Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 35672075 times)
Vince and 2578 Guests are viewing this topic.
« Reply #20225 on: November 24, 2018, 06:36:58 pm »
Might be worth grabbing a cheap Chinese Saleae clone these days. I’ve got one. I haven’t actually needed it yet.
I bought one of the USBeeAX (The model with a single 'scope channel as well) clones before I discovered it used stolen/hacked software. It serves quite well on an old Toughbook I keep for knockabout work; it is still my go-to for quick automotive diag with a 10X probe.
Just be aware you need 32-bit OS to run it. There is a newer version of the software that is also 32-bit, but that will nuke the firmware in the clone USBee if you don't lift the write-enable pin on the FLASH ROM. PM me if you need it... I have both. You'll need DotNet 3.5 as well.
*Home alone with the kid, and quite outnumbered*
« Reply #20226 on: November 24, 2018, 06:40:23 pm »
Good books. Have both. Make sure you check the errata in the learning book. It’s extensive.
Yeah, they just had to go and actually LOOK at the little bastards moving... and discovered we had it bass-ackwards all these years.  :palm:
"Electrons may be very, very small... but when they gang up on you, they always win." ~ me
« Last Edit: November 29, 2018, 02:22:22 pm by mnementh »
Offline Gribo
« Reply #20227 on: November 24, 2018, 07:26:24 pm »
I think I am on the right path.
I am available for freelance work.
« Reply #20228 on: November 24, 2018, 07:57:03 pm »
*Makes sign of warding against the horrific visage of a HAKKO FX-951*
"Back...! Back you fiend; back to the depths that spawned you!!!"
Seriously... of all the Txx-compatible models you could have chosen from, you HAD to pick the one designed by a sociopathic reject from the Doofenschmirtz School who clearly HATES anybody who has to actually USE the Ifni-accursed thing?  :palm:
The murrr-furrr who designed that thing needs his nutsack ground into a fine paste under the heel of a rhinoceros in heat.  :-DD
"Kill it! Kill it with FIRE!!! It's just going to catch fire by itself and burn down your workbench anyways!!!" ~ me
Offline Mr. Scram
  • Display aficionado
« Reply #20229 on: November 24, 2018, 08:10:48 pm »
What's up with everyone seemingly casually having 3000X series on their desks? It makes me feel.. inadequate.  ;D
« Reply #20230 on: November 24, 2018, 08:11:03 pm »
The right path to what?? :-DD
« Reply #20231 on: November 24, 2018, 09:15:17 pm »
If it makes you feel any better, merely the TDS210 here and that's good enough! My bench is looking very sparse today, since I tidied it. Playing with VFO feedback and "finding the cheapest ass FET that isn't useless so I can buy a couple of hundred of them":
(33120A and TF930 are on the shelf above and that is all I have out at the moment - rest is stashed away where I can't get distracted by it!!!!  :-DD)
Edit: just meant to add, I am really so happy with this set up. Everything works just how I want it to. I don't want to change a thing for once!
« Last Edit: November 24, 2018, 09:18:06 pm by bd139 »
« Reply #20232 on: November 24, 2018, 10:01:08 pm »
No need to feel inadequate. This SDS-1052DL does just fine thank you very much. But if it does get out gunned I have an extensive analog fleet to back it up.
« Reply #20233 on: November 24, 2018, 10:07:34 pm »
The transformer I use right now has two heater windings, but since the mains voltage was raised to 230 volts, they're a tad too high (7.1 volts) for my taste. And I prefer DC, of course. Alas, 7 volts AC doesn't leave enough headroom for regulation to 6.3 volts after full-wave rectification.
A third transformer  just for that? These are the reasons for my undecidedness. ;) And I have plenty of lab supplies (remember the 9 HP E6114A).
That should not be an issue. As soon as you load the filament windings with tubes it will drop to closer to 6.3 volts. And tubes aren't real fussy with their filament voltage anyway as long as it isn't ridiculously high or low.
Offline djos
« Reply #20234 on: November 24, 2018, 10:26:09 pm »
I get jealous seeing those pics too, I've just got a cheap ass Uni-T UTD2102CEL scope on my workbench.
Offline Gribo
« Reply #20235 on: November 24, 2018, 10:43:22 pm »
On the right path of giving my wife a heart attack when she sees the bill  ;D
Offline Mr. Scram
« Reply #20236 on: November 24, 2018, 10:57:59 pm »
I have to be mindful to be very happy with what I have, rather than being too busy with or unhappy about what I don't have. I'd have killed for my current kit not too long ago, and can tackle some rather interesting projects. Yet I catch myself looking at what's next a bit too much sometimes.
« Last Edit: November 24, 2018, 11:00:12 pm by Mr. Scram »
Offline Mr. Scram
« Reply #20237 on: November 24, 2018, 10:59:16 pm »
Don't knock that Uni-T. Their oscilloscopes are comparatively good compared to their other products and that model line is basic, but quite useful.
The following users thanked this post: djos
Offline djos
« Reply #20238 on: November 24, 2018, 11:01:10 pm »
Good point, I might upgrade to a 4 channel Rigol at some point, just because it's hard to watch RGB signals with only 2 channels. Otherwise my Uni-T is good enough for everything else I use it for.
Ps it only cost me $100 aussie pesos so I can't complain.  :-+
Offline Mr. Scram
« Reply #20239 on: November 24, 2018, 11:07:51 pm »
Maybe one of those cheap logic analysers would do the job? Or do you need signal integrity too?
Offline djos
« Reply #20240 on: November 24, 2018, 11:08:54 pm »
Quite possibly.  8)
Offline Neomys Sapiens
« Reply #20241 on: November 25, 2018, 12:13:37 am »
Aah, damnit.
Wolfgang, I owe you an apology. I really should have credited the HV PSU's original designer right at the first post (I was also unaware that the very designer was participating here). I never meant to imply it was my design. My linear design capabilities are, alas, not quite top notch.
Totally unrelated:
There's an Agilent 54641d (complete with probes!) on german fleabay. https://www.ebay.de/itm/302962251973 As I'm not at all happy with my Rigol's logic analyzer, that thing looks interesting to me. What do you think?
So? Did you get it? Even as I am not exactly a fan of this series (and manufacturer, when talking scopes), it should be much better that a Rigol and the end price seemed quite adequate.
On the topic of enclosures. for standard instrument needs (anything below 19" and not RF or environmental, and needing no special form factor) I can only recommend the range from Feltron Zeissler.
Especially the possibility to insert a mounting plate at mid-height lends itself to nice solutions.
Online tggzzz
« Reply #20242 on: November 25, 2018, 12:14:13 am »
Make sure you understand the limitations of protocol decoding on those scopes, and assess whether it affects your use cases.
General principal: use a scope to assure the signal integrity of the analogue signals. Once that is assured, flip to using a digital device (e.g. logic analyser or printf()) to capture the digital signals.
« Reply #20243 on: November 25, 2018, 12:19:52 am »
Is that the thing coloured like a sort of evil parrot?
Nevertheless: don't go postal.  Reptile, take your medicine!
(I deem it ok, for a Highland)
P.s.: I was just waiting for any opportunity to throw this pic at you
p.s.2: Empty by now
« Last Edit: November 25, 2018, 01:19:20 am by Neomys Sapiens »
Offline Zucca
  • EE meid in Itali
« Reply #20244 on: November 25, 2018, 01:25:20 am »
I feel now I have to stop to buy toys and start to play with them. My problem I never use my brain before using the wallet.
I am such a TEA addicted... Maybe I need to find a wife to cure my TEA, or should I buy more now because I am SWMBO free?
« Reply #20245 on: November 25, 2018, 01:40:25 am »
No SWMBO? Shop 'till you drop!  :-DD :-DD :-DD  (Or go broke)
« Reply #20246 on: November 25, 2018, 03:16:59 am »
That scope will probably do the trick quite nicely. Welcome to the TEA house, Gribo!
Offline 0culus
« Reply #20247 on: November 25, 2018, 03:29:55 am »
OK, what does SWMBO mean? It's not in the glossary in post 1!  :-DD
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #20248 on: November 25, 2018, 03:38:27 am »
She Who Must Be Obeyed.  :-DD
Offline 0culus
« Reply #20249 on: November 25, 2018, 03:43:59 am »
And now it makes sense!  :-DD
