Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37511388 times)
0 Members and 2027 Guests are viewing this topic.
« Reply #50475 on: February 22, 2020, 11:18:48 pm »
Been researching whether I made a wise purchase with the Extech EX530 (branded Rapid) and it seems to be reasonable OK, if a bit slow on the updates at 2 updates a second and the continuity is not the worlds best but is usable, however it is very tough by accounts as this video shows, not that I would personally dream of treating any of my meters in this fashion, but it it good to know that will take the odd knock from time to time.  >:D
bd, would you dare to try this with your little Brymen?  >:D :-DD
« Last Edit: February 22, 2020, 11:20:26 pm by Specmaster »
Offline Mortymore
  • Country: pt
« Reply #50476 on: February 23, 2020, 01:15:37 am »
The Extech people must learn do a proper torture test with the Master himself
« Reply #50477 on: February 23, 2020, 01:25:49 am »
Agreed, but they weren't out to destroy it, just to show that it can take a fair amount of punishment in its stride and the only thing that is likely to happen to most meters is the occasional drop from a bench etc to the floor, not being driven over or thrown against a wall like a ball.  :-DMM
Plus of course there is a vast price difference between the Fluke and the Extech so its hardly a fair comparison to judge it by.
« Last Edit: February 23, 2020, 01:28:06 am by Specmaster »
The following users thanked this post: Mortymore
« Reply #50478 on: February 23, 2020, 02:52:26 am »
Servicing the fan motor on the 535A. For the first 5 minutes after power up it would rattle and run at half speed. Once heated up would spool up to normal speed with no more rattle. So the sleeve bearings must be dry.
The fan is held on the motor shaft with a allen key which came out fine but the fan is pretty much seized to the motor shaft. I didn't want to pry too hard so I left it. In addition the motor is hard wired in so had to let it hang out as shown.
I found a date! June 3, 1966. That explains a number of things with this 535A. First, the BNC's rather than UHF connectors. Tek converted to BNC in 1963. Second, early 535A's had wax caps and “bumble bee” caps both of which went leaky. This one has epoxy caps which last forever. So this is a late version of the 535A. It went out of production in 1972.
I was able to get the backside of the motor apart and clean it up and re-oil the sleeve. I have a long pin point oiler so I was able to get to the front sleeve although couldn't clean it. Reassembly and the fan comes up to speed immediately with no rattle. Should be good for a long time.
Tomorrow continue with the filter cap change.
The following users thanked this post: mnementh, Mortymore, bd139, nixiefreqq, Kosmic
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #50479 on: February 23, 2020, 02:53:33 am »
A real fan with METAL blades!  :-+
« Reply #50480 on: February 23, 2020, 02:56:44 am »
And it's kinda loud but doesn't bother me. I think that's because I sleep with a box fan running all year long. I started doing that 30 years ago when I worked a 2nd shift and had to sleep during the day. The fan drowned out day time noise. I continue doing that to this day.  :-+
Offline Mr. Scram
  • Display aficionado
« Reply #50481 on: February 23, 2020, 02:59:32 am »
That's how you lose a finger or two.
« Reply #50482 on: February 23, 2020, 03:00:34 am »
Only if you're stupid.  ::)
Offline Mr. Scram
« Reply #50483 on: February 23, 2020, 03:04:54 am »
That's how I lose a finger or two.
The following users thanked this post: mnementh, WastelandTek, bd139
« Reply #50484 on: February 23, 2020, 03:06:17 am »
Oh well, can't fix stupid.  :-DD
« Reply #50485 on: February 23, 2020, 04:30:43 am »
Depends on how good your lawyers are when negotiating the service contract. If you have it set up so you counterbill for downtime, and your definitions for "downtime" are granular enough, you can make money on the service contract.  ::)
Happened to one of the ASPs I subcontracted for; the end-client tried to counterbill us for more than the service call claiming I was late to site, when I provided exemplary less-than-1-hour response time. The only thing that saved us was the fact I anally SMS-documented every step in their obscenely convoluted security process, with arrival time in front of the rack to the minute and every ridiculous step their bridge associate made me take in troubleshooting before admitting the fault was in fact infrastructure rather than the hardware we were responsible for.  |O
When the WO for said infrastructure work came across the wire the next day, I noted the address and politely declined citing :bullshit: allergies.  :-DD
Guess my  techy-sense was tingling on that one; it wasn't until almost 2 weeks later the counterbilling nonsense went down. :palm:
*currently trying to un-fuckerize a Android TV box with UI defaulted to Chinese*
You can rest assured this kind of service provider has excluded any responsibility they could.
I was the tech onsite for the service provider; I know half the company personally.  The end-user data center belonged to one of the telecoms big enough to own senators.
Not exactly even footing on the legal side of things, I’m afraid; as I said, the only thing that saved the WO was my egregious note-taking.
 :-/O
« Reply #50486 on: February 23, 2020, 05:55:09 am »
Now you need to remove the rust with a sander and the wheels to polish them up... We want mirror finish!
Mirror Mirror!
Those wrenches are black from phosphating, so no.
Offline Brumby
« Reply #50487 on: February 23, 2020, 06:17:39 am »
TEA Enabling PM sent to @Brumby so my Sunday morning is off to a good start  >:D
Yes.  I only got to see it just now - and if the seller was closer, my wallet would be lighter already.  Shipping doubled the price of some things I'm interested in - but that shipping cost would not be unreasonable if the items were packed properly.
I'm scared to ask if they combine shipping on multiple purchases.  My wallet is cringing.   :scared:
« Reply #50488 on: February 23, 2020, 06:34:06 am »
Based on what I got from the same seller last time very amenable to combined shipping or even arrange your own  >:D Assist Assist  :-DD
Offline McBryce
« Reply #50489 on: February 23, 2020, 09:12:32 am »
Page 2019! "We're in now-now" and we'll soon be passing ourselves.
Everyone: But, we're not in 2019 anymore.
Me: I know, but if I don't post now, it'll be already be then and then it's too late.
Ok, now we really are in now. And I quoted you... Automatically taking you from 2019 into 2020. Forum time-travel!
McBryce.
« Reply #50490 on: February 23, 2020, 09:35:59 am »
And it’s definitely a redneck hamfest this one. Just seen someone driving a porcupine into a lamp post  :palm:
Edit: uniformed raynet whackers as well  :palm:
« Last Edit: February 23, 2020, 09:46:15 am by bd139 »
« Reply #50491 on: February 23, 2020, 10:14:10 am »
It's early in the morning and first cup of coffee hasn't taken effect yet. So break this down for me. What the hell are you talking about?  :-// :-DD
Edit...See, even your fellow countryman doesn't know either.  :P
« Last Edit: February 23, 2020, 10:21:19 am by med6753 »
Offline WastelandTek
« Reply #50492 on: February 23, 2020, 10:21:42 am »
livin' in the future man
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
« Reply #50493 on: February 23, 2020, 10:23:54 am »
The Uniform enhances the Power output of their radios and further gives the wearer disillusions of Authority  ::) Generally compensating for other small things but that would just be conjecture  ;)
« Reply #50494 on: February 23, 2020, 10:27:15 am »
Say what? You loyal subjects of the Monarchy are speaking in code today. This Yank ain't gettin it. I need more coffee.  :palm:
« Reply #50495 on: February 23, 2020, 10:33:10 am »
Porcupine  = car with more antennas than necessary. Usually because the guy who drives it can’t see or remember the ones he already put on it.
Anyway that was total shit. Some decent stuff but the prices were fucking stupid and they wouldn’t budge. Going on the shit list that one. Biggest complaint is the fund raising trash table which had the fine example of a Farnell L30 which was “working” for £20. Working consisted of missing captive mains cable, missing the meter needle and a knob.  :palm: :palm:. Missed a Keithley 4.5 digit LCD meter someone got for £20 which was a bit high for “untested” IMHO.  :--. Bought nothing.
Time to go for a shit and a walk now
« Reply #50496 on: February 23, 2020, 10:35:06 am »
The disloyal subjects are just as bad!
Skip to 2:05
« Reply #50497 on: February 23, 2020, 10:44:54 am »
Ding! OK, now I get it. Hamfest but the prices sucked. Some Hobo with too many antennas crashed his ride.
Now I can go on with my life full of confidence.  ;D
Offline tggzzz
« Reply #50498 on: February 23, 2020, 11:01:01 am »
Rainham/Chatham? Bit of a hike for you: chose longer faster or shorter slower :(
Presumably a lot military (= likes uniform) types.
Pet hate when I was a kid: men that wore blazers with an "important" badge[1] and expected that to engender some respect in other people. Maybe before the 60s, but counterculture stopped that kind of nonsense!
[1] like a school uniform for "adults", e.g.
« Reply #50499 on: February 23, 2020, 11:09:08 am »
Well, you Brits have always been big on "Class" and who has it and who doesn't. You still engender people with "Sir" and related stuff. It reminds me of the caste system in India. And all one has to do is look at the sinking of the Titanic and see "Class Structure" in action.
Edit...and I have no class.  :-DD
« Last Edit: February 23, 2020, 11:11:47 am by med6753 »
