Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36797732 times)
Vince, DashApple and 2319 Guests are viewing this topic.
Offline capt bullshot
« Reply #70100 on: September 22, 2020, 07:37:49 am »
Playing with the Keithley 238:
What's missing on the photo?
Front panel inputs.  :P
Yes, it's kind of annoying having rear triax connectors only.
Anyway, wrong answer.
BU508A: There's a proper decimal point between 0 and 9, so wrong answer too.
Hint: There's a resistor, an Ampere setting and a Volts reading ...
« Last Edit: September 22, 2020, 07:39:26 am by capt bullshot »
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #70101 on: September 22, 2020, 07:45:30 am »
Mnem would say a coat of Tektronix blue?
The following users thanked this post: mnementh, capt bullshot
« Reply #70102 on: September 22, 2020, 07:47:19 am »
NIce plan, but wrong answer.
Hint: It's the TEA forum, and there's some more fetish available other than Tek blue ...
Re: SMtechno SPT-5010A
« Reply #70103 on: September 22, 2020, 08:08:51 am »
Any one have any idea what kind of HV plug type needed for the big white HV terminal ? Is that proprietary ?
The leads for your tester are probably these, hopefully you will be able to find something to fit.
Fairly common for HV kit. It's a standard 4mm plug screwed into the end of a plastic rod. Ideally turn one up on a lathe. A 4mm Plug soldered onto a bit of large coax center conductor and dielectric makes a good alternative. might need a bit of heatshrink to make up he diameter. Even better if you can get a bit of plastic tube that is a good fit and glue a plug into the end of that.
David, thanks.  :-+
That white plug, looks like a mutant banana to me, as it has non standard long body.  ::)
« Reply #70104 on: September 22, 2020, 08:10:16 am »
Okay, you've set the CC to 10nA, you are measuring nearly 1V, therefore this is a 100GOhm resistor.
Looking at the cables I'd say they should be better proper PTFE insulated cables.
And you should have something like this:
« Reply #70105 on: September 22, 2020, 08:18:12 am »
Mhhh ...
You're clearly in need of the thing that is missing on the photo ...
Offline VK5RC
« Reply #70106 on: September 22, 2020, 08:31:43 am »
The cabling doesn't seem to be intact, it goes off screen, also at nA don't you have to be much more careful of shielded cables, ptfe pref, also the resistor and cable sitting on the top of a ? metal earth shield of the smu, shouldn't the DUT be shielded separately and be up at the potential of the source, ie proper triax set up?
(Takes off pedants hat)
Rob
(sore after a 7m long tumble off my mountain bike down a 30degree slope and 5 sutures to my lower lip - where the f****g bike hit me)
« Reply #70107 on: September 22, 2020, 08:37:15 am »
Yes, it's a bodge, but the reading is correct and stable. So wrong answer too.
Rob
Please don't kill yourself mountain biking. I've got a colleague here who broke some bone in his wrist that turned now into a permanent damage.
« Last Edit: September 22, 2020, 08:40:07 am by capt bullshot »
Offline tonyalbus
    • My Channel
« Reply #70108 on: September 22, 2020, 08:38:43 am »
a propper operator  :-DD :-DD
« Reply #70109 on: September 22, 2020, 08:44:00 am »
Rob
This. My immediate counterpart smashed the crap out of himself a month before I broke my arm (which is now healed) and isn't any better as such yet  :(
Fortunately he's a miserable bastard like myself so there isn't a lot of difference  :-DD
Edit: no sign of tinySA dispatch yet despite arrival and tracking ID for Thursday. Wonder how good our drop shippers are this week...
« Last Edit: September 22, 2020, 08:49:21 am by bd139 »
« Reply #70110 on: September 22, 2020, 08:45:10 am »
That's quite near ...
« Reply #70111 on: September 22, 2020, 09:27:55 am »
Mhhh ...
Okok, it is 100MOhm  :P   :palm:
« Last Edit: September 22, 2020, 09:29:50 am by BU508A »
The following users thanked this post: mnementh, Specmaster, capt bullshot, 0culus
« Reply #70112 on: September 22, 2020, 09:29:23 am »
Well chosen.
Edit: see the small picture for the proper operator ...
« Last Edit: September 22, 2020, 09:33:09 am by capt bullshot »
The following users thanked this post: Specmaster, nixiefreqq
« Reply #70113 on: September 22, 2020, 09:29:28 am »
I'll just leave this here before retiring for the evening and sleeping guilt free.  :)
NOTE..... I strongly suggest that if you have a weak constitution you close your browser immediately and call your shrink.  :scared: This could scar you for life. You have been warned.
"Sacrificed so that ours may live"  ;D  :-/O :-DMM
OMG you did not make a 'scope tube clock' out of you 465, did you?  :palm:
Nope, I do have my limits and I would not resort to that kind of carnage.  :-DD This 465 did work at one time or I should say several times between failures. For some reason it just couldn't keep running and would puke it's PSU. I fix and shortly after puke again. Also had vertical attenuator issues. So it became a parts mule. It's biggest sacrifice was the CRT to fix a 465B with a CRT that had focus issues. I also sold the Trigger IC's to a fellow blog member. The DM44 was sold to someone on the Tek Facebook group. Almost like an organ donor program.  ;D
The following users thanked this post: mnementh, AVGresponding, tonyalbus
« Reply #70114 on: September 22, 2020, 09:54:47 am »
Realised that I had several hand held meters out so I did a photo op :-DMM
The following users thanked this post: BU508A, med6753, mnementh, Specmaster, Mortymore, Neomys Sapiens, bd139, tonyalbus
Offline VK5RC
« Reply #70115 on: September 22, 2020, 10:09:23 am »
Rob
I have been riding a lot - since 16yo, moving to mountain biking from road, the cars (well their drivers) on the road is really what scare me now, you don't walk away if a car hits you.
Bugger re the arm bd!
« Reply #70116 on: September 22, 2020, 12:38:27 pm »
I guess I scared him off. Asks for help. Offer it. Crickets.  :-//
I don't bite, I really am a nice guy.  :-DD
https://www.eevblog.com/forum/testgear/need-vertical-position-fiber-glass-shaft-for-465/
« Reply #70117 on: September 22, 2020, 12:41:15 pm »
David, thanks.  :-+   That white plug, looks like a mutant banana to me, as it has non standard long body.  ::)
STILL looks like a job for 3DP to me.  >:D
The following users thanked this post: BravoV
Offline FransW
« Reply #70118 on: September 22, 2020, 12:58:32 pm »
Robert763:
Industrial archeology?
« Last Edit: September 22, 2020, 01:00:29 pm by FransW »
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
Offline McBryce
« Reply #70119 on: September 22, 2020, 01:01:05 pm »
I'm not sure I'd trust 3D printed parts for HV. ABS is a sponge and PLA is full of air pockets. What the breakdown voltage? Creepage distance etc? No idea, then I wouldn't put it between me and a kV source. The original parts look like they are Nylon.
McBryce.
Offline BravoV
  • +++ ATH1
« Reply #70120 on: September 22, 2020, 01:02:26 pm »
You sound exactly like the voice in my head, the one with horn & fork.  >:D
While the other voice says ... Don't you dare even stare at that 3DP rabbit hole !!!  :-[  ::)
Offline BravoV
  • +++ ATH1
« Reply #70121 on: September 22, 2020, 01:03:48 pm »
McBryce.
Yeah, this is what I'm wondering about as this thing generates 5kV AC.
« Reply #70122 on: September 22, 2020, 01:07:13 pm »
Robert763:
The most used are the Fluke 8060As
The following users thanked this post: FransW
« Reply #70123 on: September 22, 2020, 02:26:14 pm »
McBryce.
WTFE.  ;)   If you're handling that bit while its live, you DESERVE what you get.  :palm:
EDIT: The Probulator end... yeah, I agree. I wouldn't print that; except maybe a hand-grip to go around a nylon, FR4 or glass tube which would be the actual probe.
EDIT-EDIT: Dang... woudja lookit that scary-ass HV cable with just a alligator on the end...? That's like... TURBO Suicide Cord; for when the usual AC Line Suicide cord isn't fast enough...   :palm:
 :popcorn:
« Last Edit: September 22, 2020, 02:45:17 pm by mnementh »
« Reply #70124 on: September 22, 2020, 02:31:56 pm »
Also... welcome to Probulator Club.  >:D
« Last Edit: September 22, 2020, 02:34:29 pm by mnementh »
