bdbbdb, themadhippy, nfmax, Vince and 2108 Guests are viewing this topic.
...I might pull the 7404 it feeds into in the desperate hope there is a fault with the 7404 that's holding the output low. If it's the MK500P, then it looks like they are around, but not in great numbers. If you want a laugh - have a look at the one offering on eBay: https://www.ebay.com/itm/143112726483
Quote from: beanflying on February 14, 2019, 05:34:09 amGood job you have got further in a day than I 'felt' the need to in 6 months I have a few 7404 circa 1978 vintage IC's I could have included I think the ones I have might be a better match ... circa 1975, I think.
Quote from: mnementh on February 13, 2019, 01:44:51 pm That should be the full list, unless it was operated by a grad student sometime in its life. mnem*Currently doing a teardown on a $40 1000W computer PSU*Hoping its that easy, as I travel alot, no time to tinker with yet.
Think I am becoming a more of a sheetmetal worker. Bottom end of my 10 decade 25W Vishay's the other decade in the box will have paralleled 3W 200 for 6W for the 100 decade. Waiting on a 3 layer rotary switch instead of the two shown to share the current a bit better on the low range.It is now Little Creatures O'Clock and 25C in the shack
Quote from: bd139 on February 14, 2019, 08:23:46 amThink I’m going down the same route as you The stories I could tell. Wrong forum.
Quote from: med6753 on February 14, 2019, 08:49:34 amMy "Little Black Book" is all tucked away in the brain cells, never to be put to paper. When I die the evidence goes with me. Same here, makes me wonder if there ever was a little book in the first place. Strikes me as a rather dangerous thing to do, if SWMBO ever got her hands on it, we'll never be able to sleep at night for fear of never ever waking up again
Quote from: Specmaster on February 14, 2019, 09:48:37 amQuote from: med6753 on February 14, 2019, 08:49:34 amMy "Little Black Book" is all tucked away in the brain cells, never to be put to paper. When I die the evidence goes with me. Same here, makes me wonder if there ever was a little book in the first place. Strikes me as a rather dangerous thing to do, if SWMBO ever got her hands on it, we'll never be able to sleep at night for fear of never ever waking up again Not as bad as looking for the number of one of your old doobie hangouts and finding where she has gone and "graded" every entry in the damned thing. Some time. In the several months since you last looked in it. mnemDefine "crazy"?!?
The world is sadly full of Gorillas, maybe a cull is required
Spent some time today working on the 465B Channel 2 attenuator deck issue and I found the problem. And unfortunately it's fatal. Some gorilla has been in here before me and they stripped several of stand off screw holes causing inconsistent contact across the entire assembly. And the front plate is bent so the BNC must have taken a shot at one time and was replaced. So this whole mess has got to go. I'll keep and eye out for a cheap junker but this really isn't a priority and it will function just fine as a single trace scope.This isn't the first time I've had to clean up after this damn gorilla and I'm sure it won't be the last.
Quote from: Specmaster on February 14, 2019, 06:32:49 pmThe world is sadly full of Gorillas, maybe a cull is required Hey... some of us are just clumsy dwagons. mnemHave mercy...
Quote from: med6753 on February 14, 2019, 05:51:31 pmSpent some time today working on the 465B Channel 2 attenuator deck issue and I found the problem. And unfortunately it's fatal. Some gorilla has been in here before me and they stripped several of stand off screw holes causing inconsistent contact across the entire assembly. And the front plate is bent so the BNC must have taken a shot at one time and was replaced. So this whole mess has got to go. I'll keep and eye out for a cheap junker but this really isn't a priority and it will function just fine as a single trace scope.This isn't the first time I've had to clean up after this damn gorilla and I'm sure it won't be the last. And you won't consider re-tapping them just oversize and fitting a different screw ?
Quote from: Neomys Sapiens on February 13, 2019, 09:33:20 pmQuote from: med6753 on February 13, 2019, 05:32:49 amQuote from: Inverted18650 on February 13, 2019, 05:25:31 amEspecially considering what you lady does, I imagine your ears are also open. She's NYPD and I'm at minimum 75 miles north of NYC so unfortunately too far away to pick up. And I'm just running the whip antenna anyway. But it's good enough to pick up all of my county. Especially since one of the repeaters is only 2 miles away. Come on, BOS/PSB-Dx is a thing! Get a nice LogPer or a directional array! I was having Frankfurt and Karlsruhe regular except in inclement weather - with a discone!I'm sure the landlord will get a little pissy if I start erecting antennas on his roof.
Quote from: tautech on February 14, 2019, 07:24:39 pmQuote from: med6753 on February 14, 2019, 05:51:31 pmSpent some time today working on the 465B Channel 2 attenuator deck issue and I found the problem. And unfortunately it's fatal. Some gorilla has been in here before me and they stripped several of stand off screw holes causing inconsistent contact across the entire assembly. And the front plate is bent so the BNC must have taken a shot at one time and was replaced. So this whole mess has got to go. I'll keep and eye out for a cheap junker but this really isn't a priority and it will function just fine as a single trace scope.This isn't the first time I've had to clean up after this damn gorilla and I'm sure it won't be the last. And you won't consider re-tapping them just oversize and fitting a different screw ? Maybe a another screw with a locking nut on the other side?
I still don't know if she called them and compared notes, or if she just knew most of the same people as I did and guessed on the rest. Don't wanna know either. I just put it back in the back of my dresser and went on about my life as if I'd never looked in it. We lasted almost a year after that; and no blood was spilled. Well, none that wasn't voluntary. mnemLife is complicated.
Quote from: Specmaster on February 14, 2019, 07:55:57 pmQuote from: tautech on February 14, 2019, 07:24:39 pmQuote from: med6753 on February 14, 2019, 05:51:31 pmSpent some time today working on the 465B Channel 2 attenuator deck issue and I found the problem. And unfortunately it's fatal. Some gorilla has been in here before me and they stripped several of stand off screw holes causing inconsistent contact across the entire assembly. And the front plate is bent so the BNC must have taken a shot at one time and was replaced. So this whole mess has got to go. I'll keep and eye out for a cheap junker but this really isn't a priority and it will function just fine as a single trace scope.This isn't the first time I've had to clean up after this damn gorilla and I'm sure it won't be the last. And you won't consider re-tapping them just oversize and fitting a different screw ? Maybe a another screw with a locking nut on the other side?Blind holes in plastic.
Quote from: med6753 on February 14, 2019, 08:04:14 pmBlind holes in plastic.Fill with epoxy, redrill and retap?-Pat
Quote from: Cubdriver on February 14, 2019, 08:14:10 pmQuote from: med6753 on February 14, 2019, 08:04:14 pmBlind holes in plastic.Fill with epoxy, redrill and retap?-PatDepending on the plastic results can be disappointing without some type of primer to get a good adhere.Back when 465's were built they didn't have the good self tappers we do now.Med, some pics and screw diameter and length measurements please.
