[EDIT]
Hmmm... the spec sheet for the DE-5000 is pretty informative. 100Hz, 120Hz, 1KHz, 10KHz, 100KHz test frequencies. 20,000uF/2000 H capacity with all the usual test parameters, and AC Resistance at the above test frequencies. Spec sheet says the TL-21 alligators & TL-22 Tweezers are both 4-wire measurement connected at the clips/tweezers. Sort mode with multiple tolerance ranges, and optional serial IR out to PC. Accuracy 0.3% to 3.0% depending on range. All with a common 9V battery for power. That is pretty damned impressive.
Further investigation of that LCR-TC1 Color Component Tester reveal a LOT of functionality for a small price ($US22-26 shipped); the usual Mega328 graphic component ID, looks like LiPo battery power supply built-in (Micro-USB charging?), IR Detector/Decoder, with junction test voltage up to 4.5V so Darlington HFe should be pretty accurate, and zener regulating voltage up to 30V. Sonuvacrap!
That is a genuine little gem right there, if the overall accuracy is as good as you suggest!
Hmmmm... it may be time for yet ANOTHER Mega328 tester in my arsenal.
[/EDIT]
*wibble*
Well the colour tester IMO is expensive just to gain the luxury of colour and a few extra functions like a cell tester, something DMM does very well, given that the one I have in the transparent case is a Mega 328, (one you recommended actually) is less then $10 shipped,
The DE-5000 I did consider briefly and the dropped it as in IMO it is just to complicated for its own good with to many button presses to access the right settings for each test etc, leads to mistakes being made aside from its price ruled it out of contention for me.
The black one $28 shipped was the first one I tried to try and read ESR etc in circuit but is not as good in my view as the Mega 328 one above because the ZIF socket is not built in but a push in adaptor if required.
I attach 2 photos of them both testing the same transistor which is an S9018 and you will see almost identical results.
Oh, I tend to agree with you in principle, but the thing with these testers is the firmware is constantly being updated to be more accurate in one device type or another, and unless you find the Chinese-language eevblog-equivalent forums where they're being discussed, and can read Chinese, you're pretty much boned as far as being able to update your firmware without buying a newer unit to steal it from so from time to time it does pay to get into a newer version.
Plus, this one adds not only higher res color display, but also built-in rechargeable power AND that IR detector/Decoder AND the 30V range on the Zener tester. I think that's a pretty good deal, especially considering the nicer case.
There are vendors selling the
black one with a ZIF socket now, and of course a bare socket is only a few $$ all over fleabay anyways. Or is that what you were saying?
The one thing that Mega328 tester DOES have is the 3-way pads for testing SMDs; nothing else is as convenient, especially for SOT-23. Tweezers are a distant second place in general, IMO. The only other
Mega328 tester I've seen with those pads more conveniently arranged is this one; also ~$US22.
Of course, you can always
buy some cheap breakout boards like these to roll your own, if that's more to your liking.
*Test-ily*
