Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36132884 times)
0 Members and 3357 Guests are viewing this topic.
Offline 0culus
« Reply #22925 on: January 17, 2019, 02:21:19 pm »
I want to take a shower, but I can't. I could, but I know I'll find a "didn't find you home" slip as soon as I exit the bathroom. Of course, waiting it out means not seeing anyone all day. That's how it works.
The sacrifices we make for TEA...  :-DD
Offline ArthurDent
« Reply #22926 on: January 17, 2019, 03:09:57 pm »
Uri (reply #22901) – “The standard oscillator comes nowhere near being spot on.”
My 53132A came with the high stability time base and 3Ghz channel (options 010 and 030). One design flaw of the HP53132A, in my opinion, was having the caps on the power supply right against heat generating components especially where the power supply is always on. The caps in my power supply were starting to bulge so I replaced them all with new high temp ones. Where I normally use an ext ref and don’t need the internal ref powered 24/7, I installed a toggle switch in one of the unused holes in the back that allows me to reach behind and kill all power going to the counter if I’m not going to be using it for some time.
I had used my Pendulum CNT-81 (Fluke/Philips PM6681) with the math function and 10 second gate time to get 12 digit resolution but the HP53132A does it neater and in a smaller package.
The following users thanked this post: FransW
Offline URI
« Reply #22927 on: January 17, 2019, 03:35:22 pm »
That's just another description of Murphies law..   :-DD
Offline Mr. Scram
  • Display aficionado
« Reply #22928 on: January 17, 2019, 03:36:08 pm »
The sacrifices others make for my TEA. Oof! Luckily, the meter has arrived. Time to get some hot water and make some Scram Tea. It's an acquired taste.
« Reply #22929 on: January 17, 2019, 03:38:32 pm »
And a cordial "Fuck you too, med."  :-DD
" *~Good mo-o-ornin-n-ng!!!~* " is what med would say if... ummm... err... Oh, who the fuck am I kidding? med would NEVER say that... and certainly NOT in that tone of voice.   ;)
"The more people I meet, the more I like my dog. BTW... my dog's a complete asshole." ~me
Hey, you wanna hear some Quaker?
Fuck thee.  >:D :-DD
Right back atcha with a side of toast, old friend. ;) Dry, of course... Just like Elwood.  :-DD
Current mood: 60.7 Hz
« Reply #22930 on: January 17, 2019, 03:54:02 pm »
Time to recycle the old Viz board game (right click, open in new tab):
« Reply #22931 on: January 17, 2019, 03:55:13 pm »
I thought I smelled something rank.  :o :-DD
I think that's whatever I just stepped in...  :o
"Awww, man... it got under my scales and e'e'ythang..."
Offline Mr. Scram
« Reply #22932 on: January 17, 2019, 04:00:51 pm »
I was thinking of that one earlier. ;D
« Reply #22933 on: January 17, 2019, 04:20:43 pm »
When Beanflying looked over my proposed 190mV, 1.9V, and 19V references he recommended for greater stability to reduce the size of the trim pot and add any required fixed resistor to achieve the desired output. I decided to test that on the 190V reference and results have been spectacular. Here's the results. Initially I had an over all drift of approx +/- 30mV. That has been reduced to less than +/- 20mv.
After 30 minute warmup and setup.
45 minutes later
Here's the original schematic. The trim pot was 10K. It's now 1K. An additional 1K fixed resistor has been added so the total fixed on the adjust pin is now 440K. I'm seriously considering replacing those 3 resistors in series with 1 - 0.1% of approx 440K. I may be able to get this reference close to lab grade!  :o I have totally fallen into that volt-nut rabbit hole.  :-DD
Tomorrow I'm going to start building up the low voltage references.
Online tggzzz
« Reply #22934 on: January 17, 2019, 04:28:56 pm »
Have you tried undressing, dipping your foot in the bath, and waiting a second or two?
That actually worked for me, a couple of weeks ago :)
(Yes, I did have a large towel nearby :) )
The following users thanked this post: Mr. Scram
Offline neo
  • The specialist.
« Reply #22935 on: January 17, 2019, 04:33:27 pm »
See i don't have problems with them not delivering. They always leave it, sometimes in the yard because their too lazy to drag the overweight box to my door but they always leave it logic be damned.
« Reply #22936 on: January 17, 2019, 04:33:48 pm »
I have to tell yeh all that I have just come across someone really genuine on evilbay.... what that you say...Never  :-DD
Monday I spied a Teac CR-H250 receiver just been listed with a BIN price for spares / repair and contacting the seller it seems that it just stopped recently mid way through a track but he claimed that unit worked perfectly OK prior to that including the DAB section. Many of you will know that I've been looking for 2 DAB modules to fit inside of another H250 and also a H300DABmkII tuner.
I offered a low figure, way below £10 because it sounded that it could be terminal as it was completely dead in every way. The seller said that he did not have anything other than the unit, no aerials or remote etc.
My offer was accepted and drove to London N1 to collect it that afternoon and when got it home, extracted the DAB and fitted it in the other receiver and it worked perfectly. I then set about finding out was wrong with the unit, in case it was an easy fix, and it transpires that the power transformer has had the embedded thermal cutout in the primary operate and of course the transformer is unobtainium.
Last night, totally out of the blue, the seller emailed me saying that he has found the remote for and if gave him my address he would post it to me. I replaied of course and took him up and offered to sent via PayPal a few quid for it to which he declined the offer and that he would post today. So I mentioned to him what I had found and asked if he had used with anything covering the ventilation holes in the top (these do run warm) and he replied yes, he had his laptop resting on the top so he could plug it into AUX input and play some music and thats when it stopped working.
Now how many people would A) Bother to contact me later and say that they had found the remote and offer to send it to me and B) also decline to accept any money for it or the postage so I fully expect that after he pays the selling fees and postage that he'll be lucky to have made £1 on the sale. He said he was glad that the DAB module brought my unit back to life and that was reward enough for him... how sweet.
That has really cheered me up knowing that there some really nice people out there  :clap: :clap: :clap: :clap:
Offline Fungus
« Reply #22937 on: January 17, 2019, 04:36:21 pm »
Offline Mr. Scram
« Reply #22938 on: January 17, 2019, 04:49:01 pm »
The question is what I'm going to do now. I originally purchased the meter as a gift, as earlier conversations suggested interest. Since I bought it I've been prying the mind of the intended recipient some more and it's clear that a multimeter isn't as high on the list as I'd hoped, or possibly not even on the list at all. I really don't want to give something for my own gratification, only for it to end up on a shelf. It's not quite the meter I would have bought for myself, though.
Offline neo
  • The specialist.
« Reply #22939 on: January 17, 2019, 04:53:35 pm »
Could always send it to me.  :popcorn: I may have a dozen already but like any true TEAr i swear i use all of them.  :-DD
« Reply #22940 on: January 17, 2019, 04:54:41 pm »
Heads up:
https://www.ebay.com/itm/173711610060
Interesting piece. And it's definitely from the early 1930's. Dead give away is it can only socket the older 4 and 5 pin tubes. It can't do octals (8 pin) which came out in the late 1930's.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #22941 on: January 17, 2019, 04:55:26 pm »
As announced, here are the photos of my newly arrived HP 53132A:
Checked with my naked but working Trimble 57963-D against itself it's spot on showing a nice 12 digit resolution:   :-DD
this unit is perfect to built the TEA-Meter, connect it to a stable VCO  and subtract the 0V Offset
« Reply #22942 on: January 17, 2019, 04:55:46 pm »
What kind of "meter" is it?  :-//
« Reply #22943 on: January 17, 2019, 04:58:02 pm »
Okay... Brain-picking time:
Y'all know I've been looking for a video card. I have a counteroffer of $145 shipped on an XFX Radeon RX 580 GTS XXX Edition 8GB card. Appears to have not been used for mining but actually used for gaming, as I can see seller also listing pretty much his whole gaming rig. With retail box & paperwork.
Take it or not?
Offline Mr. Scram
« Reply #22944 on: January 17, 2019, 04:58:19 pm »
I like you guys, but not quite *that* much.  :popcorn: It would definitely be useful to have around, but I'd have picked something different for myself. Not that I really need any more meters, really.
Offline Mr. Scram
« Reply #22945 on: January 17, 2019, 04:59:15 pm »
Take it or not?
Although I'm not familiar with your local market, it sounds like a good deal to me.
« Reply #22946 on: January 17, 2019, 05:00:02 pm »
You'll get the remote and it will be destroyed since the batteries leaked.  :-DD Just kidding. It is amazing but every once in a while you DO encounter an honest person. But don't let you guard down because the next person will take you to the cleaners.  :o ;D
Offline Mr. Scram
« Reply #22947 on: January 17, 2019, 05:10:58 pm »
It's a Fluke 179.
« Reply #22948 on: January 17, 2019, 05:11:29 pm »
Guess I'm not the only one who's ever done this. Mostly because when I was younger and did the B/S/T flea market trade in recycled electronics, the biggest PITA was remotes; I was constantly rummaging the yard sales and household sale tables to find the one I needed for a TV, VCR, DVD player, etc. I know the pain of trying to find the right remote. It's right up there with athlete's foot.  :palm:
I know... an eBayer with empathy. Go fig.  :-// (But I probably would have accepted the offer to cover postage) ;)
I've also sent a seller a "bonus" when I got more than was listed in an auction. Nothing crazy... a few bucks and a "Thanks for the extra... have a brew on me." in the PP transaction or similar.  :-+
eBay's a bitch; but I have a lot of Karma to burn off.
« Reply #22949 on: January 17, 2019, 05:16:47 pm »
I second that thought, can never have too many meters can you??? I use all of mine from time to time to keep them all gainfully employed  :-DD
