Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14984656 times)
Robert763, mnementh and 177 Guests are viewing this topic.
« Reply #41525 on: October 20, 2019, 05:27:13 pm »
FYI, Siglent are working on a manual Cal procedure so that owners can tweak measurements once their SDM's have aged. Not all measurement types will be tweakable AFAIK, just those for which you budding volt/ohm/amp nuts carry the typical standard references.
Actually, must check how things are progressing with this manual Cal ..................
That would be great! Keep me informed. Thanks  :-+
Online tggzzz
« Reply #41526 on: October 20, 2019, 07:41:28 pm »
Now I need to make myself a couple of pieces of Vegemite toast.
That shit sounds nasty.
Nasty is too strong a word. "Too sweet" is appropriate for those accustomed to The Real Thing: Marmite  >:D
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #41527 on: October 20, 2019, 08:06:46 pm »
the 90kg wakes up..  :phew:
https://www.wellenkino.de/e108/test-1.mp4
next problem: bandwith 4.5kHz missing (solding again..)
The following users thanked this post: Cubdriver, med6753, Kosmic
« Reply #41528 on: October 20, 2019, 08:10:54 pm »
Good deal! Sounds like the BFO is now working, correct?
Offline Martin.M
  • in Tek we trust
« Reply #41529 on: October 20, 2019, 08:13:02 pm »
yes. I have forgotten a bridge on the coil
« Reply #41530 on: October 20, 2019, 08:18:03 pm »
To me anything classified as "too sweet" is nasty to me. I've never been a fan of real sweet stuff. Things that make your teeth cringe when you bite into it. Even before I was diabetic.
Online mnementh
« Reply #41531 on: October 20, 2019, 08:22:58 pm »
;D
And now they make units with higher res that fit in a cellphone shell for 1/20 the cost. Such is the march of progress...
The build and image quality of those isn't quite the same though.
I thought I saw the entry-level FLIR with native VGA res at around $1k a while back...? What’s the diff; pixel-by-pixel accuracy? :-//
 :popcorn:
« Reply #41532 on: October 20, 2019, 08:30:59 pm »
Marmite is very close in consistency to cigarette tar in any reasonable concentration. Doesn’t taste much better either. Best use for it was fucking up a rental we had. We decorated the place then he kicked us out because it was worth more. So we redecorated it again with marmite.
Online Kosmic
« Reply #41533 on: October 20, 2019, 09:13:26 pm »
;D
 :popcorn:
The cheapest Flir 640x480 camera on Amazon is like 41k$ can
https://www.amazon.ca/FLIR-T620bx-Camera-Resolution-25-xb0/dp/B00GJYV690/ref=mp_s_a_1_6?keywords=flir+camera&qid=1571605875&sr=8-6
Offline Mr. Scram
  • Display aficionado
« Reply #41534 on: October 20, 2019, 09:33:07 pm »
 :popcorn:
Less noise, more consistent performance, likely a better framerate. It's a different class of instrument and though technology marches on thermal imaging doesn't appear to be moving as quickly as some other areas.
« Reply #41535 on: October 20, 2019, 09:58:33 pm »
The mind boggles as to how and why you ended up tasting cigarette tar  :-DD
Offline worsthorse
  • aina varma, usein väärin
« Reply #41536 on: October 20, 2019, 10:00:06 pm »
My "hope to find" list for the hamfest was short: GR874 and N adapters to use at my bench. My first tour round the selling tables revealed a cardboard box full of GR874s. Next to it was a mixed box of adapters, with a goodly number of N type. Here's what I scooped up:
But I not only found a few pounds of adapters, I picked up an almost complete set of Tektronix GR attenuators (2X, 5X, 10X), oscilloscope and DMM voltage pickoffs, a 10% sampling coupler, and a paired 50 ohm load and short:
There was a capacitive coupler in the box, too, which I forgot to put in the pile. I didn't realize that until I got home. |O
The grand total?  23USD.  I couldn't believe it and accepted the ask without further negotiation!
The seller offered to sell me the rest of the GR box for another ten bucks. I passed on it, though with some misgivings.
Photos of the impulsive TE purchases to follow.
The following users thanked this post: Kosmic, 0culus
Online mnementh
« Reply #41537 on: October 20, 2019, 10:04:26 pm »
 :popcorn:
Okay... a little research shows the difference.
The ones I was thinking of have progressed; they're a lot cheaper now too... but the actual hardware isn't what I thought it was. Way lower native IR res than the one Kosmic has, and due to the fact it multi-scans and stitches the images together to make a larger image, net is less than 8fps. :o
That kindof puts Kosmic's score in much better perspective.      :-DD
 :popcorn:
« Last Edit: October 21, 2019, 04:04:50 pm by mnementh »
« Reply #41538 on: October 20, 2019, 11:13:49 pm »
The  -- hp -- 428b verification procedure is steadily and slowly advancing. Built a little voltage divider box for the cal from a plastic mini Hammond box, 3 Chinesium binding posts and 2 hand-selected Vishay 1K 1% resistors that the -- hp -- 974A declared were 0,1 Ω from each other. (428b manual says one should select these carefully for similar values.) The  -- hp --427a (hi, bd139!) said there was 22mV on the centre of the divider when used as directed in the oscillator circuit, which is in-spec ("under 50mV"). Oscillator frequency is now 40KHz, not 39980Hz (which was also in-spec, though), according to the -- hp -- 5221A (yes, Nixies at work here. Wonderful.), and the oscillator level is 8,02V, according to the Marconi VTVM, which is in-spec. My ScopeMeter was very finicky and did not want to auto-trig on the waveform; it took almost CRO amounts of fettling the controls to get it to display anything sensible.
All vintage instruments have had a modern sanity check made in parallel, because even if the person with two clocks always wonders which one is right, the observation that they roughly agree the next day too is somewhat reassuring. The  -- hp -- 974a really is an excellent DMM, steadily getting a good measurement off of the DUT.
All in all, so far every measurement has been within tolerance. This instrument must have been put aside at a very young age, probably because it blew fuses, and then just been a Sleeping Beauty waiting for someone to take it to bits and figure out what was wrong with it.
This is bordering on obsession, but I've got my reasons, and I like to think they're on track for a group of T.E.A. afficionados...
Offline 0culus
« Reply #41539 on: October 20, 2019, 11:21:26 pm »
Dang, that's a nice grab. I was able to restrict myself to buying radio related stuff this time.  :-DD
« Reply #41540 on: October 21, 2019, 12:26:11 am »
Mmmm Vegemite  ;D Unless you grow up with it the taste buds will take some acclimatization.
Given a serving is maybe 1-2g and the Sugar content of Vegemite is circa 2% (local Marmite is over 10% unlike the sour UK 1% Version  :-DD ) it is unlikely to ever cause a diabetic reaction.
Offline Neomys Sapiens
« Reply #41541 on: October 21, 2019, 12:30:31 am »
Given that we transferred some antipodes-to-europe just a few months ago, indeed.
Online mnementh
« Reply #41542 on: October 21, 2019, 12:35:20 am »
Yup... still have no idea what perverse sense of conservatism made you pass on the other half of that pot o' gold, but STILL...       :-DD
(Kosmic's Jammy above is technically for yesterday, so I feel justified presenting two in one day with no remorse ;) )
« Reply #41543 on: October 21, 2019, 12:35:57 am »
More volt-nttery. Today's mission is to certify the Siglent SDM 3055 as my “Bench 2 Standard”. I've had this Siglent for almost a year now and while I like it overall there are a few items that annoy me. First, it doesn't match up exactly with either AD584-M references. It's always measured consistently low as seen as the chart. It's close but no cigar. Sloppy factory calibration or are BOTH references off?  :-// Who knows but to me 5.5 digits is overkill anyway.  ::) Second, I found that there is no difference in warm up times from either a cold start (power completely off) or power up from standby. Takes at least 12 hours for both for best accuracy. That tells me that standby does not keep the internal voltage reference hot which makes it totally useless and just consumes power. Perhaps Tautech can confirm this.
For this exercise the Siglent was powered up for 48 hours. It has confirmed via cross checking that the Fluke 8050A is a valid bench 1 standard. And it further convinced me that for my needs 4.5 digits is more than enough. 5.5 digits is overkill and I'll never venture into 6.5 digit territory. Especially when I see these 6.5 digit and greater DMM's all stacked up and connected to the same source and all reading differently.  :wtf: That would drive me to drink.
When you get into 4th digits and above you will really need to start looking at spec & datasheets for long and short term drift plus a bunch of ethereal fudge factors. Your Siglent for example may now have NEARLY enough hours on it for the reference to have settled to a more stable number but I doubt your AD584's have.
My two Agilent/Keysight 6 1/2 digit meters have opposing temperature coefficients of seemingly similar numbers against an my ovenised references. At 20C they are within 2ppm. Still both within spec but something I recognize. If that same drift at 5C shift in temperature was applied to your meters for example it would be see a shift in your meter if they were similar shift a LSD or two. Add that to a cheap and cheerful but unknown reference (other than assuming it matches the datasheet) you could easilly slip several more COMBINED.
This is WHY YOU NEED 6 1/2 Digits to test your others to then be uncertain about it :-DD
« Last Edit: October 21, 2019, 12:37:40 am by beanflying »
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #41544 on: October 21, 2019, 12:43:45 am »
Absolutely agree 100% med needs 6.5 digits for sure no question about it.  :-+
« Reply #41545 on: October 21, 2019, 01:07:41 am »
The bridge is ok.  :phew:
858412-0
30000pF 0.5% Koweg Capacitor
858416-1
20kOhm 0.1%
So, into the breach again - looking for everything that fits that Lemo. (I need 4W tweezers,4W clips and a SMD-Adaptor. Will consider altering other makes, will not consider crap)
The following users thanked this post: xrunner, beanflying, Kosmic
« Reply #41546 on: October 21, 2019, 01:11:32 am »
And we all know where this apparent logic goes  ::) 3458A and or regular certified Calibration and chasing sub PPM :-DD
« Reply #41547 on: October 21, 2019, 02:36:09 am »
Between that nasty looking vegemite and the 6.5 digit DMM's I swear you Aussie's are trying to kill me with either puking out my guts or having a stroke.  :-DD
« Reply #41548 on: October 21, 2019, 03:10:39 am »
Jump on in 6 1/2 needn't cost you a Kidney  ;) https://www.ebay.com/sch/12576/i.html?_from=R40&_nkw=3456a&_sop=15&_blrs=recall_filtering and I am happy to ship you a jar of Black Gold for free  :-DD
Offline ArthurDent
« Reply #41549 on: October 21, 2019, 03:29:00 am »
I have to admit that I've eaten Marmite for years, plus I love their commercials.
https://youtu.be/xkn3ZQoOa40
https://youtu.be/hC_r-dC4PqA
« Last Edit: October 21, 2019, 03:33:39 am by ArthurDent »
