, 08:13:57 pm »
Any pressurised container is capable of tremendous damage when the integrity of the vessel is interrupted, look at the incidences of pressured boilers , even a humble electric immersion water boiler can unimaginable when they get beyond a safe pressure, punching large holes in the fabric of a building and even I'm sure in some cases bringing it down when they let go.
« Reply #4334 on: December 04, 2017, 08:15:34 pm »
I'm not sure as I replaced my lead acid with another lead acid, thus keeping its integrity.
« Reply #4335 on: December 04, 2017, 08:16:41 pm »
Oh. OK, so the question is for Rob (VK5RC), then. :-+
« Reply #4336 on: December 04, 2017, 08:17:58 pm »
What's a good alternative for pressurized air for occasional cleaning duties? Attach a hose to the exhaust of a vacuum cleaner?
Offline Mr. Scram
« Reply #4337 on: December 04, 2017, 08:25:54 pm »
Not being a wuss and getting on with it. As has been noted above, you have boilers and other devices in your home right now. There's plenty of safety measures implemented and if you're not being stupid, chances of something going wrong are slim to none. You're probably more likely to fatally trip over a multimeter.
« Reply #4338 on: December 04, 2017, 08:26:05 pm »
I have one of those pumps that you stand on the bottom (has 2 feet sticking out) and a large cylinder (plastic) with a piston in it that you pump up and down by hand and there is a short hose that is used for pumping up footballs and air beds etc. I find that you can get a quite good air flow from that and it is delivered from a fairly small nozzle so the pressure is good as well as the volume of air per pump stroke. The pump is also double acting so it pumps air on both the down ward stroke and the up stroke as well. The downside is that it does require 1 person to work the pump, and another to direct the nozzle where it is needed.
« Reply #4339 on: December 04, 2017, 08:32:44 pm »
I would be surprised if one of those cheap air compressors from Harbor Freight and the like could realistically generate sufficient pressure to cause the tank to give way. I would expect that one would have to dramatically uprate the motor size etc before that was a real risk, never upgrade something like beyond what it was designed to do, playing with fire if anyone did that.
« Reply #4340 on: December 04, 2017, 08:35:29 pm »
Well thats the third item on my Ebay list that I beaten at last second on, lets see what happens with the remaining 4 shall we, this is not helping my TEA much is it, I'm stagnating here through no fault of mine  :scared:
« Reply #4341 on: December 04, 2017, 08:43:02 pm »
Ideal for child labour then.  >:D
« Reply #4342 on: December 04, 2017, 08:45:47 pm »
Precisely, my sons usually do one or the other functions, not sure if they qualify for child labour though, in their 30's  :-DD
« Reply #4343 on: December 04, 2017, 09:02:38 pm »
Does this line of questions mean that you just won a 3466A on Ebay UK then by any chance?
« Reply #4344 on: December 04, 2017, 09:50:15 pm »
Nope, didn't win a 3466A. In true TEA fashion, I'm just as curious about others' acquisitions and mods in addition to my own. :-+ I have some 3478A, which don't have a battery option, hence the interest.
« Reply #4345 on: December 04, 2017, 09:52:22 pm »
Alrighty, then! :-+ :-DD
« Reply #4346 on: December 04, 2017, 09:52:50 pm »
Oh I see, only I was pipped at the post in my attempt to acquire another one to keep the other one company  :-DD
« Reply #4347 on: December 04, 2017, 09:59:14 pm »
Was that the HP one with the missing fuse holder? What did that go for in the end?
I won a buy it now finally. Been nearly a month now. Got a Fluke 8000A with the original 7 segment display where the segments are each made of two LEDs. Needs tidying up but is shown powered up and is listed as working. £26 was possibly a bit high but I figured the wife has spent more on ornaments that don’t do anything. 3.5 entire digits of cool  :-+
The pile-o-Flukes is go again!
« Reply #4348 on: December 04, 2017, 10:09:43 pm »
Yes it was that meter and the bloody annoying thing is I missed it by 5p, it went for £33.55. There was also another Fluke 27, went for £39, grrr.
Was that 8000A the one from Amersham, the blue one? I looked at but decided against it because it has a manual switcher.
Offline neo
  • The specialist.
« Reply #4349 on: December 04, 2017, 10:14:44 pm »
Well i have found true obsession, i bought a fluke 8400A to fix my 8400A using funds that, technically, i don't have yet using bits and pieces of earlier conversations to give myself the answer i needed.
