Personally if it was my bench, regardless of what it was made out of, I'd definitely reduce the huge boat anchor loading on the top shelf. That in itself is either an accident waiting to happen when either stacking or removing any one of those boat anchors and also a possible hernia, slipped disc etc into the bargain lifting that kind of weight that height.
I would only be putting something like HP34401A's or similar up at that level, not just on the grounds of weight and personal safety on the times when you need to alter them around etc. but from a purely ergonomic view point. Also of course, things like that need to be at an easy to view level and your sitting at the bench they are not easy to view, they would and will as you get older become a point of severe aggravation, especially if you get a stiff neck from time to time.
I was actually thinking of having the beams be just shy of ceiling height so that for something like my tektronix 7704a i could make a mount to hold it at an angle facing down towards the workbench. Like Mr.Carlsons ceiling mounted scopes, for example. Besides that there is always the possibility of using the beams to give me a monitor mount or whatever else really. If all i was interested in was a shelf then i'd be fine with 60" posts.
That's fine, but I was actually referring to bench that URI has and the massive boat anchors he has above his head, I have shelves above my bench but they are not used for holding anything TEA related so I don't have to keep looking up all the time, I keep things like models etc on them. As you can from this photo, my stuff is all within my field of vision and below the lower monitor shelf of my desk/bench where the storage bin and NAS drives can be seen, now resides my Tektronic TDS210 scope and my larger Fluke PM3390B is to my left besides me which does not get used as much these days unless its extra oomph.
I see your point, Specmaster, but I'm still young enough to lift my boat anchors up that top shelf.
Plus I don't have enough space around my bench, so no problem on my side yet. So it grew to the ceiling.
I also have a zone just in front of me sitting at my bench with instruments within the range of my arms:
My oscilloscope (Phillips PM 3065) resides directly on the tabletop, so do all my power supplies without GPIB and as exception from that rule (..GPIB) my 34401A.
Above that and under the top shelf I have two shelves where various instruments/tools reside that I use regularly;
Three weller solder stations, a desoldering station, DMMs (HP 3457A, Philips/Fluke PM2534 and PM2535), voltage/current calibrator Knick JS 3010 and my 4263A LCR meter -and used less regularly, but it's handy to have them within the range of my arms: power meters (432A, 437B) and signature analyzer.
All these devices (except the oscilloscope) have one feature in common: They're under ~30cm deep thus fit on the tabletop/shelves above. Boat anchors with 50cm-60cm wouldn't.
Having my boat anchors (function Generator 3325B, level generator 3335A, voltmeters 3456A, counters PM 668X, system power supplies 6232B, 6643A, electronic load 6063B) up over my head is not ideal on one hand; On the other hand the back of those instruments is freely accessible for reconfiguration of cabling etc I found out more than once.
Yes, Specmaster, I would arrange my bench differently if I had more space meaning: more square meters of free floor. I'd probably set my boat anchors up on tabletop level and slightly above like you.
Another aspect: E.g. you have a smaller function generator and counter (TTI) that fit on your shelf so you don't have my problems.
I'll stick to my 3325B and PM668Xs because I like it very much thus I have to bear* the consequence..
(*-double meaning
