0 Members and 2688 Guests are viewing this topic.
Here's the improved version of a 190VDC reference completed and mounted in a case. I changed the 4 turn trim with a 25 turn trim pot to give a finer adjustment. The reference is not perfect but it is significantly better than my old version. The old one would drift around as much as 2 to 4 volts which made it almost useless as a decent reference. With the improved regulation it drifts about +/- 70mV or about 140mV total.
Quote from: med6753 on December 02, 2018, 01:03:44 pmHere's the improved version of a 190VDC reference completed and mounted in a case. I changed the 4 turn trim with a 25 turn trim pot to give a finer adjustment. The reference is not perfect but it is significantly better than my old version. The old one would drift around as much as 2 to 4 volts which made it almost useless as a decent reference. With the improved regulation it drifts about +/- 70mV or about 140mV total.140mV in 190V is ~700ppm.Whether that is acceptable depends on what you are trying to do. It wouldn't satisfy the voltnuts, but arguably nothing can satisfy them
Quote from: med6753 on December 02, 2018, 07:31:34 amQuote from: Brumby on December 02, 2018, 04:34:41 amQuote from: tautech on December 02, 2018, 01:18:17 am... so I guess he's picked up a little of our Kiwi twang.That twang is quite persistent. I was at a garage sale a few years ago and heard a lady there say something. I turned to address her stating "You're a kiwi." She looked at me somewhat startled and told me she left New Zealand 17 years ago. She obviously thought that would be long enough to lose that accent.I don't think it ever goes away.Just like a NYC (and upper New Jersey) accent. It NEVER goes away and I can pick it out a mile away. Yup, upper NJ for me. I've been in Florida for 29 years. The accent is less but still there. Of course, I can easily exaggerate it if necessary. Fuggeddaboudit.
Quote from: med6753 on December 02, 2018, 01:15:24 pmQuote from: bd139 on December 02, 2018, 01:10:06 pmTry swapping out the resistors for ~1W metal film 1% resistors. Carbon ones drift terribly when they get warm. 250-500 ppm/oC at average. You can get that down to 50ppm/oC and use larger resistors that dont get warm to dodge it. If you want to play with this idea, solder a 100 ohm cheap CF resistor on the end of a couple of bits of wire and plug it into a handheld DMM and wave it over a flame. Then do the same with an MF one.Hmmm...maybe go one better with 0.1% resistors. The next Mouser order will include some. Don’t really need 0.1% as you can cal the thing out with your trimmer. Main thing is low ppm drift. If you can do better than 50ppm put your money into that. Also if it doesn’t get any better then the IC is probably causing it. Glue it to a big chunk of metal
Quote from: GreyWoolfe on December 02, 2018, 01:18:04 pmQuote from: med6753 on December 02, 2018, 07:31:34 amQuote from: Brumby on December 02, 2018, 04:34:41 amQuote from: tautech on December 02, 2018, 01:18:17 am... so I guess he's picked up a little of our Kiwi twang.That twang is quite persistent. I was at a garage sale a few years ago and heard a lady there say something. I turned to address her stating "You're a kiwi." She looked at me somewhat startled and told me she left New Zealand 17 years ago. She obviously thought that would be long enough to lose that accent.I don't think it ever goes away.Just like a NYC (and upper New Jersey) accent. It NEVER goes away and I can pick it out a mile away. Yup, upper NJ for me. I've been in Florida for 29 years. The accent is less but still there. Of course, I can easily exaggerate it if necessary. Fuggeddaboudit.My paternal grandmother was originally from Jersey City, NJ and she used to say "uril" for "oil" and "turlet" for "toilet". My younger brother would tease her by running through the house yelling "turlet, turlet!" and it would piss her off to no end.
If you’ve got some freezer spray squirt the resistors and the IC carefully and independently and work out what happens. That should point to the biggest offender.
You can also spray it on a cotton swab and touch the component with it as well. Also with the added bonus of a plastic insulator between you and the other end of it where all the volts are hiding.No Christmas tree up yet. I just managed to undo about 2 weeks' worth of damage from my slightly over-creative 6 year old. Hopefully we'll get the tree up before she trashes the place again. Tree tomorrow, maybe.
When I get back to the 6114A again I will have to do something.
I just got a bunch of GPIB cables I'd like to test. Considering the recommended maximum cable length between devices is 4 metres, I think I can just daisy chain them together and stick a device on the end as long as I don't go over those 4 metres total to test the lot. Right?
I do have freeze spray but the spray pattern is too damn big to really isolate individual components. I'll start replacing the resistors and take it from there.
I thought it was maximum of 4m between devices and 20m (I think) total length. So providing there is an active device every 4m should be fine daisy chaining leads.
... glitter ...
Quote from: URI on December 02, 2018, 09:28:39 amWhen I get back to the 6114A again I will have to do something. You need to get that power supply out of your way! Can I help?
Quote from: tggzzz on December 02, 2018, 02:19:22 pmQuote from: med6753 on December 02, 2018, 01:03:44 pmHere's the improved version of a 190VDC reference completed and mounted in a case. I changed the 4 turn trim with a 25 turn trim pot to give a finer adjustment. The reference is not perfect but it is significantly better than my old version. The old one would drift around as much as 2 to 4 volts which made it almost useless as a decent reference. With the improved regulation it drifts about +/- 70mV or about 140mV total.140mV in 190V is ~700ppm.Whether that is acceptable depends on what you are trying to do. It wouldn't satisfy the voltnuts, but arguably nothing can satisfy them Some other universe with better constraints might
..for bitseeker:There's room on the bench reardless how crowded it is, e.g. on my bench there's now an inverted pyramid stack of TE......because I wanted to test the counter but wasn't eager for rearranging my bench/tidying it up. When I get back to the 6114A again I will have to do something.
Here's the improved version of a 190VDC reference completed and mounted in a case. I changed the 4 turn trim with a 25 turn trim pot to give a finer adjustment. The reference is not perfect but it is significantly better than my old version. The old one would drift around as much as 2 to 4 volts which made it almost useless as a decent reference. With the improved regulation it drifts about +/- 70mV or about 140mV total. One heck of an improvement and I can live with that amount of drift. But I'm sure it can be improved. Perhaps an op-amp with a precision reference as a feedback loop to null out any drift. But I'm not smart enough to figure that out so for now I'll leave it as is.
Quote from: bd139 on December 02, 2018, 08:59:16 pm... glitter ...That's worse than sand. It gets everywhere, e.g. into Tek leaf switches When I get a Christmas card from one relative, I always open the envelope over the bin, so that the loose glitter/stars/etc doesn't hang around and annoy me until the new year.
