Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 35801586 times)
Gertjan and 1462 Guests are viewing this topic.
« Reply #36300 on: August 05, 2019, 10:07:25 pm »
@med, I think I have just spotted another problem for you, take a look at the attached photo, the blue tubular cap? 2nd one down does not seem to be connected at all, the hole where it should be soldered to is open???  :-//
« Reply #36301 on: August 05, 2019, 10:16:59 pm »
This is getting real intense. It's looking more and more like I have a short in the board itself.  :palm: I've pulled and isolated just about every component hanging on the +15V bus and it's still shorted to ground. As much as I don't want to do it I'm going to cut the land in a choice spot where it branches in two directions and see what happens.  :scared:
Bring in a 15v (limit the current to say 1A) supply from your bench PSU and if you have either a thermal imaging camera or even a infra-red thermometer look around the board for signs of extra heat. If you don't have either, then you could use something like lighter fuel spread in areas on the board and components, (not too much as to make it a hazard) and then look for areas where the fuel evaporates quickest due to the increased temperature caused by the short circuit and then bingo, you'll have found the source of your problem.
I think IPA would probably be a better choice although it does evaporate pretty quickly on it own.
« Reply #36302 on: August 05, 2019, 10:17:37 pm »
Nope, they are connected.
« Reply #36303 on: August 05, 2019, 10:26:30 pm »
Yep it does and I think that maybe why I have noticed that quite a lot of YouTubers use lighter fluid because it will totally evaporate in a few minutes and does zero damage but will visibly evaporate far quicker in any areas where there is extra heat such as a short circuit.   :-+
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #36304 on: August 05, 2019, 10:34:09 pm »
This Dana 5330 voltmeter listed on ePay.com in the wrong category may be of interest here, it has nixie bulbs:
eBay auction: #254237958335
Damn you!!!   :P :P :P :P |O   :palm:
Hmm. Does that mean you own it now? Looking forward to the teardown. ;D
I was hesitant to answer this earlier, given my experience a year or so ago with the Fluke that I bought that turned out to be either lost or "failed testing and was scrapped" by the vendor (after having been listed and sold as "for parts or not working"  :rant: :rant: :rant: ), but it has now been marked as shipped, so I hope I am safe in saying yes, I bought it.  Why, you might ask?  Well, it has nixies in it, and I don't have one of THAT particular model yet.  Reason enough for a TEA addict.  (And I'd been doing kind of well with staying off the Bay of Iniquity, too, dammit!)
-Pat
« Reply #36305 on: August 05, 2019, 10:38:50 pm »
We'll be holding a vigil for your sanity in the chapel pending delivery. You figure what; Thursday-ish...?  :-DD
*agitating-ily*  >:D
Offline Cubdriver
  • Nixie addict
« Reply #36306 on: August 05, 2019, 10:53:09 pm »
ETA shows as between the 7th and the 9th, though of course it's not yet scanned into the system so that's just a guess for now...
-Pat
Offline 0culus
« Reply #36307 on: August 05, 2019, 10:56:07 pm »
I need more Nixie tubes. I was considering getting one of those fancy clock kits....but a nixie counter would be super tasty on the bench.  :-+ Currently the only nixies I have is that Nonlinear Systems voltmeter.
Offline Brumby
« Reply #36308 on: August 05, 2019, 11:14:45 pm »
When I read this:
This outcome was my first thought:
I made what I thought was a strategic cut in the land and BOTH sides still reading short to ground. I think I need to step away from this for today and start fresh in the morning.  :palm:
Offline Kosmic
« Reply #36309 on: August 05, 2019, 11:26:11 pm »
You could also use freeze spray. But it tend to leave water all over the place.
To find shorts, I had some success using y 34401a in ohms mode.
« Reply #36310 on: August 05, 2019, 11:42:11 pm »
Yeh, the advantage with the fluid method is that it is far quicker to locate without having to isolate one end of each part, find the dry spot, and that is where the heat is, jackpot.
« Reply #36311 on: August 06, 2019, 12:18:15 am »
No need to hesitate. Things happen, even after they've shipped. *sigh* If you've paid, that's close enough to ownership in this neck of the woods (until the situation changes, of course).
No, I'll not ask that. TEAmateurs might. :-DD
Yep, that's how four Nixie counters ended up finding their way to my lab. Beware! ;D
« Reply #36312 on: August 06, 2019, 12:28:43 am »
Speaking of which, I too had been taking an intermission from the evil online inlet of the sea. But then I got a few things on the way to my dock: a probing thing, a vibrating thing, and a thing with 14 LED digits. Coming soon to a post near you...
Offline 0culus
« Reply #36313 on: August 06, 2019, 12:32:58 am »
Here's something some of you might be able to answer: I have a nice set of Teledyne drafting tools. Unfortunately, the foam in their case badly deteriorated and created some kind of chemical reaction with the metal that was touching it, causing pitting. I've removed the instruments and cleaned them as best I can, but I'd like to replace the foam with something modern, but it needs to be easy to cut so the nice little spots for the instruments can be recreated. Any recommendations? It appears the foam in the bottom of the case is about 0.6" (1.524 cm) thick, while the top is about 0.4" (1.016 cm) thick.
Offline rhb
« Reply #36314 on: August 06, 2019, 12:59:55 am »
Plaster of paris and velvet.
Offline 0culus
« Reply #36315 on: August 06, 2019, 01:20:02 am »
Interesting....do tell more. Mold with plaster and cover with velvet?
« Reply #36316 on: August 06, 2019, 01:21:09 am »
You can also use styrofoam sheets and cover with your choice of fabric. A potentially messy and unsatisfactory, but strangely intriguing, option could be foam caulk (white stuff). It's easier to control and expands less than foam insulation (yellow stuff).
I'd go to the art/craft supply store and get some high-density foam.
« Reply #36317 on: August 06, 2019, 01:24:34 am »
Bitch Lives.
I'm goin' to bed.
Bout time  :-DD Yes I am a biatch .....
Enjoy the speediness.
Offline Cubdriver
  • Nixie addict
« Reply #36318 on: August 06, 2019, 01:25:13 am »
Only FOUR?  ::)   ::)
Slacker!   :P  >:D >:D >:D
-Pat
The following users thanked this post: mnementh, 0culus
« Reply #36319 on: August 06, 2019, 01:31:29 am »
Who saw THAT coming...? *raises hand*
 :popcorn:
Offline Kosmic
« Reply #36320 on: August 06, 2019, 01:32:12 am »
I don't isolate anything. Just connect the lo terminal of the multimeter to ground and use the hi terminal to probe following the rail path. The point where the resistance is the lowest is usually really close to the short you are looking for.
« Reply #36321 on: August 06, 2019, 01:51:49 am »
Only FOUR?  ::)   ::)
LOL! Counters started much later than more voluminous collections such as DMMs. >:D
Offline Cubdriver
  • Nixie addict
« Reply #36322 on: August 06, 2019, 01:59:30 am »
Only FOUR?  ::)   ::)
I'm afraid to count my counters.   :o
« Reply #36323 on: August 06, 2019, 02:10:00 am »
Yes, an advantage of having only four. :-DD
Offline Cubdriver
  • Nixie addict
« Reply #36324 on: August 06, 2019, 02:41:52 am »
Touché!   :-DD :-DD :-DD
-Pat
