Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14933639 times)
Gertjan, rvalente, Vince, opabob and 242 Guests are viewing this topic.
« Reply #23000 on: January 18, 2019, 04:41:43 am »
https://www.ebay.com/itm/163491313811
Since it's bought & paid for, I guess I don't have to worry about someone sniping it out from under me. Of course, only after I paid did I see that the seller has "Relisted this item or another one like it".
Dammit... I looked at his other items and selling history before I bid, no prior on this item and only a few other computer parts, MBs & such; like you would expect from someone selling their old gaming rig. Jeebus, I sure hope he isn't just unloading some effed-up mining cards. :palm:
I've messaged the guy asking to make sure it still has the stock firmware. Hopefully it arrives as described.
I'm all out of "pithy".
« Reply #23001 on: January 18, 2019, 04:50:40 am »
The question is what can owning Capacitance Standards of that quality give you when most Caps we use are at least 1%+ accuracy unlike say a resistor where 0.005% is readilly available? My Yokagawa/HP decade box is 0.25% and way better than I need as a reference.
Offline Kosmic
« Reply #23002 on: January 18, 2019, 05:52:14 am »
No idea, Even for RF application (where you need precision) you endup testing the cap with a VNA to find the self-resonance frequency. And the frequency change from one cap to the other depending on their construction.
Offline Inverted18650
    • Test Gear Addicts
« Reply #23003 on: January 18, 2019, 05:53:36 am »
woups .. that's what I meant. Still, try to find something that can give you 5 digits resolution on the nano farad range.
No worries man, I have some others than you may want to try though. PM me and Ill send you my email and we can chat there if you'd like. Thanks again.
    • Test Gear Addicts
« Reply #23004 on: January 18, 2019, 05:56:35 am »
They are being sent to England where "Dr. (nunabusiness)" will be setting up his calibration lab. I obviously have no use for them, I am just trying to get him some base line paperwork, as I have no (reliable) way to do it on my own. But for a CAL LAB that students will frequent for years to come, they are a treasure.
**the good Dr is a forum member, I just have no right to speak on his behalf; as that sounded kinda pissy, I didnt want you to take it the wrong way.
« Last Edit: January 18, 2019, 06:00:16 am by Inverted18650 »
« Reply #23005 on: January 18, 2019, 06:25:40 am »
The question I put above was aimed at 'us' the users not a Cal Lab. 98% of us simply can't use them or measure them as you know. Any measurements you make are likely to carry an error at least one order of magnitude more than needed to read it with 'precision' let alone confirm it's value with any level of certainty. So other than a rough check with the best gear you have on hand not worth shipping around IMO even to someone with a 0.1% class LCR meter.
    • Test Gear Addicts
« Reply #23006 on: January 18, 2019, 06:34:13 am »
What about just having fun and seeing how good your gear is? But I gotta..I sold my 4274A because it was WAY more than I needed (until now right) so I feel ya.
    • Test Gear Addicts
« Reply #23007 on: January 18, 2019, 06:38:31 am »
If you reserved some gear, please PM your address you I can get quotes and start getting this stuff packed up. As soon as I actually sell something, I will be able to start mailing it out...MUCH LOVE!
« Reply #23008 on: January 18, 2019, 06:47:31 am »
Absolutely that's why I got the HP box in the first place at 0.25% it is as good or better than fairly much most Capacitance meters I am likely to use and better than the variation as per Kosmic alluded to above for tuned circuits of off the shelf Caps.
When I ran the box over the 121GW (2.5%) it is an order of magnitude better than the meter so a good test against a claimed spec.
BUT
Part of looking at the Tweezers I have on the bench will be using it to test them across a range and at different frequencies but in this case the of one set of tweezers are down to 0.2% accuracy depending on range so they become as much about testing the box as being tested. But as they claim to have been tested/calibrated prior to shipping a good chance to see if the HP is still somewhere within spec. I will also be setting up a couple of sanity checks with the Sig Gen and DSO. Maybe I should have brought your Caps  ;D
« Reply #23009 on: January 18, 2019, 07:59:38 am »
Any of you have an old meter in need of some new old terminals? Same deal as before free plus postage should nearly be letter thick so not to much postage around the planet but would need to check. They are 50 ohm Pamona dummy loads in the middle.
Offline tautech
« Reply #23010 on: January 18, 2019, 08:04:57 am »
Oh, those long skinny ones are AVO meter lead tips.
I've got a few and a few old AVO's without them.
I'll raise a hand if no one else needs them.
Avid Rabid Hobbyist
« Reply #23011 on: January 18, 2019, 12:14:26 pm »
The winter storm "watch" that I mentioned yesterday has now been confirmed as a "warning" for Saturday afternoon through Sunday. No snow amounts given other than stating "heavy snow" and blowing snow. So there will be mass hysteria today at the local grocery stores since most did not heed the potential forecast posted days ago. :palm: I did my grocery shopping yesterday and the store was nearly empty. So I'm fully provisioned. :-+
All I have to do is visit my local pharmacy this morning and pick up a refilled medication. Then hunker down and watch it from the window.  ;D
« Reply #23012 on: January 18, 2019, 12:38:52 pm »
Looks like a nice little front heading through the NE. Bit cool here for the next few days only + 21-22C  ;)
@Tautech Avo tips are yours.  :)
Offline tautech
« Reply #23013 on: January 18, 2019, 12:49:14 pm »
Thanks Bean but hold off for a week to see if someone needs them more than I.
Providing any weather has blown through by next week I don't care as I'm off fishing later next week trying to get a stripy or two in a comp, wish me luck.  :)
Let's sort the tips when I get back if that's OK.
Avid Rabid Hobbyist
« Reply #23014 on: January 18, 2019, 01:08:01 pm »
Swap places with you, its +2C here.
Offline tautech
« Reply #23015 on: January 18, 2019, 01:23:14 pm »
In the last month we've seen up to 42C while in Perth and a few high 30's and got home to days of 27C, it felt nice and just worked through it on some jobs outside that had to be done. Nothing like a few weeks in a hot climate to help you through the hotter days at home.  :)
Next week or two is normally our hottest in NZ with the odd place hitting 30C.  :phew:
I'm going fishing and I don't give two hoots.  :P
Gunna do a bit of this too:  :popcorn:
Avid Rabid Hobbyist
Offline Brumby
« Reply #23016 on: January 18, 2019, 01:25:11 pm »
I know about 42ºC.  Had it here today.
Offline tautech
« Reply #23017 on: January 18, 2019, 01:31:41 pm »
Yea for aircon and beer.  :phew:
Experienced a week of 42C for my first Perth visit a few years back and then went to see the wifes buddy a couple hours north and inland where it was 45C !  :wtf: That was tough.  :--
Avid Rabid Hobbyist
« Reply #23018 on: January 18, 2019, 01:37:54 pm »
I'll trade, although 42 C is a little too much.  :-DD Currently -3 C and got a dusting last night. A foreshadowing of things to come.  :scared:
« Reply #23019 on: January 18, 2019, 02:01:18 pm »
   *Sighing wistfully over my morning cuppa Chock Full O' Nuts*
I miss "weather".
« Reply #23020 on: January 18, 2019, 03:04:30 pm »
I miss "weather".
Better brace yourself, you'll get plenty of it when you move north of the border
« Reply #23021 on: January 18, 2019, 03:10:49 pm »
I miss "weather".
The forecast here is getting more detailed. Now saying 6 to 12 inches of snow with winds up to 30 MPH. Close to blizzard conditions. Must have sustained winds of +35 MPH to be considered a blizzard. The only thing I worry about is losing power. And that's usually caused by some jack hole hitting a power pole, not because of a tree coming down.  :scared:
« Reply #23022 on: January 18, 2019, 03:22:30 pm »
Yeah, I know... I used to live a few hundred miles upstate of you, in the Finger Lakes region. We had lake-effect snowfalls (the rest of the state gets 3"; we'd get 10".... for weeks in a row sometimes) deep enough to hide a pickup truck... and when the snowplows come through, sometimes they throw snow 30 feet because they have to move that fast to "keep the curl".
You forget you have a mailbox for days sometimes. ;)
Still better than 2 months of weather where you can almost breathe, and the rest of the year like living in a sauna. And the constant battle to keep roaches and ants OUTSIDE, because there's never a killing frost. The "line of death" around every structure is kindof metaphoric...
*Off to the dentist for my next dose of misery*
« Reply #23023 on: January 18, 2019, 03:40:36 pm »
I miss "weather".
I know the weather in that region intimately. I grew up about 400 miles from Toronto, almost on the same latitude. The move holds no surprises for me, aside from the idea that I'd EVER be happy to go BACK from where it's warm.  :scared:  That WAS a surprise; but it's over now. ;)
Texas is THAT toxic; environmentally, socially, AND spiritually.  :palm:
I think it's the constant, unrelenting heat. It bakes people's brains; boils all the humanity out of their very pores, and all that's left is self-righteousness and selfishness. You see the same regressive attitudes towards almost everything here that you do in the middle east; where they still have family feuds that are twice as old as America.
Cheers,
I don't want to be that person.
Offline Kosmic
« Reply #23024 on: January 18, 2019, 03:47:36 pm »
Just Ordered bunch of 0.5% caps  ;D I should be able to lower uncertainty a little bit on the PM6303.
