Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36278373 times)
Vgkid, Jambalaya and 5703 Guests are viewing this topic.
« Reply #40300 on: October 02, 2019, 01:45:02 pm »
It's all becoming very clear to me. In addition to the 3d printer I would need to buy/build a top tier PC in order to run a decent CAD program (more expense) and be stuck in that ever lasting loop of "More Power Scotty!!" just like a gamer?
And there you go. Bd just dropped 750 either pounds or dollars (don't matter which, it's a lot!  :-DD)
That's not a rabbit hole.....it's a giant sinkhole.  :o :o :-DD
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #40301 on: October 02, 2019, 01:52:49 pm »
Don't forget the NanoVNA - the latest gizmo you need to be a Kool Kid.
and so the list grows (I included empty slots for your conveinience)
1. 3D Printer
2. New powerful PC with all the trimmings
3. NanoVNA
4.
5.
6.
7.
« Last Edit: October 02, 2019, 01:55:46 pm by xrunner »
« Reply #40302 on: October 02, 2019, 01:53:51 pm »
Don't even go to NanoVNA territory. I'm down a kidney already  :-DD
As much as it's against the law in these parts, a chunk of test gear may have to depart for this one.
« Reply #40303 on: October 02, 2019, 01:59:28 pm »
1. 3D Printer
3. NanoVNA
4.
5.
6.
7.
I think I'll remain an outcast....a rebel with no cause.  :-// :-DD
Online Zucca
  • EE meid in Itali
« Reply #40305 on: October 02, 2019, 02:01:06 pm »
LOL my sister-in-law was going to do one of those to buy a new car  :palm:
« Reply #40306 on: October 02, 2019, 02:01:46 pm »
But But just look at all the prints you could make  >:D https://www.thingiverse.com/search?q=middle+finger&dwh=305d94ad886823f
« Reply #40307 on: October 02, 2019, 02:02:29 pm »
On it  :-+  :-DD ... fucktopus coming soon. That'll turn him  :-DD
BTW Ender resume got tested half way through this print. Someone unplugged it instead of the hairdryer  :palm: :palm: :palm:. Worked fine!
« Last Edit: October 02, 2019, 02:04:51 pm by bd139 »
Online xrunner
« Reply #40308 on: October 02, 2019, 02:06:43 pm »
Hmmm ... I have a blue PLA but it's not quite the Tek blue I would need for it to be perfect.  :-DD
« Reply #40309 on: October 02, 2019, 02:18:01 pm »
That was me. I sent a text to your Daughter.  >:D ;D
« Reply #40310 on: October 02, 2019, 02:35:32 pm »
Well you keep printing your fucktopus while I go to the local home center and get some lumber and do a project the old fashion way...with saw, drill, and hammer.  ;D
« Reply #40311 on: October 02, 2019, 02:47:50 pm »
We'll see what Mr Octopus has to say about that shall we?
 :-DD
The following users thanked this post: xrunner, Carl_Smith, mnementh, beanflying
Online xrunner
« Reply #40312 on: October 02, 2019, 02:48:30 pm »
Bwahahahahaha!  :-DD
Offline nixiefreqq
« Reply #40313 on: October 02, 2019, 02:52:55 pm »
quick update on the hp8569b.  (with apologies to indiana jones)
"attenuators.......why is it always attenuators?"
everything else is lookin' pretty good.  but the input attenuator goes 0,0,20,20,40,40,60,60  when it should go 0,10,20,30,40,50,60,70.
will go back to the basement and fettle.  (is that the proper use of the word?)
might even have to rtfm.
free range primate
Offline 0culus
« Reply #40314 on: October 02, 2019, 02:56:29 pm »
Those attenuators are made like Swiss watches...lots of small parts very finely put together. Magnification is extremely helpful. A common problem is the disintegration of the little o-rings that cushion the action of the solenoids. Assuming, of course, no one transmitted into it and burned up the pads.  :palm:
The following users thanked this post: nixiefreqq
Online Mr. Scram
  • Display aficionado
« Reply #40315 on: October 02, 2019, 02:58:05 pm »
The overhangs on that octopus look pretty decent. Still a bit of stringing around the fingers though.
« Reply #40316 on: October 02, 2019, 03:02:56 pm »
Yeah. There's a small rim where the power went out as well. Not too bad though. I did have to clean that up slightly this time.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #40317 on: October 02, 2019, 03:13:45 pm »
I know these attenuators come up frequently on the HPAK mailing list, and based on what I've heard there the issue is often actuator o-rings.  I personally have not yet had occasion to open one up, but your message just prompted me to do a search because it piqued my curiosity as to what exactly the o-rings DID in the device.  This video seems to explain it well; hope this helps.
Good luck with your new beast!
-Pat
The following users thanked this post: bitseeker, nixiefreqq
Offline worsthorse
  • aina varma, usein väärin
« Reply #40318 on: October 02, 2019, 03:21:26 pm »
No space here either. My printer lives on the fireplace in the living room  :-DD
mine (an entry level ender) is going to go on a folding table in the dining room. i am just holding off until i get through the rickreall hamfest...
Offline worsthorse
« Reply #40319 on: October 02, 2019, 03:29:52 pm »
Interesting. My 191 is in a slide in cabinet like your 106 and also the recently acquired 114.
I think the sine and square wave generators were often sold together in a rack mount case (there was one pictured earlier in the thread). Then people started taking them out of the rack and using the shell you see on mine. It is not really well-thought out... it is just a wrapper and isn't fastened to the unit inside.
Did you have to replace the caps in the low voltage supplies? I did. They were really crusty.
No, they were in good shape on this one, so I left well enough alone.  ;D
I didn't do a full calibration as you did. I did some spot checks and found the unit to be pretty much on the mark so I left it alone.  :-+
There's a quick check out procedure that suggests doing what you did. My OCD combined with curiosity didn't allow me to follow it. For the second 191, I will do that and avoid the twiddling back and forth unless it is necessary.
« Reply #40320 on: October 02, 2019, 03:38:34 pm »
Exactly. I’m now printing a swearing octopus.   :-+
Once the initial excitement dies down, all of these little bits that you're producing will all find their way into the trash bin before too much time has gone by I expect  >:D
I needed another to send to a 'special' person  >:D
Ohh, thanks, just what I needed  :-DD
« Reply #40321 on: October 02, 2019, 03:39:13 pm »
 :-DD
I remain unmoved. Although my $0 balance credit card just caused my wallet to burst into flames.  :wtf: :scared: :-DD
« Reply #40322 on: October 02, 2019, 03:44:29 pm »
Makes sense and I notice that yours does have the hole in lower left which would contain the thumb screw to secure it into a rack. Apparently someone removed it completely.
« Reply #40323 on: October 02, 2019, 03:53:22 pm »
Octopus has more birds: https://www.thingiverse.com/thing:2765929
Have decided to buy a desktop PC. Keyboard just gave out on my T470 already ffs. Fortunately still under warranty so that's going back. Have rammed a USB keyboard in it for now and will order a desktop for later.
Ryzen it is... and custom build. Good job I just got paid up for some work  :palm:
Finally, sense has prevailed in Twickenham, laptops are a convenience thing, desktops are serious items and the Ryzen is a good starting point   :-+
« Reply #40324 on: October 02, 2019, 03:58:05 pm »
You want to buy a lightly used RX580 Mister  >:D Depending on how much poke you want there is some very good deals going on the last gen 2600 and 2600X if you need to shave a $
Looking at Ryzen 5 2600X actually.  :-DD. 6 cores and 19Mb of cache glory.
I haven't actually built a PC from scratch since 2005 believe it or not.
What operating system will you go for with that? Only 6 cores, pah, my ancient AMD FX has 8 cores, problem is however that hardly any software I have can use them all  :palm:
