I have seen Bananas straighter than this POS molding. Time for a beer to decide what to do about it and even if it will help keep the zebras in the right spot.
$60+frt for the frame and $230 for the LCD if it needs it
Thin strip of high density foam ?
Full strip clean of zebras, contacts etc and re assembly yielded the same LCD fault. As it is only a single path and the lower bars on the upper digits it is still translatable.
The Zebras are held in position by the four white clips to the pcb and any cantilevered force from the three
screws holding the board in the case. Evrything at the top of the PCB is flapping in the breeze between the outer case.
It is still possible that a PCB or the outer frame warp is stopping the zebras from contacting bit I am leaning toward the LCD having a dud track.
I think it suffers from being the bastard love child of Fluke and Martel who forgot to consider some basic mechanical design considerations.
