Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36198697 times)
0 Members and 1980 Guests are viewing this topic.
Offline nixiefreqq
« Reply #51075 on: March 01, 2020, 06:32:02 pm »
hey cub
any ideas about cross compatibility between the different versions of hp nixie display boards?
for sure someone at a depot somewhere had a table for which boards would work in which chassis
(for a short time back in the mid 80's i worked with the depot in san diego responsible for all navy R1051/T827 an/wrc-1 radios.  they bought those radios over a 30 year period and each radio was full of "6 pack" cans that worked in some chassis but not others.  everyone involved had a copy of the compatibility table)
i have always had enough spares that it was never an issue with hp nixie gear.
I've never really explored that, but you have piqued my curiosity.  I may ask about boards for one of the counters as I snagged a relatively rarely seen one off the bay a few months ago.  They guy had three, and of course showed a pic of the best equipped one.  I ordered, and got one without the extra two digit option, and of course by then all had sold.  I was annoyed and buried it for later consideration, and forget exactly which one it was, but perhaps it may turn out that you have some boards for it.  Of course I was away when it arrived, and then didn't open it for a few weeks after I got home, so the time frame to bitch on the bay had expired.   :rant:
-Pat
well....... that would be a disappointment.
am always willing to dive into my box-o-junk for anyone proven to NOT be a nixie rapist.
free range primate
Online factory
« Reply #51076 on: March 01, 2020, 06:36:16 pm »
hey cub
-Pat
Would that be a 5246L? if yes you will need two more low speed display assemblies, I can't remember if a couple of extra counter boards are also needed.
Offline nixiefreqq
« Reply #51077 on: March 01, 2020, 06:38:41 pm »
Sadly, I think the 3444A plug-in is blown up somehow, likely the amplifier based on the service manual troubleshooting procedures. It only works as a voltmeter in the 10,100,1000V ranges. All other ranges and functions appear to be blown.
ouch!
my plug in had an exploded (literally) precision shunt resistor which had killed one amps range.  made up a bodge with a bunch of series/parallel resistors that sort of matched the original (am not proud of it, but sometimes you do what you have to).
free range primate
« Reply #51078 on: March 01, 2020, 06:39:59 pm »
Yep you're quite right.
What happened to you last night on discord, you were there one minute and then disappeared?
I was MTing while on Discord; shopping magnetic sync cables is a massive time-sinkhole.  |O VPN hiccup booted me, then I forgot to log back on.  :palm:
*currently suffering MAME-overload*
« Reply #51079 on: March 01, 2020, 06:48:33 pm »
...nixie rapist.
Close cousin of the ubiquitous "tube nonce"?  :-DD
« Reply #51080 on: March 01, 2020, 06:51:16 pm »
*back slowly away...*
You do not want none o' dat gittin' on ya... :o
Offline nixiefreqq
« Reply #51081 on: March 01, 2020, 07:10:27 pm »
...nixie rapist.
am unfamiliar with the term.
BUT anything that scares the dragon would surely terrify me.
is it something to be googled?  or best left alone?
free range primate
« Reply #51082 on: March 01, 2020, 07:12:40 pm »
UK slang for pedophile and in London anyone who violates something beyond any reasonable boundary.
Edit: btw above is a section from a TV series called "Life on Mars" which was rather good.
« Last Edit: March 01, 2020, 07:15:00 pm by bd139 »
Offline 0culus
« Reply #51083 on: March 01, 2020, 07:13:40 pm »
ouch!
I can't see any visible signs of a catastrophic failure like that. However, neither mV range responds to input (but it can be zeroed with R31), no ohms range responds to input, and no amps range responds to input. This may point to a failure in the amplifier circuit according to the service manual, but I don't have any card extenders and so getting to some of the test points described will be impossible.
« Reply #51084 on: March 01, 2020, 07:13:54 pm »
I'm all in favor of raping parts for vintage test equipment but NOT for audio purposes.
My rationale.....the audiophools take the parts, usually just vacuum tubes, and scrap the rest. Which is BS because almost all the tubes they take are available today from other sources. Regardless of their claims that the old stuff sounds better.
« Reply #51085 on: March 01, 2020, 07:15:41 pm »
Yep. You get things like this here: https://www.ebay.co.uk/itm/143543090958
Check the guy's other sales.
Typical example of the cunt's victims:
https://www.ebay.co.uk/itm/143529937627
And yes there has been Tek stuff sold by him.
« Reply #51086 on: March 01, 2020, 07:21:37 pm »
May he burn in hell...twice.  :rant:
The following users thanked this post: Cubdriver, Specmaster
« Reply #51087 on: March 01, 2020, 07:23:51 pm »
I was thinking "may he insert three 12AU7's into his bottom and sit down too hard"
« Reply #51088 on: March 01, 2020, 07:44:48 pm »
That will work too.  :-+
« Reply #51089 on: March 01, 2020, 08:39:43 pm »
Off-topic, but interesting to some at least. I mentioned last night on Discord that I was going to North Weald Airfield to take some photos of the Gnats Display team doing some test flights after winter maintenance, turns out only 1 out of the 3 gnats was ready and here just a handful of shots taken today from the taxiway. I was unable to get any closer to the main runway so any shots of it in the air would not be worthwhile given the plane is so small to start with. Anyway enjoy them, note it is getting difficult to get anywhere there at the moment to grab photos with a relatively clear back ground owing the erection of a pretty large Police Helicopter compound and hanger and next door the construction of a similar setup for the Essex and Herts Air Ambulance.
« Last Edit: March 01, 2020, 11:02:18 pm by Specmaster »
The following users thanked this post: BU508A, med6753, mnementh, Mortymore, Neomys Sapiens, bd139, AVGresponding
Online factory
« Reply #51090 on: March 01, 2020, 09:25:09 pm »
for anyone who cares.
a 5212L-4A display board will work in an HP3440a otherwise filled with 5212-6016 boards.
closed my eyes and flipped the switch.  it did not blow up, and displayed normally.
(that is my sum total contribution to the compatibility table)
edit  factory added the table from the manual while the freqq was typing.........cool beans!  (rtfm?)
There are a couple more for the later 002/003 options, will update my table later.
Updated the table of 5245L display boards;
https://www.eevblog.com/forum/index.php?topic=81471.msg2943690#msg2943690
The following users thanked this post: Ero-Shan, beanflying, nixiefreqq
Offline 0culus
« Reply #51091 on: March 01, 2020, 11:46:39 pm »
Good news on the 3440A/3444 combo. I tracked the issue down to A2Q2 in the plugin, which is part of the amplifier circuit used in all ranges and functions except 10,100,1000 volts. . It was dead. By happenstance, A2Q2 is a 2N2369, of which I have many on hand due to all my experiments building Jim Williams pulsers, so I replaced it and now she works!  :-+
The following users thanked this post: Cubdriver, med6753, mnementh, bd139, nixiefreqq, Kosmic
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #51092 on: March 01, 2020, 11:47:31 pm »
hey cub
-Pat
i think it might be, but need to go search.  And now that you mention it, I think there were some additional smaller boards that looked to be needed.  Think it might need the edge connectors, too.  Grrr...
-Pat
Offline 0culus
« Reply #51093 on: March 02, 2020, 01:15:22 am »
Checked it out to the best of my abilities and it mostly agrees with my other voltage, resistance, and current measuring equipment, so I'd call it a win. Hard to beat for $30.  :-+
Offline nixiefreqq
« Reply #51094 on: March 02, 2020, 01:34:11 am »
cub
see attached pictures for some of the 5245 stuff that came from the retired depot guy.
have never attempted to go thru it all.  usually just dug until the item in need was found.......then stuffed it all back in the boxes.
if you think something you need might be in there just give me a board number or a picture and the treasure hunt will begin.
free range primate
Offline Kosmic
« Reply #51095 on: March 02, 2020, 02:51:26 am »
My new prototype of the Jim Williams pulse generator. This time in a proper enclosure.
Well, I tried adding an attenuator and the whole thing got pretty wild  :o
Was kind of working but the assembly was really fragile. I decided to rebuild everything on a perf board to improve support and layout. I should really do a proper PCB  :palm:
The final result is not that bad. I got a 755mv pulse with 330ps rise time and 2ns width.
Now I need to build the power supply and see if I can fit a battery in there.
« Last Edit: March 02, 2020, 04:18:47 pm by Kosmic »
The following users thanked this post: edavid, Cubdriver, 0culus
« Reply #51096 on: March 02, 2020, 02:52:56 am »
@nixiefreqq:
Oh fuck me... I have a 28-foot trailer still in storage, and a good 1/8 of it is STILL 57 liter bins who look like that. :palm:
AFTER I spent 6 months sorting it all down... |O
« Last Edit: March 02, 2020, 02:55:22 am by mnementh »
The following users thanked this post: nixiefreqq
Offline worsthorse
  • aina varma, usein väärin
« Reply #51097 on: March 02, 2020, 03:12:08 am »
@nixiefreqq:
Whenever you mention that trailer, my wall of crates in the storage room suddenly looks compact.   :-DD
Offline 0culus
« Reply #51098 on: March 02, 2020, 03:22:19 am »
@Kosmic, really nice results! There are a number of PCB designs floating around for such a pulser...perhaps you could modify one of those.
Offline Kosmic
« Reply #51099 on: March 02, 2020, 03:44:56 am »
I think I'm done with the 2N2369. I Will probably do a pcb to experiment with some other fast rise smd chip. Like the MC100EPT20 (120ps rise time).
